New u-bolts for Toytec 1.5" Single AAL on TSB springs?
Discussion in 'Suspension' started by Vantage, Nov 14, 2012.
  1. Nov 14, 2012 at 9:02 PM
    Vantage
    Vantage [OP] Well-Known Member
    Luke
    Vancouver BC
    2015 Titan Pro 4x
    Just as the title says.
    Will I need longer U-bolts to mount my Toytec (deaver) single AAL 1.5" lift into my stock 4 leaf (TSB) pack.
    Looking to install this weekend.
  2. Nov 14, 2012 at 9:04 PM
    Large
    Large Red
    Not sure about longer but you'll need to replace them anyway once you remove them.
  3. Nov 14, 2012 at 9:45 PM
    Vantage
    Luke
    Vancouver BC
    2015 Titan Pro 4x
    Ok good to know, I will have to go pick some up.
    I was unaware they were a 1 time use item. My last truck came with a set for the new Deaver springs.
    Are u-bolts a standard width? If not, what width does a Taco take?
    A search told me I need 7.5"-8" length, but nothing about width.
    Thanks.
  4. Nov 15, 2012 at 7:20 PM
    Vantage
    Luke
    Vancouver BC
    2015 Titan Pro 4x
    Bump.
  5. Nov 15, 2012 at 7:27 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Why cant you reuse them? I did the same that op is doing 15k ago. No problems only rechecked torque after 500 miles and then again at 10k. No changes.
