New TVS1320 MAGNUSON 3.4 supercharger available 30 percent larger rotors!
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1997tacomav6, Aug 25, 2023.
  1. Aug 25, 2023 at 5:44 PM
    1997tacomav6
    1997tacomav6 [OP] V6 5sp,RegCab,TVS1320 Supercharger,Haltech, 800k
    Denver
    Prototype TVS1320 has arrived!! Coming in HOT
    Teaser number #2 with some technical data.
    I bought my 1997 single cab v6 new and added the Trd supercharger the following year when they 1st hit the market in late 1998.
    Now at 750,000 miles later ( lots of supercharger rebuilds) it’s time for an upgrade with the newly designed TVS1320 supercharger from magnuson.
    Installation and tuning the TVS1320 with the current haltech stand alone ECU with Gabe Salazar from snpspeed will follow on a new post shortly here.
    Enjoy!
    Well the newest generation 3.4 TVS1320 supercharger has arrived.
    So 1st Lets go over the differences between the two superchargers new and old style.
    New superchargers Rotors will be 30 percent larger.
    TVS1320 is 1320 cc per revolving, (air flow)
    Old design is 1000cc per revolving,
    TVS has 4 lobe rotors that are 160 degree twist,
    Old supercharger is 3 lobe 60 degrees rotor twist,
    TVS has Larger input and output sections on the supercharger,
    TVS bearings are rated at 20k rpm’s,
    Old supercharger rated at 12-14k rpm’s,
    TVS power to run the supercharger is 10-15hp,
    Old supercharger probably 30hp plus depending, TVS supercharger will be running a 3” two piece quick change pulley to slow it way down,
    TVS will make 4 pounds of boost with this pulley to turn it much slower compared to 6 pounds of boost with the older supercharger to equal the same power output.
    The TVS will be using a two piece pulley with 4 bolts and is not setup with a key way slot to deal with anymore.
    So changing out the pulley will be super quick and easy.
    The TVS with the 3” pulley will be rated at the same hp possibly a bit more to match the old supercharger so that the emissions requirements are the same and extensive emissions testing will not have to be done.
    Rebuilding the TVS supercharger time mileage intervals should be much higher because the new bearings are rated at 20k and the TVS supercharger will be turning much slower and a reduction of heat.
    The TVS1320 will have the ability to have a smaller pulley added, stock pulley will be 75mm (3”). A 70mm pulley possibly a bit smaller will work but needs to be made by Gaget URD or others. Because it’s a specific offset for this 3.4 there are no smaller pulleys available immediately unless a custom one is made.
    For more boost past the 70mm pulley having the snout wall shaved where the pulley will be pushing into the snout probably will be another option. URD actually sells a snout cutter for the 4 liter magnuson supercharger that removes 10mm from the snout and sells a number of smaller pulley for this specific cut. I’m betting this might be a popular choice if there is a possibility for shaving.
    The stock Pulley should be a 75mm, 4-rib w/2.286mm offset. This offset is what lines up the pulley to the tensioner. TVS will use the same dynamic tension setup as before.
    The 1320 will have an ERG valve port for the 7th injector from URD and OR if your running an EGR valve and tube for emissions to the headers or stock exhaust WHICH might not be in the EXACT same location so that EGR pipe might have to be modified to fit for Emissions, but not 100 percent sure sure yet, will chime back in when I do the inspection.
    As with the old supercharger you will be able to run it stock with the 3” pulley on stock ECU, But at the minimum you should have injector cleaned and serviced because each injector has a fuel filter, install a high flow fuel pump and add a vortech 3-1 FMU from snpspeed .com that has the correct size fittings and lines. An FMU will raise the fuel pressure in boost only and turn the stock injector 270cc into a 340cc injector ( as bench tested by Gabe Salazar) on demand.
    You will be able to add the 7th injector kit from urd also for fuel and tuning, possibly a modified version? Gadget URD has the market cornered in making extensive styles, mods and smaller pulleys for magnuson superchargers and I’m sure will be chiming in with new pulley options.
    I will be running the haltech ECU from SNPSPEED Gabe Salazar with an FMU as I had before on the previous TRD supercharger (I’ve been running the haltech ECU for 3 years now and it makes huge power gains in the lower and midrange rpm’s over the stock ECU) and he will have a specific tune setup for the TVS1320 if you go haltech.
    I will then source out a smaller custom pulley 70mm or possibly getting the snout shaved for a smaller pulley and go from there to see the results with a dyno at a later date with comparisons. The TVS with the stock 3” pulley for me at 6000 feet will probably be soft on power hence getting the smaller 70mm pulley made and snout shaved for a smaller pulley option if possible.
    1). Oil - Eaton and contact SuperchargersOnLine https://superchargersonline.com/product/eaton-supercharger-oil-bulk-fill-8-oz/ (we utilize from 55gal. drums)
    2). 4.0577 ounces or 120ml
    3). M8 bolts are 18 foot pounds torque
  2. Aug 25, 2023 at 6:07 PM
    ChargedSHOTaco
    ChargedSHOTaco Well-Known Member
    So, have you installed it yet?
  3. Aug 25, 2023 at 6:10 PM
    1997tacomav6
    Denver
    Just got it today, hopefully this coming week and needs to be turned with the haltech:)
  4. Aug 25, 2023 at 6:29 PM
    ChargedSHOTaco
    Not sure why the retune as it should work with the existing tune, then dial it in on the dyno. I'm thinking the biggest advantage will be cooler IATs, and max power coming on earlier.
    Anyways, can't wait to hear your impressions.
  5. Aug 25, 2023 at 9:30 PM
    jacobrippey
    jacobrippey It’s always Taco Tuesday Instagram #rippstik
    Jacob
    Surprise, Arizona. USA
    2004 Tacoma DC 4wd
    Find me on Instagram: @rippstik
    I’m stoked that it went to you! Truly a deserving individual and Tacoma!
  6. Aug 26, 2023 at 3:28 AM
    roboturner
    roboturner Dead Eyed
    Colorado
    00 IJM AT XC 4x4 3.4L TRD | 18 CB MT DCSB 4x4 V6 Pro | 98 NW MT 4x4 3.4L SR5 4Runner
    Subd for numbers and thoughts - she’s hot!
    1997tacomav6[OP] likes this.
  7. Aug 26, 2023 at 10:28 AM
    sean.hwy
    sean.hwy Well-Known Member
    Sean
    Do you know if this will be california smog legal like the other ones?
    btu44, Xjman1 and 1997tacomav6[OP] like this.
  8. Aug 26, 2023 at 8:57 PM
    1997tacomav6
    Denver
    Yes it will I believe
    btu44 and sean.hwy[QUOTED] like this.
  9. Aug 26, 2023 at 9:32 PM
    Xjman1
    Xjman1 Well-Known Member
    JB
    2004 Tacoma TRD 4X4 X-CAB
    King coil overs, Rear shackle lift
    I live right around the corner from them and fighting off temptation has been hard and now this.......
  10. Aug 26, 2023 at 11:50 PM
    sean.hwy
    Sean
    ooooo..
    thanks.
  11. Aug 27, 2023 at 2:57 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    That's purrty!!
  12. Aug 27, 2023 at 3:02 AM
    SmoothTRD
    SmoothTRD Well-Known Member
    Ugh, the raptor lights......
    boostedka, ChargedSHOTaco and ace_10 like this.
  13. Aug 27, 2023 at 5:42 AM
    1997tacomav6
    Denver
    Should be finished installing it today,
    Shes definitely bigger
  14. Aug 27, 2023 at 9:21 AM
    jacobrippey
    Jacob
    2004 Tacoma DC 4wd
    WHAT A UNIT!
  15. Aug 27, 2023 at 9:27 AM
    Madjik_Man
    Colorado Front Range
    Ugh, meaningless and irrelevant posts.
  16. Aug 27, 2023 at 12:13 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    It's a beast compared to the old one.
  17. Aug 27, 2023 at 9:33 PM
    1997tacomav6
    Denver
  18. Aug 27, 2023 at 9:35 PM
    sean.hwy
    Sean
    nice!
  19. Aug 27, 2023 at 11:16 PM
    mechanicjon
    Jon
    Scottsdale Arizona
  20. Aug 28, 2023 at 11:26 AM
    TacoMac156
    TacoMac156 Member
    2002 IMPULSE red tacoma 3.4 4x4 5spd
    Bilstein 5100 Deck plate mod URD short shift Magna flow cat back exhaust
    Subbed, and congrats! Your FB post said that is much quieter than the older ones. Hope to hear some driving videos in cab and/or with windows down!
