New wheel and TPMS question
Discussion in 'Wheels & Tires' started by JimmyRiddle, May 5, 2013.
  1. May 5, 2013 at 2:43 PM
    JimmyRiddle
    JimmyRiddle [OP] Member
    NorCal
    Tacoma regular cab Maual
    I just purchased a new Toyota Tacoma base model and am considering changing out the ugly OEM wheels (15 X 6). to black wheels. Are the TPMS transferable to the new wheels? I'm a bit of a noob at this. Any suggestions on 15 X 6 black wheels. I like the XD Series Enduro but they only come in 15 X 7. Thanks in advance.
    Edit: Just noticed on Tirerack.com that steel wheel TPMS cannot be transferred to alloy wheels. :(
  2. May 5, 2013 at 6:15 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Matte Black custom paint
    You can reuse your sensors if you use a strap kit like this:
    Talk to the tire shop first and check if the carry it.
  3. May 5, 2013 at 6:48 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Strap is the easiest/cheap/safe way to do it.
    Cheapest way, rotate the sensors 180 and they will most likely work with the alloys, BUT, in the future, make sure any tire installer is aware of it or they will break your sensors when they remove your old tires.
    On your new truck, I'd go with the strap and standard stems.
    My truck is an '08, so the batteries are likely not long for the world. Better option there is to simply buy a new set from Rockauto.
  4. May 6, 2013 at 6:34 PM
    JdMeF9SiR2
    JdMeF9SiR2 PARTS HOARDER
    Riverside CA
    06 Tacoma
    I recommend against the strap and against turning the sensors, because it's too easy to forget to remind the next tire shop that your sensors aren't installed in the original location (using resulting in the sensors being broken when your tire is removed - at no fault of the tire shop).
    I just posted some information here:
    http://www.tacomaworld.com/forum/wh.../96679-17x8-konig-countersteer-type-x-37.html
    for someone who asking about going from steel to alloy wheels. :)
