New TSB
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacoskim, Jul 24, 2009.
  1. Nov 16, 2009 at 2:11 PM
    tomonian77
    tomonian77 Well-Known Member
    Thomas
    Magnolia, TX
    2008 PR DC 4.0
    Painted Rims Black, Painted Emblems Black, Aftermarket Stereo, Grillcraft, BHLM, K&N CAI
    Got it, thx
  2. Nov 17, 2009 at 12:49 PM
    Chad
    Chad Well-Known Member
    Chad
    Cary, NC
    09 V6 Access Cab TRD Sport
    Kenwood DMX-7704S Headunit -- Blackvue DR-470 Dashcam -- Pioneer TS-A1685R Speakers in Front -- Suntek CXP 40 Front Tint -- Access Vanish Roll-up Tonneau -- Wet Okole Seat Covers -- Fog Lights on Anytime -- PnL Powered Tailgate Lock -- DTRL "Stealth Mode" -- LED Footwell and Cup Holder Lights -- Map Lights ON with Dome Light -- Shorty Antenna -- AC Line Extension Mod -- Access Cab Rear Headrest Removal
    Does it look like I could get the TSB with this?
  3. Nov 17, 2009 at 12:53 PM
    tacoskim
    tacoskim [OP] Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    no... the fluid will stick and not go anywhere, its pretty thick.
    also look for a ring above it, its another good way to check for a leak, when the shaft turns, itll leave a perfect circle ring of residue
  4. Nov 17, 2009 at 1:12 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    I have the leak but with the oil pan being so low and the seal being so high on the transmission do you think there would be a significant amount of fuel loss after about 10,000 miles ?
  5. Nov 17, 2009 at 1:14 PM
    tacoskim
    Los Angeles, CA
    Stock
    The leak is very minimal. but why push it for 10k?
  6. Nov 17, 2009 at 1:28 PM
    Asgard
    Just wanted to get an idea of how urgent of a fix it was, I'm changing my front u joint on Friday but the dealer won't get the seal in time for that, 2 to 3 weeks they say they have to ship it in. My truck is vibrating and squeaking like crazy so I have to do the u joint on Friday I know it would be easier to do both but I have to do the seal some other time. December is no good so January 2010 is more like it. The Toyota dealer in Jamaica sells only JDMs, they don't sell the Tacoma only the Hilux.
  7. Nov 17, 2009 at 1:30 PM
    tacoskim
    Los Angeles, CA
    Stock
    Have them replace is with the old replacement seal. thats what i did and it held for bout 2 weeks till the leak came back, then put the double seal on. just depends on how good of relationship u got with ur service manager. my guy was nice enough to do it
  8. Nov 17, 2009 at 2:16 PM
    Asgard
    I think I'll do that.
  9. Nov 26, 2009 at 12:09 PM
    JAG
    JAG Well-Known Member
    I have this prob, but out of warranty. Can I do it myself if I buy the seal? Will I have to replace the trans oil too? Thanks.
  10. Nov 26, 2009 at 12:35 PM
    ikataco
    ikataco Well-Known Member
    06 DC Sport
    One could just replace the amount of oil leaked out. I'd drain & refill the transmission personally.
  11. Dec 3, 2009 at 10:13 AM
    Asgard
    Well I changed my seal today, did it while doing an oil change. Updated part number : 90311-40034. About a 1/4 cup of transmission oil came out but I don't think it will be a problem so I didn't bother to refill. 1/4 cup = 1/8 quart and the transmission holds about 11 quarts. Took about 1hr.
  12. Dec 3, 2009 at 12:10 PM
    ikataco
    06 DC Sport
    How many miles on your tacoma? Wondering what color was your transmission fluid.
  13. Dec 3, 2009 at 12:14 PM
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    What Frederal law states you get a new truck if the old one leaks?
  14. Dec 3, 2009 at 12:30 PM
    ikataco
    06 DC Sport
    I still have the leak after the TSB. Why is my Taco going in for the same repair twice again! 1st was rear differential leak at 31k miles, two dealerships. Now, the transmission extension housing seal twice.
  15. Dec 3, 2009 at 12:34 PM
    #35
    Asgard
    50k miles. I want to say red but it was more like pink.
  16. Dec 3, 2009 at 12:39 PM
    #36
    Asgard
    Maybe they didn't replace it with the updated seal. It happened to the OP. Make sure they use part number : 90311-40034 and not 90311-40001.
  17. Dec 3, 2009 at 12:43 PM
    #37
    ikataco
    06 DC Sport
    Well, according to the service invoice, part# 90311-40034 is listed.
    red to pink tranny fluid. So, it didn't resemble the color of the picture above, 1st post of this page. coffee color
  18. Dec 3, 2009 at 12:49 PM
    #38
    Asgard
    ^^I just replaced my seal today so I guess I'll have to keep an eye on it. Maybe it's just the photo, but dark brown (coffee) color transmission fluid usually indicates the fluid is burnt and thats not a good thing.
  19. Dec 6, 2009 at 1:54 PM
    #39
    Yuma Taco
    Yuma Taco Well-Known Member
    Lee
    Yuma, Az
    09 PreRunner DC TRD
    35% tint windows, OEM black running boards, OEM black roof rack, Foglight mod, De-badged & Sockmonkey Horns decals added, Two ammo box storage units (removed), 110 volt & 12 volt outlets for back seat area, EGR Slimline inchannel visors (all windows), Fold-A-Cover G4, Tonneau, Bedmat.
    Tacoskim, thanks for the information on the TSB.
    Ikataco thanks for the photo!
    I just found the same leak today while trying to find the drive-line shaft zerts. (I found no grease zerts by the way!) :eek:
    I'll check it again next week then contact the local dealer for this TSB and a couple of others (speakers & ask about the suspension).
    Yuma Taco,
  20. Dec 6, 2009 at 3:49 PM
    #40
    Phantom_X-SP
    Phantom_X-SP Rude Boy |><|
    High Point, NC
    08 DC Black Sand Pearl X-SP
    This is good to know...I noticed this leak on my '08 a couple of weeks ago while under the truck checking the propeller shaft. Looks like another trip to the dealership.
