New Wheels 17 x 9, what size of tires i should get?
Discussion in 'Wheels & Tires' started by wing103, Aug 12, 2011.
  1. Aug 12, 2011 at 3:34 PM
    wing103
    wing103 [OP] Well-Known Member
    Boston
    Tacoma TRD Sport / Dark Gray
    Grill Craft upper & Lower Grill WetOK Seat Cover, Devil Horn, Bug, Windows Deflector, Side step Bar, HID 55W 8000K Headlight, HID 35W 4000K Foglight, Fog Light Mod, Interior LED Map Light Mod, Electric Tail Gate Lock, Leer Cab, Key ring light, Bed LED lights Mod, Kenwood DNX5120, Signal Mirror with Heat
    Hi
    I just get a 17 x 9 with 12" off set wheels, what size of tires i should get? and what brand name is good on highway driving?
    Please help me out.
    thanks
  2. Aug 12, 2011 at 3:42 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    If your stock and wanna stay stock 265/65/17 slightly larger would be 265/70/17.
    As far as a tire go to wheelworks/goodyear/sears/discount tires and ask them what they recommend anything will be fine for your application.
  3. Aug 12, 2011 at 3:54 PM
    wing103
    Boston
    Tacoma double cab 2009 with OEM wheels on it, have not do the lift kit yet.
    I hope this is what you looking for. Thanks a lot.
  4. Aug 12, 2011 at 4:26 PM
    wing103
    Boston
    Thanks.
    Did you guys geard a brand name Masteraft AT2? are they good?
  5. Aug 12, 2011 at 4:28 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    They are owned by Cooper Tires. My buddy has a set on his cummins and says they are "alright he guesses"
    Also check to make sure on the manufacturers website that the 265s are approved for use on 9" wide rims.
  6. Aug 12, 2011 at 4:30 PM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    They're not bad, as KPT said, they're a Cooper brand. Where are you getting the tires? Townfair Tire price matches so you can find the cheapest, down and dirty price you can and they'll match it!
  7. Aug 12, 2011 at 4:58 PM
    wing103
    Boston
    So if i looking for the tires, am I have to look for 265s/70/R17
    Am I right?
  8. Aug 12, 2011 at 4:58 PM
    wing103
    Boston
    Thanks for the info.
  9. Aug 12, 2011 at 5:00 PM
    Pugga
    Massachusetts
    Depends, if you want a little lift, go with 265/70R17. They're about 1" taller than stock tires so the truck will sit 1/2" taller. Stock size for the 17" rim is 265/65R17.
