New VFtune install
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wrightme43, Jun 11, 2020.
  1. Nov 30, 2020 at 6:56 PM
    #601
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    :spy:
  2. Nov 30, 2020 at 6:58 PM
    #602
    Pnciv66
    Pnciv66 Well-Known Member
    Louisiana
    If only we knew.
    I’m still waiting for the tune pack to be available for the 2021 ecu
  3. Jan 2, 2021 at 9:11 PM
    #603
    mandog
    mandog Lesser-Known Member
    Race City, USA
    2017 4WD Off-Road Quicksand Overland
    Can someone please explain the correlation between the tuning packs (ie: stock, performance) and fuel grade?
    Do you need to run certain grade fuels after applying a tune and is it problematic if you don’t do this?
  4. Jan 2, 2021 at 9:40 PM
    #604
    G8R_Taco
    G8R_Taco Just passin thru….
    FLA
    2019 TRD OR 4x4
    The only correlation is the starting point for the ignition timing and valve timing. The tunes are octane learning using the knock sensors in the valley of the engine. Pre-detonation (knock) is very bad for an engine. But if you have to run lower grade fuel,do it, just don’t lug it in high gears.
    wrightme43[OP] likes this.
