New vs Repaired Garage
Discussion in 'Garage / Workshop' started by Hotdog, Mar 2, 2009.
Repair or replace?
  1. Repair the garage
    54.5%
  2. Replace the garage
    45.5%
  1. Mar 2, 2009 at 9:34 AM
    Hotdog
    Hotdog [OP] My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    What are your thoughts? I'm skeptical to put any money into a garage that has a bad foundation, but if I were to tear it down, I would end up having a lot of expenses. I'll post up some pictures when I get home.
    Current Garage Pros:
    1500 S.F.
    2 Stories
    Relatively Cheap to repair
    Already has gas, electric, cable, water, internet
    Current Garage Negatives:
    Some termite damage
    Some Water Rot
    Needs new roof and roof decking
    1 wall is leaning outward
    Foundation is cracked
    Garage door does not function
    1 wall needs new siding
    Exterior needs to be painted
    Washer and Dryer are in here and the garage is detached
    New Garage Pros:
    Weather/Critter Tight
    Could provide attached washer/dryer to house
    Could park a car in garage
    New Garage Cons:
    Expensive
    Much Smaller
    Demolition might kill Live Oak Tree
  2. Mar 2, 2009 at 10:08 AM
    40204ever
    40204ever Well-Known Member
    Caldwell, TX
    4x4 taco racing development
    Fix the old one. Unless you have the money and time to start over. You can repair alot for what a 1/3 of a new one would cost.
  3. Mar 2, 2009 at 10:22 AM
    WoadWunner
    WoadWunner Well-Known Member
    Peter
    Bridgetown, Nova Scotia
    17 Accesscab TRD Offroad Inferno
    Tonneau Cover, Devils Horns on the way, Blackened Grill, LED Low beams and Fogs, weathertecs
    I hate to kill good trees when I could do the fix up cheaper
  4. Mar 2, 2009 at 10:22 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Need pics, especially of the foundation damage.
    Based on the leaning wall I'd bet the the roof is sagging. Jack up the roof center beam to straighten it and the wall will likely straighten too. Add some supports and you're set.
  5. Mar 2, 2009 at 10:32 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i say go for the reapir if the foundation isnt that bad damaged. you may be able to fix the foundation pretty cheap if you look into it and the damage isnt too bad.
  6. Mar 2, 2009 at 10:59 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    First, I'll have to uncover the floor...some jerk filled up the garage with a bunch of crap. :rolleyes:
    But I'll get some pictures.
    Yes, the roof is sagging. I was thinking about jacking up the roof and then coming back in with a come-a-long to pull the leaning wall in. Then I would add in some bracing to hold the rafters together.
  7. Mar 2, 2009 at 11:01 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    be sure to wear some sort of locating beacon so they can find the body under all the rubble....
  8. Mar 2, 2009 at 11:02 AM
    eordonez
    eordonez Living vicariously through mjp2
    Ed
    Chihuahua, Mexico
    TRD Sport Dcab 4x2 Black Sand Pearl
    OEM All Weather Mats, wheel locks, Toyota Silver Tube steps.....
    You can always say all those flaws are part of the design...
  9. Mar 2, 2009 at 11:05 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    that's what I do when I start a design. :D
  10. Mar 2, 2009 at 11:07 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    I don't plan on using your help for this, so I think I might be OK.
  11. Mar 2, 2009 at 11:09 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    *....walking tward phone to cancel plane tickets....head down.....*
    Oh....:(
  12. Mar 2, 2009 at 11:11 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    well, if you already have the plane tickets...
  13. Mar 2, 2009 at 11:20 AM
    spaghettiedy
    spaghettiedy Well-Known Member
    Pittsburgh
    09 DC LB Sport in Black 4x4
    Gray Weathertechs, LG Wet Okoles, Tacome OEM Bedmat
    This would be a hard decision. First, how long are you planning on living there? If a couple years, just fix it. If 5 or more, I would build another one. You can always roll the costs into a home equity loan, or refinance your house. Rates are pretty good right now.
    It's sooooo nice to be able to park your truck inside a garage. Soooooo nice... You can work on it inside, wax it inside, f in it inside, and the list goes on and on.
  14. Mar 2, 2009 at 11:23 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    the foundation is pretty much crap. I think it is a chain wall with a floating center. The chain wall has settled about 1.5" lower than the floating center. There are cracks all over the center. The only place for the car has also settled about 1".
  15. Mar 2, 2009 at 11:26 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    All the things you said are true, but I'm very wary about digging ourselves into a deep hole to have the convenience of an attached/functional garage.
    I'm starting to think that having a garage and a separate workshop might be the way to go.
  16. Mar 2, 2009 at 11:49 AM
    spaghettiedy
    Pittsburgh
    My good buddy's parents have that setup, and it's awesome. Park in the attached garage, and party ah I mean "work on the truck" in the other garage. Good call.
  17. Mar 2, 2009 at 12:53 PM
    mjp2
    NJ
    How's the layout? Would it be easy to build a breezeway between the house and garage to at least keep you out of the rain as you walk between the two?
  18. Mar 2, 2009 at 1:00 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    I could do a breezeway, but I won't. It would be way too difficult to do on the layout.
  19. Mar 2, 2009 at 1:10 PM
    eordonez
    Ed
    Chihuahua, Mexico
    send some drawings to me, i might be able to do something for ya....
  20. Mar 2, 2009 at 1:12 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    uh oh, Ed has a lot of idle time on his hands???
