New UCAs?
Discussion in '1st Gen. Tacomas (1995-2004)' started by STLharry, Jul 13, 2009.
  1. Jul 13, 2009 at 8:17 PM
    STLharry
    STLharry [OP] Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    So I have OME front suspension with the stock UCAs that have obviously seen better days.
    My question is, Is it worth it to buy new UCAs? What exactly would that do?
    and Where would I get them/What brand UCA should I purchase?
    thanks guys
  2. Jul 13, 2009 at 9:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    I think its worth it, but it mainly depends on the driving you mostly do. The Uniball is MUCH stronger than the OEM Ball joint, and allows for more travle. ALso, many aftermarket UC's correct Caster lost when lifting.
  3. Jul 14, 2009 at 6:16 AM
    STLharry
    Harry
    VT
    would i be expecting to pay in the ballpark of 600-800 for them?
    thats what ive been finding
    seems sort of expensive since my whole front suspension cost around 400 for the parts.
  4. Jul 14, 2009 at 7:28 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    TC's an be had for around $600.00. If you get the UCA's that use a Ball Joint, they will be around $400.00
  5. Jul 14, 2009 at 8:29 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    How is your alignment specs? Do you wheel? How much lift do you have?
  6. Jul 14, 2009 at 9:06 AM
    STLharry
    Harry
    VT
    uhh not sure
    yes i do
    and around 2 with the OME suspension
  7. Jul 14, 2009 at 10:16 AM
    sirsaechao
    Tim
    Commifornia
    If you have the extra cash spluge on the Uniball UCA's. More wheel travel. And tire width to UCA clearance. Much beefer and corrects caster when lifting your truck. I think anytime you can beef up your suspension, don't skimp on it.
  8. Jul 14, 2009 at 4:55 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    I got the TC's and love them.. It fixed my allignment and I love knowing how strong they are. :)
  9. Jul 20, 2009 at 9:58 PM
    mick478
    mick478 He is The STig
    Bott
    Stockton, CACA
    2011 White TRD Sport, 4x4 doublemint cab
    Ome 885 coils Ome n9000 front shocks Ome n182 rear shocks K&n drop in filter Duratracs Kenwood kac 90210d Kicker 12" Alpine 800 watt 4 channel Pioneer 430w 6x9 Firestone ride rite air springs
    ok, so when i took my truck to the alinement shop after i lifted it they said it went right back to spec, so how are the uca's gonna fix my wandering issues if it is already good with stock uca's and alinement at spec? :confused: i lifted it 3" and i took it back for wandering issues once, i just want to know how these work, and if it will correct and eliminate wandering issues, not just make it better. any help is welcome thanks guys
  10. Jul 20, 2009 at 10:10 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    -The new UCAs will put your allignment back to the correct specs. Once you lift your truck 3" or higher your stock UCA's are flexed to the point where the tires will wonder and the camber won't be able to be adjusted correctly. I'm having this issue right now myself...TC UCA's are on the way, then 5100 Billys and Coil Overs. I hope this helped, its hard to explain ya know? lol
  11. Jul 20, 2009 at 10:30 PM
    mick478
    Bott
    Stockton, CACA
    yeah im still confused, how much did the new uca's set you back, and if it made the difference. it feels on the highway like i get a breeze and im halfway in the next lane, and once i feel like i have a handle on it, i over correct and on the other side.... uca's sound like a good fix thanks
  12. Jul 20, 2009 at 10:33 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    images1-1_6d52e8023cf52f3521304dbdbbfd47dd7e7016d4.jpg;) Aftermarket UCA's will def. fix all your probs :D There's a bunch of brands to choose from...Light Racing, AllPro, Total Chaos, Camburg etc...Total Chaos seems to be the popular one around here
