NEW TSB, Whine Noise From Rear of Vehicle
Discussion in '3rd Gen. Tacomas (2016+)' started by Murrayb4, Feb 7, 2018.
  1. Sep 13, 2018 at 11:19 AM
    #541
    Scott Rosenberger
    Scott Rosenberger Active Member
    18 Double Cab SR5 4wd Long Bed - 08 Sr5 Access Cab 4wd
    Dealer just called, the TSB didn't fix it. Toyota authorized them to order and replace the leaf springs (which aren't part of the TSB for Super Long Wheelbase) too. They're keeping the truck until its fixed and providing a rental car
  2. Sep 13, 2018 at 11:20 AM
    #542
    weezykid
    weezykid Well-Known Member
    2018 TRD OR DCSB 4wd
    Good luck!
  3. Sep 13, 2018 at 11:45 AM
    #543
    Scotty Dosent Know
    Scotty Dosent Know Well-Known Member
    2017 Tacoma DCSB
    My truck had the whine/howl from the rear end. Down hill with foot barely on pedal would result in the noise between 50-60mph. Or freeway cruising slightly below speed limit maintaining speed would do it too.
    Lifted the truck at 10K miles and havent heard it since. Truck now has 25K miles on it. Im guessing it was a resonance issue of some type that changed with the angles produced with the OME lift. I had brought it up to the dealer several times with no answers.
  4. Sep 14, 2018 at 6:28 AM
    #544
    Scott Rosenberger
    Dealer just called, it's all done. Did the TSB AND installed new Rear leaf springs. Their Tech said the Howl is gone. I'm picking it up in a few hours, I'll report back after lunch
    shakerhood, weezykid and NMTrailRider like this.
  5. Sep 14, 2018 at 6:36 AM
    #545
    trazerr
    trazerr Well-Known Member
    Oregon
    2018 DCLB SR5 4x4/1996 AC LX 4x4
    Hopefully it really is gone! I just realized you have the exact same truck as me. I also am pretty sure you are the first non TRD truck that actually got the dealer to do the TSB on. Who is your dealer?? ha
  6. Sep 14, 2018 at 6:42 AM
    #546
    Scott Rosenberger
    I'm hoping its gone.
    I'll provide m case# and Dealer Info after I pick up my truck this afternoon
    shakerhood and trazerr like this.
  7. Sep 14, 2018 at 7:48 AM
    #547
    Lt. Dangle
    Lt. Dangle Thinks skiploder needs a hug
    Ohio
    2017 TRDOR
    stuff
    My tsb has been done for 13k miles or so and it's still fixed Imo. I had the howl on decel from 60-40 mph. I'd still put it at 90% better. Now it's just tire and road noise. I never even think about it anymore.
    shakerhood and Scott Rosenberger like this.
  8. Sep 14, 2018 at 8:07 AM
    #548
    weezykid
    Awesome. My dealer replaced the body mounts and diff, but nothing else and mine still whines. They said I didnt need the leafs, but looks like yours as well as the last poster had the leaves replaced and that helped the whine... Hmmmm...
  9. Sep 14, 2018 at 8:18 AM
    #549
    Scott Rosenberger
    Ours are Sr5's though. The leafs are probably different for the TRD OR
  10. Sep 14, 2018 at 8:22 AM
    #550
    AlabamaBlackSnake
    AlabamaBlackSnake Well-Known Member
    Jim
    4wd TRD OR 2017 dcsb
    Chrome..lot of chrome
    The SR5 does it too I test drove several to test it
  11. Sep 14, 2018 at 8:23 AM
    #551
    weezykid
    Good point that I did miss.
    Going to crawl under tonight to see what part # my springs are...
  12. Sep 14, 2018 at 8:32 AM
    #552
    Loaded NightraiN
    Loaded NightraiN Well-Known Member
    17 TRD Off Road
    I'm assuming I'd know if I had this howling issue? The noise is pretty distinct?
  13. Sep 14, 2018 at 8:39 AM
    #553
    nDub
    nDub #Nibbler
    Central Sierras - Nor(best)Cal
    ‘17 TRDORDCLB and a dǝǝſ
    Lead Free Gasoline
    Oh yeah.
    I think it varies on how loud it can be. Loud like mine to where people didn’t notice it for 20k miles.
    Don’t go looking for it because once you hear it, that is one bell you can’t un-ring. I now hear it in other peoples cars.
    fdbyrne and shakerhood like this.
  14. Sep 14, 2018 at 8:47 AM
    #554
    NMTrailRider
    NMTrailRider Well-Known Member
    Feather the throttle between 55-60mph. On flat, slight uphill or slight downhill. The sound might also happen at ~28mph. I've got the sound happening all over the place post-TSB. Including 2mph. The sound kicks in for just a split second.
  15. Sep 14, 2018 at 10:15 AM
    #555
    Scott Rosenberger
    I'm back from the dealer, it's still there, quieter, but still there, and its audible at different speeds now. They didn't replace the leafs, they did the other 3 part#'s. I guess I'll be getting some Dynamat next
    NMTrailRider likes this.
  16. Sep 14, 2018 at 10:16 AM
    #556
    Scott Rosenberger
    Yeah its like riding with Ric Flair in the back seat Screaming WOOOO! every time you feather the throttle
    1000101, nDub and Loaded NightraiN like this.
  17. Sep 14, 2018 at 10:18 AM
    #557
    weezykid
    I have to call Toyota next (keep putting it off or forgetting) as they need to do something about this when spending so much on a vehicle.
  18. Sep 14, 2018 at 10:22 AM
    #558
    NMTrailRider
    Please stay on them. They're now gonna tell you it's "normal". Don't accept that response.
  19. Sep 14, 2018 at 10:27 AM
    #559
    trazerr
    Oregon
    Thank you, sir!
    Well that sucks. Pretty much the same post TSB results as my SR5. I have sound deaden the entire rear interior of mine. I pulled the rear seats, c pillar trim, and both storage compartments to put the sound deadener in. Also shoved way more foam in the c pillars. It helped a tiny bit, but you can’t unhear the howl once you hear it haha
    shakerhood likes this.
  20. Sep 14, 2018 at 10:46 AM
    #560
    The Real Moondog
    The Real Moondog Well-Known Member
    Moondog
    Somewhere in the SE USA
    2017 Quicksand Tacoma TRD Off-Road
    I hope you get the results you want BUT don’t get your hopes up with dynamat. Keep pushing corporate over this issue. We need a fix yet got a bandaid.
    shakerhood and weezykid like this.
