New wheel questions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by sivillian, Sep 23, 2018.
  1. Sep 23, 2018 at 11:15 AM
    sivillian
    sivillian [OP] Member
    2018 Tacoma off road
    Exhaust and intake.
    im about to get a pair of new method race wheels no 305’s, and when ordering there is an option to purchase them with the tire pressure monitor sensors. My 2018 Tacoma already has those built in, my question is if I get new wheels do I have to get new ones or will it use the tpms that are already there?
  2. Sep 23, 2018 at 11:29 AM
    modifiedtaco
    modifiedtaco Well-Known Member
    Alex
    2016 Magnetic Gray Tacoma Limited
    Tuff Country 3 inch spacer kit with aal Tuff Counrty 1/4" spacer on LF (for taco lean) Bilstein 5160 rear shocks Bilstein 5100 adj front struts (removed tuff country front spacers) set to 0 lift OME 886 coil springs Front sway bar relocation bracket N-Fab Rock Rails 17x9 -12 Fuel Beast wheels Toyo AT2 285/70/17 tires Led light conversion on all interior lights Morimoto 35w HID kit 5500k OE all weather floor mats OE Tonneau cover OE Door Sill Protectors Bed Mat De badged all factory emblems matte black vinyl tailgate letter and Tacoma emblem on door silver vinyl insert on glove box and door sill protectors OME Carrier Bearing Drop Insain Fab cab mount chop plates Weathtech Rain guards
    you have to swap the sensors out of the factory wheels.. If you plan on running both sets one for winter use you'll need another set of sensors if you don't want to be swapping back and forth every season.. or just don't swap them but then your tpms light will be on all the time..
  3. Sep 23, 2018 at 11:34 AM
    sivillian
    Exhaust and intake.
    Awesome thanks. Is that something a shop can do if they’re installing the new ones?
  4. Sep 23, 2018 at 11:39 AM
    modifiedtaco
    Alex
    swap them? yes they can. I work at a tire shop and we will swap them for free when wheels are purchased thru us.. if everything is carried in then you may get charged a bit extra since you'll have to break down the stock tires to pull the sensors out. some shops may also want to rebuild the sensors to prevent leaks.. rebuild consists of new grommet an a new nut to tighten sensor on wheel
  5. Sep 23, 2018 at 11:49 AM
    sivillian
    Exhaust and intake.
    Ok great. With new wheels there’s an option to buy new ones at $40 per wheel, in your professional opinion do you think the charge to swap them would be more than $160?
  6. Sep 23, 2018 at 11:52 AM
    modifiedtaco
    Alex
    it shouldn't be, I cant imagine anyone would charge more than $8-$10 a wheel. you don't even have to dismount the tires just pull the air and break down the top bead. with the proper machines you can do this and hold the bead of the tire down while you pull the sensor out
  7. Sep 23, 2018 at 11:57 AM
    sivillian
    Exhaust and intake.
    Sounds good. Thank you so much for your insight.
  8. Sep 23, 2018 at 12:25 PM
    modifiedtaco
    Alex
    no problem
