(New Update now rod knock) 1Grfe new head gasket question .
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Imense, Aug 13, 2020.
  1. Aug 15, 2020 at 7:56 AM
    Imense
    Imense [OP] Active Member
  2. Aug 15, 2020 at 7:58 AM
    Imense
    Finally took the plunge and by the guidance of all u guys I installed the heads .almost forgot the exhaust gasket .
    Now to torque them down according the Toyota manual 36 pound foot.
  3. Aug 15, 2020 at 8:01 AM
    Imense
    This water ports are pain in the cylinder heads .very stubborn to assembleimage.jpg
  4. Aug 15, 2020 at 9:41 AM
    Imense
    Oh $&@@ forgot to click the wires on to right side knock sensor .hand cannot reach it .
  5. Aug 15, 2020 at 9:49 AM
    Muddinfun
    Muddinfun Well-Known Member
    36 ftlb is nowhere near enough for head bolts. Torque to yield bolts are generally xx ftlbs + 1/x of a turn.
    Jimmyh likes this.
  6. Aug 15, 2020 at 9:59 AM
    Imense
    Yup I did according to manual 36nm and than 180degree turn
    Muddinfun likes this.
  7. Aug 15, 2020 at 10:01 AM
    Imense
    Should I cut the water pipe flange to get to the knock sensor wire or take off the left side head which I really don’t want to do .
    Any suggestions?
  8. Aug 15, 2020 at 10:22 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I'd be willing to bet with enough patience and long needle nose pliers you can get the connector installed.
  9. Aug 15, 2020 at 10:24 AM
    Imense
    It’s very tight area and it’s at an angle as well
  10. Aug 15, 2020 at 10:41 AM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    I had a shop that was able to repair the knock sensor wiring without removing the head or the coolant pipe. They got to it just by removing the intake plenum, which you already have apart there.
    Jimmyh likes this.
  11. Aug 15, 2020 at 11:13 AM
    Imense
    image.jpg No space for a nose plier
  12. Aug 15, 2020 at 11:17 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Try a pair of Hemostats... Long short curved ... all types.
  13. Aug 15, 2020 at 11:22 AM
    Imense
    Jimmyh thanx buddy for advise but it’s middle of night and curfew outside I can’t go and buy anything only shipping god knows how long it will take .
  14. Aug 15, 2020 at 11:25 AM
    Imense
    image.jpg I have cut the first flange and pipe is abt 20 percent more moveable i will try to wiggle the connector back on to sensor another wise will cut the second flange as well.
  15. Aug 15, 2020 at 11:30 AM
    #35
    Imense
    image.jpg Got it
    Maticuno likes this.
  16. Aug 15, 2020 at 11:33 AM
    #36
    Imense
    image.jpg Look at my hand it’s inside Toyota
  17. Aug 15, 2020 at 11:34 AM
    #37
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    36 Newton Meters is a bit different than 36 Foot Pounds.
  18. Aug 15, 2020 at 11:35 AM
    #38
    Imense
    Sorry my bad typo error
  19. Aug 15, 2020 at 11:40 AM
    #39
    Imense
    image.jpg I must be bad at it now pins came out of the connector , any idea which color pin goes which side of connector ?
  20. Aug 15, 2020 at 11:48 AM
    #40
    Imense
    White pins goes to outer side as found by google search courtesy of Tacomaworld forum 6E6D98EA-90DC-4C20-9299-10549CBBE8ED.jpg
