New Tundra...Tacoma redesign
Discussion in '2nd Gen. Tacomas (2005-2015)' started by forana, Dec 9, 2013.
  1. Dec 15, 2013 at 4:29 PM
    #81
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    I see. The 2GR-FSE is the longitudinal variant which already has DI. I don't know if it may be cost prohibitive to put in the Tacoma since Manufacturers usually don't like to put an engine available in their luxury line in their domestic line. It tends to bring down the desire of their more expensive models.
  2. Dec 15, 2013 at 5:26 PM
    #82
    Quentin
    Quentin Well-Known Member
    Eleanor, WV
    2016 Toyota 4Runner Trail Edition, KDSS
    The FSE is the D4-S injection setup. That means 12 injectors in a V6. I don't know that the new 2GR revision is getting the D4-S or just 6 injectors. I imagine there are some internal bits that are different, too, but I expect the 2GR-FSE will be getting some upgrades of its own to keep it differentiated. We know the 2.0T is coming down the pike for Lexus, so I'd be surprised if the IS350 and GS350 got nothing in the way of upgrades at that time.
  3. Dec 15, 2013 at 6:04 PM
    #83
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    FTFY
  4. Dec 16, 2013 at 6:05 AM
    #84
    TexAggie
    TexAggie Well-Known Member
    Eric
    Houston, TX
    OME Lift
    The Taco/4runner is the exact same as the Tundra/sequoia IMO. What exterior parts do the Tundra/Sequoia share? To me both relationships consist of similar design, dimensions and power.
  5. Dec 16, 2013 at 6:22 AM
    #85
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    Hood, headlights, front fenders, front doors at the least
    grille and bumper are interchangeable if you keep them paired.
  6. Dec 16, 2013 at 8:59 AM
    #86
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    Be great if the D4D made it in the 2015-16 state side. Would make the swap for me alot easier, monetarily speaking.
  7. Dec 16, 2013 at 9:59 AM
    #87
    TexAggie
    Eric
    Houston, TX
    OME Lift
    Not the new ones.
  8. Dec 16, 2013 at 10:01 AM
    #88
    richardbui23
    richardbui23 That guy
    Richard
    Arlington Texas
    Stacy
    [​IMG][​IMG]?
  9. Dec 16, 2013 at 7:44 PM
    #89
    Quentin
    Eleanor, WV
    Only because they didn't update the '14 Sequoia. The Taco and 4Runner share(d) some running gear (engine, AT, diffs, etc), but the interior and exterior aren't interchangeable at all. The 4Runner shares a lot more with the Hilux than the Tacoma as far as platform goes. The Sequoia and Tundra were practically the same inside and outside from the b pillar forward. You can't say the same for the Tacoma and 4Runner.
  10. Dec 16, 2013 at 9:37 PM
    #90
    Rich91710
    Rich
    Los Angeles
    08 Base
    1st Gen Doublecab Tundra was identical to the Sequoia down to the wiring harness. The 1st Gen Sequoia was not the same as the 1st Gen single/access cab... the "Beltline" was about an inch and a half thinner on the 1st Gen pickups. I think the hood was interchangeable, but the grille on the Sequoia was taller.
    1st Gen RC/AC had a different wiring harness than the Doublecab. Made for some very interesting mod translations.
    But ya, on the 4R/Pickup, the two have been very different beasts since 1995.
