New wheels and tires w/pics
Discussion in 'Wheels & Tires' started by TRD Toy85, Dec 8, 2013.
  1. Dec 8, 2013 at 5:28 PM
    TRD Toy85
    TRD Toy85 [OP] Well-Known Member
    CT
    loaded 2013 TRD sport
    My new setup
    -Wheels are gunmetal level 8 MK6 17x8 0 offset
    -tires are Hankook dynapro atm 265/70/17
    Really happy with the look, though I wonder how slightly taller 255/75/17 would have looked.
    pics
  2. Dec 10, 2013 at 5:42 AM
    nextfriday
    nextfriday Well-Known Member
    Indianapolis, IN
    13 SR5 Double Cab
    5100s@2.5", 2" aal Leer 100 XR w/ Yakima rails and towers 18x9 Pro Comp Rockwells Cooper Discoverer AT3 275 65 18
    Pat yourself on the back. You won't be sacrificing ride quality or mpg with this set up. Proportionally, this is the same size tire found on the oem off road wheels. Only you're a 17" wheel.
  3. Dec 10, 2013 at 7:06 PM
    W00ds3oo
    W00ds3oo Well-Known Member
    Northern California
    16 TRD sport
    Looking to do a similar setup, looks good. Do you think a 285/70/17 would have fit or no?
  4. Dec 10, 2013 at 7:08 PM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    No
  5. Dec 10, 2013 at 7:28 PM
    W00ds3oo
    Northern California
    16 TRD sport
    but a 255/75/17 will right?
  6. Dec 10, 2013 at 7:39 PM
    Fightnfire
    Marysville, WA
    I believe so yes, but I would do some searching first.
  7. Dec 11, 2013 at 4:23 AM
    TRD Toy85
    CT
    You'll most likely have to remove the mudflaps,
    Also depends on your wheel offset . Keep in mind certain tire brands run alittle larger then others .
    But they should fit , do some more research to make sure don't just take my word
  8. Dec 11, 2013 at 4:38 AM
    specialized7
    specialized7 Well-Known Member
    ,Saskatoon, Canada
    05 v6 4x4
    are those stock size?
    they dont really look any bigger?
  9. Dec 11, 2013 at 5:35 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    No, it's not. The 17" stock size is 265/65R17 and they are the same overall diameter as the Off Road 265/70R16 tires. 265/70R17 is 1" taller than stock sized tires.
  10. Dec 11, 2013 at 1:12 PM
    TRD Toy85
    CT
    Yup just about 1" taller , it's honestly the perfect size for my mild lift .
  11. Dec 11, 2013 at 1:48 PM
    Rnhrtfan
    Rnhrtfan Well-Known Member
    WV
    06 Super White DCSB TRD Sport
    TRD I notice you say with your mild lift?? would they fit with no lift at all?? My truck is stock, with no plans to lift at all and I am torn between the 255/70 or the 265/70 but I do not want ANY rub at all... My last truck I went the largest that would fit (I thought) and they rubbed at full lock.... don't want that on this one but want to fill at the wells... Thanks
  12. Dec 11, 2013 at 2:43 PM
    Fightnfire
    Marysville, WA
    My 265/70-17 rub in reverse at full lock, slightly. I have billies at 1.75" in the front and the TSB rear.
  13. Dec 12, 2013 at 6:34 AM
    TRD Toy85
    CT
    With no lift your going to be cutting it close . I'd check so other threads I can't give you a sure answer .
