The Official Unofficial Super Pacific X1 Camper Thread
Discussion in 'Tonneau Covers, Caps and Shells' started by Synergy001, Jun 28, 2020.
  1. Feb 9, 2021 at 12:11 PM
    #2181
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    You'll probably be fine with a regular cab. If you do some hard off-roading or rock crawling with the camper, I would recommend planning for it at the same time you relocate your rear shocks. If you didn't even think about or consider this when you had the much heavier Flippac, then you'll definitely be fine.
    In my opinion, it's pretty necessary for the 1st gen double cab with a camper that has an overhang above the cab as it really emphasizes how much the frame flexes.
  2. Feb 9, 2021 at 12:13 PM
    #2182
    frenchee
    frenchee Favorite Member
    Oceanside CA Area
    2003 Tacoma TRD Double Cab 4x4
    Converted to 4WD DD VW MK6 TDI
    Good idea keeping the truck stock. I wouldnt touch much. If you want to reinforce the frame you should do a plate on the outside and not box it.
    Boxing it requires relocating shocks etc which imo if you like stock is not worth it.
  3. Feb 9, 2021 at 12:16 PM
    #2183
    justrussell
    justrussell Well-Known Member
    Russell
    Sacramento
    I’m at 7ft exactly. 33s on 3” front and 2” rear lift until I get the rear swapped to 3” next week. Not gonna fit anywhere if I try to fit 35s.
  4. Feb 9, 2021 at 1:37 PM
    #2184
    gnardoggie
    gnardoggie Well-Known Member
    I know my front lift is for sure not 3" as I'm on the 3 or 4th 6112 notch. What's your measurement from the ground to bedrail?
  5. Feb 9, 2021 at 3:36 PM
    #2185
    Synergy001
    Synergy001 [OP] IG: @pnwx.taco
    PDX
    00 ACLB -Daily, 16 DCSB -Adventure Rig
    Oh yeah Meadows and Hood River will more than likely get snow. You said Portland lol!
  6. Feb 9, 2021 at 3:37 PM
    #2186
    gnardoggie
    yea but I have to get my camper in portland first :)
  7. Feb 9, 2021 at 3:41 PM
    #2187
    Synergy001
    PDX
    Where are you coming from?
  8. Feb 9, 2021 at 3:46 PM
    #2188
    Coop68
    Coop68 Well-Known Member
    Coop
    Erie/Dacono, CO
    2014 TRD OR Magnetic Gray
    Method double standards 16" COOPER S/T MAXX 285/75/16 DEI clifford 2-way remote start with smart-start. Lift Kings with Dakar TC UCA extended brake lines Keyless POP-N-Lock tailgate lock,relentless tailgate reinforcement, Weather Tech Mats all around, pelfreybilt front bumper steel with middle hoop warn VR-8000s switch Pro lights coming soon see build thread
    brings up a good question if anyone is local?
    Any issues i should know coming from west i was planning on taking hwy 84 into Portland?
    realize this passes through the areas you mentioned
  9. Feb 9, 2021 at 3:48 PM
    #2189
    RangeRick
    RangeRick Well-Known Member
    Rick
    1996 Tacoma Standard Cab SX (Early TRD Off Road, manual 5 speed, V6, factory locking diff)
    Thanks. As long as we're talking, my friend put the below OME kit on his 1st Gen extra cab when he got his Vagabond Drifter. One of my rear leafs is dead so I'm considering 1) just replacing the leafs, or 2) going with this kit... or I guess 3) I don't know. Any advice? Like I say I mostly run stock, my regular cab has Bilstein's that are still in pretty good shape. As to off roading, I like to find long dirt roads leading into wilderness areas, occasionally these are very rough and I will bottom out once in a while if I go too fast... but no major off roading or rock crawling.) Leaf pack or full OME kit?
  10. Feb 9, 2021 at 3:56 PM
    #2190
    Synergy001
    PDX
    Usually when we have snowstorms 84 shuts down a lot. I’d pay attention to any road reports. You can also check www.tripcheck.com for live feeds around OR. There’s a lot of traffic cams set up in our state.
  11. Feb 9, 2021 at 4:16 PM
    #2191
    ShelaneyMTB
    ShelaneyMTB Member
    Sheila
    2020 Metallic Grey Tacoma TRD Sport
    none, yet!
    Pay close attention to what the weather will be doing near La Grande on 84, that pass is an area that will close pretty often when it snows and was something I had to keep an eye on when I was recently moving out here from Utah.
    ready6delta, whup and Coop68[QUOTED] like this.
  12. Feb 9, 2021 at 4:24 PM
    #2192
    frenchee
    Oceanside CA Area
    I ran that kit (for 03taco) about 35k miles. It was great for the $. My pack started getting "tired" at a certain point so I inserted the EMU ad a leaf. It still sags a little in the back, and I'm afraid I will have to go for a more robust pack, like Deaver from what I hear.
    I have a shell, RTT and wooden drawers so quite some weight. I'm not really confident in leaf spring knowledge to advise. I can just say that the leafs will last a while and get saggy at some point. Not sure if that is true for all leafs, or if you're better off buying a different pack that will last longer. That kit is "cheap" for what you get so maybe thats a good start.
  13. Feb 9, 2021 at 5:53 PM
    #2193
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Dakars will do the trick and hold the weight 5-700 depending on they add a leaf or not. Now I think it's medium-duty and heavy-duty. For regular work it will do the trick. The Icon RXT is better or Deaver which i would choose over those. it more but you pay for what you get. They have different heights too. Id you call them they be able to make a pack that fits your needs exactly. light lift but heavy action. I cant wait to get rid of my Dakars and will get a Deaver pack custom setup for the truck. I put it off so I can get an accurate weight with the X1.
    socalexpeditions and d.shaw like this.
  14. Feb 9, 2021 at 6:07 PM
    #2194
    frenchee
    Oceanside CA Area
    My question:
    What is the root cause for my dakkar pack sagging.
    1. Am I operating outside of its load range (too much weight)?
    2. Does the spring simply start to flatten overtime from fatigue even within the recommended load range?
    If #2 is the reason how do I ensure the next pack can last longer?
    My guess is I was on the high side of the load range for the Dakkar pack, and it slowly wore it out. Thing is if you get stiff springs, you get a shitty ride.
    I think my drawers were the straw on the camels back for the Dakkar lol
  15. Feb 9, 2021 at 6:13 PM
    #2195
    itsZEUStime
    itsZEUStime Active Member
    Paul
    2019 Tundra SR5
    Any opinions or experience with running decked drawers in conjunction with the SP? I would be interested in the residual clearance to the underside of the tent platform. I have a 2019 Tundra so not sure what to expect with head room with or without the decked system.
    This was my original idea for the buildout, but then I was seduced over to the 80/20 custom build, but now reconsidering the decked due to simplicity and getting that flat surface for easy kid sleeping.
    frenchee likes this.
  16. Feb 9, 2021 at 6:15 PM
    #2196
    justrussell
    Russell
    Sacramento
    34” - 34 1/2”
  17. Feb 9, 2021 at 6:20 PM
    #2197
    frenchee
    Oceanside CA Area
    I have similar dilema. Spent a lot of time building my drawers and I love them, but the 80/20 set up makes more sense for this...
    itsZEUStime[QUOTED] likes this.
  18. Feb 9, 2021 at 6:39 PM
    #2198
    JasonLee
    15 TRD OffRoad
    The OME Dakar leaf springs with add-a-leaf and the OME greasable shackles worked out well for me on my 2003 DCSB with the Drifter. I had "no" build" though and ran lightweight for over a year and saw no sagging. I would guess that if you have a mild interior, fridge, any batteries, water, etc constantly in the bed, then you're probably at or exceeding the Dakars causing them to wear out.
  19. Feb 9, 2021 at 7:03 PM
    #2199
    itsZEUStime
    Paul
    2019 Tundra SR5
    I agree, getting back a portion of the full bed height is a big deal especially in use cases where you might be standing up in there to cook or change or whatever. I’m just not sure with a family of four where we would truly use it in that fashion.
  20. Feb 9, 2021 at 7:12 PM
    #2200
    frenchee
    Oceanside CA Area
    Family of 4, thats ambitious!
