New ucas or cv boots?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Gavinfritz101, Aug 23, 2011.
  1. Aug 23, 2011 at 7:03 PM
    Gavinfritz101
    Gavinfritz101 [OP] THE Gavin Fritz.
    Gavin
    Temple, Tx
    01 SR5 4x4 Gold
    Blacked out emblems, grill guard, Wade wind deflectors, White led dome light, Camo Steering wheel cover.
    Hey I am planning on running 5100s all around with eibach coils up front with a rear aal. Do I have to have new ucas or cv boots??
  2. Aug 23, 2011 at 7:08 PM
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Fort Collins, Colorado
    bone stock / unmolested 04 2.7L
    I don't think you have to have either of them. If the CV boots aren't torn leave them alone. But get UCAs if you want "proper" alignment. I've been running my 3" lift for 1 1/2 years now and still have stock UCAs. I think the caster(?) is off a bit but other than that it seems to align and run fine.
  3. Aug 23, 2011 at 7:11 PM
    Gavinfritz101
    Gavin
    Temple, Tx
    01 SR5 4x4 Gold
    I don't think I can afford ucas right now. I'm broke and don't have a job :/
  4. Aug 23, 2011 at 7:11 PM
    TacoSID138
    TacoSID138 Well-Known Member
    SoCal
    04 PreRunner TRD
    Faded out tinted tails and 3rd brake light,deck-plate mod, dumped Flow Master 40, King EXTD coil overs, 1.5 AP shackles, AP EXPD leafs. 285 Hankook DynaPro ATM tires
    i have the same setup up front. have stock UCAs. no problem with alignment. x2 about the CV boots^
  5. Aug 23, 2011 at 7:17 PM
    45acp
    Jonathan
    You can live without them just fine. I'll get some eventually... unless I SAS before I get around to that haha
  6. Aug 23, 2011 at 7:21 PM
    Gavinfritz101
    Gavin
    Temple, Tx
    01 SR5 4x4 Gold
    Ok good :) how much does it cost tonged this setup installed??
  7. Aug 23, 2011 at 7:22 PM
    45acp
    Jonathan
    It's free if you do it yourself.:D
  8. Aug 23, 2011 at 7:23 PM
    Gavinfritz101
    Gavin
    Temple, Tx
    01 SR5 4x4 Gold
    I'm am mechanically challenged!
  9. Aug 24, 2011 at 9:50 AM
    jbrandt
    jbrandt Well-Known Member
    Sacramento, CA
    '04 TRD Tacoma 4x4 DC
    King ext travel coils Total Chaos UCAs Sticker mod
    A 3" will probably be at the upper end for the CV boots, but there's a lot of guys on here that run 3" with no problems. Depends on how you drive. Easy drviers shouldn't have a problem
    You don't need new UCAs. Just get an alignment done when you install the shocks at the height you want (you should do that anyway).
  10. Aug 24, 2011 at 9:52 AM
    jbrandt
    Sacramento, CA
    but you're getting a lift for your truck??
    Do it right, or don't do it, it will end up costing you more in the long run. Like I said, though, you should be fine with stock parts...
