New version Locking Gas Door
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by eAreEyeSee, Jan 18, 2014.
  1. Mar 10, 2014 at 10:16 AM
    #101
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Just ran across this thread. Very nice. But to offer a bit of advice, think about changing your market stratagy. It is nearly impossible to syphon gas from our Toyota trucks, even the first gens. Think about adding to your sales pitch that this feature would be better to keep someone from putting something besides gasoline into your tank. Maybe you did meantion it and I missed it.
    The gadget head in me loves this, but I would have no use because I know gas can't be removed by syphoning. Thieves are more likely to drill your tank and drain the gas into a wide pan.
    Again, cool feature.
    Later
    KO
  2. Mar 10, 2014 at 6:35 PM
    #102
    griffin407c
    griffin407c Well-Known Member
    Upstate NY
    '12 DCLB MGM 4x4 Sport w/Entune
    OME 885s on Bilstein 5100s set at 0 with 1/2" plate spacers. OME Dakars with Bilstein 5100 Extended Length Shocks. 16" Pro Comp 7032 wheels wrapped with 285/75-16 Duratracs
    Definitely thinking about one of these. Nice work
  3. Mar 11, 2014 at 1:35 PM
    #103
    eAreEyeSee
    eAreEyeSee [OP] Well-Known Member
    Eric
    Aurora CO
    2010 DCSB TRD Off-Road
    Blah Blah Blah. Like your FF team, nobody cares!
    Thanks. Let me know when you want one.
  4. Mar 11, 2014 at 11:15 PM
    #104
    Sbasser
    Sbasser Active Member
    Renton Washington
    TRD Off Road 4x4
    Trailer pkg. 6 spd.
    For what it's worth, the little anti-siphon flapper in the gas filler neck was one of the few things that has broken without provocation...and it's the best thing to happen to it! If you can figure out how to break that little sucker off, do it asap. This "mod" lets me fill the tank about 50% faster and get in about 20% more gas before it starts barfing gas all over.
    The clamp on the stainless exhaust tip also (broke?) fell off, but a muffler clamp from the local auto parts store fixed that way better than the stock part. I think it is a 2.5" clamp, but could be wrong. It was a long time ago. I probably double nutted both ends of the U-bolt. Maybe Loc-Tite and elastic lock nuts, too. It's how I roll...
    The only things that really have annoyed me are the outside thermometer in the mirror quit ($280?) and I've had to replace 2 or 3 of the mud flaps... both front and rear ones. One must be careful with those, as they are too brittle and far too close to $100. :tumbleweed:
  5. Mar 11, 2014 at 11:39 PM
    #105
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    :confused::confused:
    If you're pushing in 20% more gas, you're going to be flooding your charcoal canister. $300+ to replace it when you get a CEL.
  6. Mar 14, 2014 at 6:39 AM
    #106
    eAreEyeSee
    Eric
    Aurora CO
  7. Mar 15, 2014 at 1:28 PM
    #107
    Sbasser
    Renton Washington
    TRD Off Road 4x4
    Trailer pkg. 6 spd.
    Never had a CEL yet, except for when the tech forgot to reset the computer after normal service, with 93k on the clock.
    The problem I had was that the filler nozzle would start clicking off with the tank less than half full and getting more gas in was painfully slow. I never used anything but the slowest setting on the nozzle, either. Maybe the filler or venting has been improved since my '06 was built? But for my '06, losing the flapper down into the tank was a big improvement. I normally let the nozzle run, shutoff automatically, and maybe round it off to the next dollar. Which isn't much, if you haven't noticed. :censored:
  8. Mar 18, 2014 at 8:08 PM
    #108
    SoulCalTaco
    SoulCalTaco New Member
    James
    SoCal
    4X4
    lifted, cold air intake
    I'll buy one... send me a link
  9. Mar 19, 2014 at 4:40 AM
    #109
    eAreEyeSee
    Eric
    Aurora CO
  10. Mar 25, 2014 at 12:02 PM
    #110
    eAreEyeSee
    Eric
    Aurora CO
  11. Mar 25, 2014 at 2:58 PM
    #111
    WisTaco
    WisTaco Bowhunter -)))----->
    Wisconsin
    Murdered 08
    TRD coi,TRD exhaust, Leer cap,WT floormats, Ironman Lift, LR UCA's, Ultra Rogue wheels, 255/75/17's. DYI mods 4x4 Illum switch & BLHM.
    Sure does look clean with the button on the inside, almost like it was suppose to be there!
    I'd be interested also
  12. Mar 28, 2014 at 4:08 PM
    #112
    Scooter
    Scooter Canadian Member
    Manitoba, Canada
    08 Double Cab TRD Sport Short Box
    Pop n Lock Power Tailgate Lock, Bak Flip Tonneau Cover, Factory DLR installed, Defrost with A/C Off, EZ Down Tailgate Damper, Code Alarm Security System with Remote Starter, Rear Spring TSB, Ming rust proofing & paint treatment, 3M fabric protector, Cargo Mat, Scanguage II, DYI Illuminated 4X4 Switch, Versa-Gate box extender & cargo divider, Toyota Roof Rails, Grom USB Audio adapter with bluetooth, LED Bed lights, OEM Backup Camera with LCD Display Mirror
    Hi Eric,
    I just received my fuel door lock today. Thanks for shipping it to Canada for me. I probably won't install it until the weather gets a bit warmer. This winter has been crazy cold here. Nice job on the lock. It looks really well built. I'll let you know how the install goes once I get around to it. By the way it looks, I think it'll work great.
    Thanks!
    Scooter
  13. Mar 28, 2014 at 5:36 PM
    #113
    eAreEyeSee
    Eric
    Aurora CO
    Good to hear. Glad you like it. Good luck with the install and let me know if you need any help.
    Eric
  14. Mar 28, 2014 at 5:53 PM
    #114
    Li0nel1234
    Li0nel1234 Well-Known Member
    Lionel
    Denver
    14 TRD OR DCSB SSM
    Hmmm....
    I want one.
  15. Mar 28, 2014 at 5:58 PM
    #115
    eyesurf2611
    eyesurf2611 Well-Known Member
    714 & 808
    09 Tacoma 4X4 DCLB & 4th Gen T4R
    *Icon Extended Travel Coilovers w/ 700lb. Coil *TC UCA *Rear Icon 2.0 w/ Resi *Rear All Pro Standards *ArmorTech Shackle Flip *All Pro Flip Kit *F&R Wheelers Bumps *All Pro Front Bumper w/ 10,500 Winch *All Pro Front Skid Plate *All Pro Trans Skid Plate *All Pro Mid Exhaust Skid *All Pro Rear Bumper w/Hitch *Rocky Road Outfitters Rock Sliders *Method Rims *Custom Bead Locks *305-70-17 Nitto Terra Grapplers *Hanneman Fiberglass Front Fenders *EBC Stage 5 Brake Kit *Bed Mounted HiLift *FrontRunner Roof Rack *50" Dual Amber/White LED Light Bar w/ Roof Rail Brackets *Custom One Off Removable Bed Rack *Satoshi Grill w/ BAMF Bar and (2) 20" LED Light Bars *Leather and Heated Seats *Full Audio/Video System
  16. Mar 30, 2014 at 5:06 PM
    #116
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
  17. Apr 7, 2014 at 9:58 AM
    #117
    eAreEyeSee
    Eric
    Aurora CO
  18. Apr 7, 2014 at 11:35 AM
    #118
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    I'll take one. Send me details please
  19. Apr 7, 2014 at 3:47 PM
    #119
    eAreEyeSee
    Eric
    Aurora CO
  20. Apr 21, 2014 at 10:40 AM
    #120
    eAreEyeSee
    Eric
    Aurora CO
