New version Locking Gas Door
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by eAreEyeSee, Jan 18, 2014.
  1. Jan 18, 2014 at 9:44 AM
    eAreEyeSee
    eAreEyeSee [OP] Well-Known Member
    Eric
    Aurora CO
    2010 DCSB TRD Off-Road
    Blah Blah Blah. Like your FF team, nobody cares!
    I am currently out of these kits and I'm not sure when I will have more. Seems like everyone who was interested already got one so sales have slowed so I have moved on to other projects and don't really have time to put these together. I will update if I get around to making these again. Thanks to everyone for your support!!!!
    I’ve come up with a locking gas door for the 2nd gen truck. Yes, I know you can just get a locking gas cap. I had one and it worked just fine for 2 years without issue but I needed a project and I prefer this method better. This is the way it should have come from Toyota. No extra key on my key ring and no fumbling with the key while getting the cap off.
    These are semi-complete with the basics to get it working. It includes the fuse tap, spring to pop the door open, and a basic momentary button. Its just a basic button but you can find and substitute in your own flavor button or trigger method.
    $50 includes the shipping within the US using the small flat rate USPS box.
    What you need:
    -wire
    -a few random wire connectors of your choice like butt connectors or crimp caps
    -zip ties
    -maybe wire loom if you desire but not required
    Here is the write up I did for the install.
    http://www.tacomaworld.com/forum/2nd...-gas-door.html
    https://youtu.be/13MmGxyH1_0
  2. Jan 18, 2014 at 11:28 AM
    rubenc87
    rubenc87 Cobra
    Texas
    2025 Tacoma TRD PRO
    The items in the third pic is te factory gear that will be replaced by your kit. Seems like it would work well. Only think May be the price point.
    ChadsPride likes this.
  3. Jan 18, 2014 at 11:56 AM
    eAreEyeSee
    Eric
    Aurora CO
    Yes on the replacement parts and I thought about the price too. It was just a starting point but I'll prolly change it to $70. Any less than that is not really worth my time in labor to modify the latches and the machine time for the catches and brackets.
  4. Jan 18, 2014 at 12:17 PM
    Grimjack
    Grimjack Active Member
    Sugar Hill, GA
    14 MGM Dbl Cab LB 4x4 TRD Sport
    If you do build some of the kits I would be interested.
  5. Jan 18, 2014 at 12:26 PM
    617mike9c1
    617mike9c1 Well-Known Member
    Newton, MA
    2008 DCLB Sport 4wd
    A little of this and a little of that
    I'm in for one too.
  6. Jan 18, 2014 at 12:29 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    pretty nifty... good work OP
  7. Jan 18, 2014 at 12:43 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Just curious... concidering the price difference what was so bad about the locking gas cap? :confused:
  8. Jan 18, 2014 at 3:05 PM
    S13chris
    S13chris Well-Known Member
    Jacksonville nc
    07 dbl cab 4x4
    Tail gate mod, debadged, and weather techs, satoshi grill, diff breather mod, Duratracs 265/70/17, snugtop shell w/ rack, sleeping platform for bed, LED's for interior lights/Reverse lights/license plate, BHLM & DTRL Mod.
    I would buy one
  9. Jan 18, 2014 at 3:21 PM
    SpeedoJosh
    SpeedoJosh Well-Known Member
    Florida
    2010 Access cab, Base, 4x4
    Is it really that loud? Sounds like a sledge hammer
  10. Jan 18, 2014 at 4:40 PM
    eAreEyeSee
    Eric
    Aurora CO
    Nothing is wrong with the locking cap. I used one for a long time. The price isn't for everyone just like the $98 price for the Pop-n-Lock tailgate unit which is basically the same thing but I liked it so I bought it.
    cnote4l likes this.
  11. Jan 18, 2014 at 4:42 PM
    eAreEyeSee
    Eric
    Aurora CO
    Ha. Yeah it's a bit loud in the video. I also have the tailgate lock unit so the sound from that bouncing off off the back of the garage at the same time may be contributing to that.
  12. Jan 18, 2014 at 6:17 PM
    rubenc87
    rubenc87 Cobra
    Texas
    2025 Tacoma TRD PRO
    $70 definitely sounds better.
  13. Jan 18, 2014 at 6:21 PM
    gman2530
    gman2530 Well-Known Member
    San Diego, Ca.
    04 PreRunner
    For Gen 1s??????
  14. Jan 18, 2014 at 6:45 PM
    Jstrumpf
    Jstrumpf Well-Known Member
    Long Island NY
    08-AccessCab-4X4-6in Lift-Rockstars
    Pro-comp 6 in lift Rockstars 35in Nittos Roll Up bed cover Ipod Hookup
    i would be in if you built some kits
  15. Jan 18, 2014 at 7:02 PM
    TRDKAZI
    TRDKAZI Well-Known Member
    Earth
    I'd buy one
  16. Jan 18, 2014 at 7:10 PM
    rubenc87
    rubenc87 Cobra
    Texas
    2025 Tacoma TRD PRO
    I believe the hardware behind the door on the 1st gen would be different from the 2 gen.
  17. Jan 18, 2014 at 7:54 PM
    eAreEyeSee
    Eric
    Aurora CO
    Thanks for the interest. I will get on these and let you know when there're ready.
    I don't know if they will work on 1st gen. I only had a 09 and 10 to test on.
  18. Jan 18, 2014 at 8:04 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
  19. Jan 18, 2014 at 8:34 PM
    eAreEyeSee
    Eric
    Aurora CO
  20. Jan 19, 2014 at 5:53 AM
    Yaozer
    Yaozer Well-Known Member
    North Jersey
    2011 Red DCSB TRD Sport
    Flowmaster exhaust, 3" Old Man Emu lift, Konig Countersteer Rims, and too much more.
    Interested. Nice work, OP.
