New wheel and tire purchase
Discussion in 'Wheels & Tires' started by southerntaco171, Jul 11, 2011.
  1. Jul 11, 2011 at 8:19 PM
    southerntaco171
    southerntaco171 [OP] Well-Known Member
    Ocean Springs, MS
    2017 TRDOR
    2013 regular cab 4x4 Bilsteins Spc uca Eibach coils 285/75/r16 Projector retro 5500k hids 2017 TRDOR DC Weathertech Floor mats 5500k Morimotto Headlights and Fog lights 5% Tint 2008 Toyota Tacoma(SOLD) 8k Hid Headlights and fog lights, BHLM, 6" Pro Comp basic, 2.5" top spacer, Allpro front bumper, Jvc KVX10 double din, 2 crossfire bmf 12's, Memphis 6x9s, cherry bomb exhaust, K&N drop in intake,
    I currently have 17x9 helo maxx 6's in black with 265/70/r17 with a leveling kit on my 08 Taco. Im looking to buy 20x12 fuel octane black rims(-44 offset and 87.1 hub bore) and 305/50/r20 nitto grapplers. Im not stressing about lifting a little bit more if the need be, but im curious to what yall think about this idea. Good idea? Bad?
  2. Jul 12, 2011 at 5:57 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Other than the hub bore being too small (you need at least 106mm), the wheels being way too wide (305/50/20's are only approved for 8.5" to 11" rims), and the backspacing/width combination making the rims stick out almost 6 inches further than stock :eek: (tons of rubbing), it looks like a great idea.
    I also couldn't find where any of nittos truck tires (5 different models, all of which are called "grapplers" btw) even come in 305/50/20. All I see is 305/55/20.
  3. Jul 12, 2011 at 6:17 AM
    KPT
    09 Prerunner
    I'll save you some more research and just tell you that even with a "leveling kit" (which you did not note the size of so I'll assume it's 3"), If you got 20x9's with -12 mm offset, you'd be pushing it with a 12" tire. You will have to trim a bunch of fender well plastic, and chop and re-box your cab mounts, and then still might rub.
    You would even still need to trim if you went with a 285/55/20.
  4. Jul 12, 2011 at 10:48 AM
    southerntaco171
    Ocean Springs, MS
    2017 TRDOR
    I have a 2.5 inch spacer already so I was contemplating putting some 5100's on. The tires are terra grapplers I found on Amazon 32x12r20. After I sold my rims and tires I have now I was gonna throw on some fiberglass fenders and do the cab chop.
  5. Jul 12, 2011 at 11:22 AM
    KPT
    09 Prerunner
    Just making sure you know that you can't use the 5100's without ditching the spacer first. That would be stacking lifts. I still wouldn't recommend the 12" wide rim. I bet even with glass you wouldn't be able to turn. Not to mention the tire isn't designed for it.
  6. Jul 12, 2011 at 11:37 AM
    prae
    prae Well-Known Member
    Calgary, AB
    06 4x4 SR5 BSP DCLB
    Bilstein 5100s, eibach springs, AAL, TRD anthracite FJC rims, PIAA Fogs, Pace-Edwards hard rolling tonneau
    don't combine a spacer lift with 5100s. It'll be uncomfortable, and more importantly, unsafe.
  7. Jul 12, 2011 at 11:44 AM
    southerntaco171
    Ocean Springs, MS
    2017 TRDOR
    From my understanding I thought I could as long as I didn't exceed the down travel length of the stock suspension?
  8. Jul 12, 2011 at 11:47 AM
    KPT
    09 Prerunner
    Where did you see that you could do that?
    You will have little to no down travel left, and if you go over a bump the shocks will top out and could break. Also preloading the stock springs to basically twice what the spacer did is going to give you a terrible ride. Thirdly, most people at 3" of total lift new uca's to get the alignment in spec. With the setup you are talking about, i don't even think it would be possible to align your truck.
  9. Jul 12, 2011 at 12:00 PM
    southerntaco171
    Ocean Springs, MS
    2017 TRDOR
    I thought it may have been on here but I suppose not. I just don't want to have to but a new lift kit to gain a half inch in the front. I suppose ill also go with the ten inch wide rim since you talked me into it ha.
  10. Jul 12, 2011 at 12:59 PM
    KPT
    09 Prerunner
    For the lift, what I would do is get the 5100's, set them at 2.5", and buy a 1/2" top plate spacer for like $20 to get it up to a full 3".
    I was trying to talk you into the 9". With every inch of wheel width you add (for a given backspacing), you pull the tire out 1/2", and it might be close to rubbing on the outer edge when you turn. The 10 may work thought I'm just not sure.
  11. Jul 12, 2011 at 4:15 PM
    southerntaco171
    Ocean Springs, MS
    2017 TRDOR
    I really like the look of the ten inch and but i definately like the idea of the 5100's versus a full 3 inch spacer. Youve been alot of help man i appreciate it greatly.
  12. Jul 12, 2011 at 4:41 PM
    KPT
    09 Prerunner
    Not a problem let me know if you have any other questions.
  13. Aug 2, 2011 at 1:34 PM
    Raddbus
    Raddbus Well-Known Member
    Russell
    Santa Maria
    TRUE BLU TACO
    Illuminated 4X4 switch, 3" lift,
    have you sold your Helo Maxx rims yet?
  14. Aug 2, 2011 at 1:43 PM
    southerntaco171
    Ocean Springs, MS
    2017 TRDOR
    Decided to keep them. Going 6" and 35's just waiting on the lift to come in.
  15. Aug 2, 2011 at 10:54 PM
    Raddbus
    Russell
    Santa Maria
    TRUE BLU TACO
    :frusty::annoyed:, good chose, I love these rims and can't wait till I get one for my truck, I think I'm going to go with 16s, cheaper tires.
