New v6
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Nomad_Pilot, Apr 14, 2018.
  1. Apr 14, 2018 at 6:33 AM
    Nomad_Pilot
    Nomad_Pilot [OP] I need to pewp
    Clay
    Ft Collins
    Hey all you v6 guys, 1gr vs the new 3.5? I drove my mom's 2018 4runner to arizona and back pulling a trailer, it did awsome. 21 mpg empty and 17 mpg on the way back. I thought it had the new 3.5 but it doesn't. Will the new 3.5 in the tacoma preform that good? I am looking to upgrade from my 2tr-fe so I can tow a camper. I have 4 choices.
    Swap in a d4d common rail
    Get a tacoma with 1gr
    Get a tacoma with 2gr
    Put on urd charger to current truck
  2. Apr 14, 2018 at 6:36 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Test Drive a new Tacoma and see if you like how the 3.5 feels.
    jeremy5000 and Plain Jane Taco like this.
  3. Apr 14, 2018 at 6:37 AM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Perhaps you could snag a 2018 4Runner...
  4. Apr 14, 2018 at 6:43 AM
    Nomad_Pilot
    Clay
    Ft Collins
    I tried, can't find a manual to test drive
    I need a truck . I fly helicopters and am in the process of buying one. I have a jet fuel donkey tank I slide on the back for remote ops. I am also gonna buy one of those micro minnies to take out on the job, thats why I am looking to upgrade to v6.
  5. Apr 14, 2018 at 6:48 AM
    shakerhood
    Southern Ohio
    You may have to search for a Manual, but test driving a new Tacoma is the best thing you can do, you already drove the 4.0 so now try the 3.5 to see if you like it.
  6. Apr 14, 2018 at 6:57 AM
    Nomad_Pilot
    Clay
    Ft Collins
    How about the select shift transmission, if I select 3rd, will it start off in 3rd, or will it not shift past 3rd?
  7. Apr 14, 2018 at 7:00 AM
    tonyinsight2
    tonyinsight2 Well-Known Member
    need some pics!!!
  8. Apr 14, 2018 at 7:02 AM
    aleriance
    aleriance Well-Known Member
    Jorge
    Naples, FL
    2017 TRD Off-Road 4x4
    CMC 285/70/17
    Will not shift past 3rd. That's one of my biggest complaints about my 3rd gen. The gear selector basically is just a gear limiter. If I select 4th gear and floor it, I wan't it to stay in 4th gear! Instead the truck will downshift as if you had it in drive... Supposedly the near $1k "magical fix" tune out there will take care of this...
  9. Apr 14, 2018 at 7:21 AM
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    The tune is damn near magic.
    OP, the 3.5 technically makes more power than the 4.0 but it hides it up top so the first thing you’ll notice with the 3.5 is that it feels gutless down low. There are tons of modes you can use to access different power bands. There is an ECT button that makes the throttle and shift maps a little more aggressive and you can limit the gears with the S-mode but it isn’t a “manual” style shifter. The MT guys seem to be pretty happy overall and even more so if they drop the $800 on the tune which will give you more power down low and in the midrange.
    My friend hasn’t a 18 4Runner pro and with my truck tuned and running premium my truck feels more agile and similar in power down low. Stock (untuned) it was no comparison. My truck felt 2,000lb heavier and much slower down low. FWIW
    shakerhood and MOC221_ like this.
  10. Apr 14, 2018 at 7:30 AM
    Nomad_Pilot
    Clay
    Ft Collins
    Ok thanks, I think I will look for a 2nd gen v6 manual then.
  11. Apr 14, 2018 at 7:30 AM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    This is how normal automatic transmissions have worked for 50 years. They are all like this, with the ability to gear-limit only using the selector . Why would you expect to be able to force it to hold a single gear? Why is this a complaint? Is there any auto tranny from any maker that allows you to hold a gear? None I’ve ever driven. Maybe in a Lamborghini?
    Lt. Dangle, jeremy5000 and bshammer0 like this.
  12. Apr 14, 2018 at 7:34 AM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    ^^ What he said. You're probably going to see some 2nd Gen Tacoma 4.0 fans who have driven the 3.5L a couple of times say the new setup is gutless. On the stock tune (IN MY OPINION), it does feel that way down low. Then again, you may try a stock M/T and love it. I hear the stock calibration on the '18s is better. Just saying there is an aftermarket option to make the truck work "better" if you feel the need. There are also dyno results to back it up (A/T, we never really got one for the M/T after the latest tune version came out). Anyway, best of luck Op!
    bshammer0[QUOTED] likes this.
  13. Apr 14, 2018 at 7:36 AM
    MOC221_
    Frank
    You can't really go wrong there either.
    bshammer0 and shakerhood like this.
  14. Apr 14, 2018 at 7:55 AM
    Nomad_Pilot
    Clay
    Ft Collins
    It's not how they have worked for 50 years. Check your facts. Both ford and Chevy had cars in the early 80s that had push button transmissions, whatever button you push, that's what gear you get. Both Chevy and dodge currently have transmission that hold whatever gear they are told. I have a Chevy sitting in the drive that when I select manual mode 5th, that bitch starts at 5th, and will not shift out. And it's a complaint becuase autos hunt for gears in hills. You probably have only driven autos your whole life, so you dont see anything wrong with it. I have never owned an automatic, and I don't really want too either
    airborndad and 02Duck like this.
  15. Apr 14, 2018 at 7:59 AM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    Get a 4runner or Tacoma with the 4.0, the 3.5 engine in the new Tacomas is more like a Honda civic motor. Not a lot of torque and you have to rev it up.
    bshammer0 likes this.
  16. Apr 14, 2018 at 8:00 AM
    Stocklocker
    17TRDORDCSBAT
    Wrong / Fake info. You do not own a “Chevy” auto that will start at a stop sign in 5th gear. Sheesh
    Cole man and TFly like this.
  17. Apr 14, 2018 at 8:09 AM
    MOC221_
    Frank
    Op, just get a manual and be done with it lol. You know you won't like an auto, as you've already stated you've never owned one.
    Also, this thread is gonna blow up with a "how an auto trans works" fight. :duel:
  18. Apr 14, 2018 at 8:09 AM
    ramirj2
    ramirj2 Active Member
    Jose
    2018 TRD OFF-ROAD 4x4
    The 6R80 in my Mustang will act as a manual in sport mode, holding the gear even if I’m banging the rev limiter and will down shift wherever I want it to from the factory
    Also it will rev match on down shifts
  19. Apr 14, 2018 at 8:12 AM
    hookembevo
    hookembevo Well-Known Member
    Austin, TX
    2016 Tacoma DCSB with 6MT
    Snugtop Rebel with some options Body Armor Rock Steps Rhino Mats Weathertech Mudflaps Radar detector hardwired to rear view mirror. Stereo upgrade: Amp: Arc Audio XDI805 LOC: AudioConnect LC7i Front Speakers: Hybrid Audio Technologies Claris 6.5 Rear Speakers: Hybrid Audio Technologies Mirus 5.25 Sub: Pioneer TS-SW2502S4 Box: Pioneer Ud-SW250T Bilstein 5100s OME 885 Springs Single Add-A-Leaf BFG KO2 265/75/16
    I see you're in Texas. Holler if you're ever around Austin and you can drive mine. The 3.5 with the 6 speed manual is great.
  20. Apr 14, 2018 at 8:12 AM
    Nomad_Pilot
    Clay
    Ft Collins
    I will go take a video right now
