New U-bolts for AAL with TSB springs??
Discussion in 'Suspension' started by crawlerdog, Oct 4, 2010.
  1. Oct 4, 2010 at 7:40 AM
    crawlerdog
    crawlerdog [OP] Member
    Scott
    New Mexico
    2010 Toyota Tacoma access cab 4x4 TRD OR
    Billies all around with 2.5" in front, TSB with Toytec 1.5" AAL, 265/75/16 Yokohama Geolander AT-S Redline Elite struts, Ultragauge, Yaseu FT-7900 radio, Leer XL topper, Westin nerf bars.
    Wondering if I need new longer U-Bolts if I add the Toytec 1.5" AAL for the TSB rear leafs?
    Also thinking about adding the shims. Will this require longer U-Bolts?
    Thanks. Love TW.
  2. Oct 4, 2010 at 7:41 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    If you add only the AAL, your U bolts are going to be fine. No need to buy new (being as your truck is new). If you add the shim, you may need longer ones.
  3. Oct 4, 2010 at 8:05 AM
    dirtytaco2010
    dirtytaco2010 Well-Known Member
    south lake tahoe, CA baby
    SR5 TRD Sport LB
    custom badging, Black Badges, tint, General AT/2's, nerf bars black, ultra-gauge,toytec AAL, removed mud flaps, Bilstein 5100's @ 2.75, AFE pro dry s air fliter, spidertrax, black rock 17'' wheels
    i have stock bolts too no problems here
  4. Oct 4, 2010 at 8:07 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    If you're re-using the original u-bolts, just make darn sure you torque them enough and CHECK THEM regularly until you are absolutely sure they're not coming loose. Depending on the situation, they may or may not stay tight over time.
  5. Oct 4, 2010 at 8:43 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    To add: DO NOT over tighten them.
  6. Nov 20, 2010 at 5:45 AM
    mach1man001
    mach1man001 eh whatever
    Rob
    Blackstone, MA
    '09 Sport DCLB Met Grey
    Toyota bed mat (1st mod), Toyota all season floor mats, Rear spring TSB, Map light mod, Fog light mod, Putco yellow fog bulbs, Weather Tech window vents, Extra d-rings, Mounted mag light, TRD CAI with AFE pro dry filter, '05 front mud flaps (winter only), 2 set's of wheels/tires, 285/75/16 Hankook MT's, Black Painted 1st Gen TRD wheels (wheeling set) Black powder coated FJ Cruiser with 265/70/17 BFGoodrich KO2's (everyday), painted center of grill & bumper black, Devil horns, OME with 885's + spacers front, OME shocks w/OMD designed rear springs, Front diff drop, Rear trailer plug relocate, ATO IFS skid, Relentless Trans & Transfer skids, BAMF bolt on rock sliders, Relentless tailgate reinforcement, Uniden 75 CB radio, BAMF antenna bracket, TRD exhaust, high lift jack w/ATO mounts. And of course ProEFX Towing Mirrors!
    Please correct me if I'm wrong. I know people do it but I thought you were not supposed to reuse u-bolts??? Once you remove them you should replace them???
  7. Nov 20, 2010 at 6:09 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Your not, but if they are not that old, less than 1 year, I would, but just check the torque of the bolts regularly.
  8. Nov 20, 2010 at 6:28 AM
    mach1man001
    Rob
    Blackstone, MA
    Thanks Chris.
  9. Nov 21, 2010 at 9:04 AM
    brelandt
    brelandt Well-Known Member
    Terry
    Dublin, CA
    04 Prerunner reg cab SR5
    3" lift front and back
    I've reused U-bolts for as long as I can remember and have never had a problem afterwards. I even reused the 25 year old ones on a 65 mustang years ago and they never failed or anything.
