new wheels and tires what do u guys do?
Discussion in 'Wheels & Tires' started by RDAY, Jul 19, 2009.
  1. Jul 19, 2009 at 9:15 AM
    RDAY
    RDAY [OP] Well-Known Member
    NY
    07 Tacoma SR5 4x4
    i just went from 265 65 17 to 285 70 17 do u guys buy an extra tire for a spare? cause u cant use a 265 65 17 at all right if u get a flat? and will a 285 70 17 fir under my truck in the holder?
    Thanks Guys
  2. Jul 19, 2009 at 10:14 AM
    Canadianboy
    Canadianboy Taco love in East Van
    James
    Vancouver, BC
    09 TRD Sport S/B 4x4 Auto in Mag Grey
    Icon Stage 3, Goodyear Duratracs and KMC Addicts!
    I think you can, just not for a long distance. Hey post up pics of your new setup man!
  3. Jul 19, 2009 at 11:00 AM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    You can't use it in the rear if you have an LSD rear end. When I moved up to 265/75-16 I left the spare alone for a good 6 months. However, the correct size is on it's way to me right now.
  4. Jul 19, 2009 at 11:09 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    yeah, you could use a smaller spare to limp you a few miles....... as long as you dont use it on the rear end if you have a Limited Slip diff. If you dont have a limited slip, then it should be ok I think.
  5. Jul 19, 2009 at 11:12 AM
    RDAY
    NY
    07 Tacoma SR5 4x4
    i will post pics when i get the truck back its getting aligned 2moro how do i know if i have a limited slip diff? i have a 2nd gen. sport
  6. Jul 19, 2009 at 11:17 AM
    RelentlessFab
    Eric
    Sparks, NV
    to my knowledge, all the TRD sports come with a LSD in the rear end. In which case, you'd want to get a matching sized spare for the truck. you can double check whether there is a LSD by looking under the rear of the truck at the diff- there should be a sticker that reads 'LSD fluid only', or something similar.
  7. Jul 19, 2009 at 11:39 AM
    RDAY
    NY
    07 Tacoma SR5 4x4
    yea i could always try to find a used tire in my size just to get me home
  8. Jul 19, 2009 at 2:02 PM
    johnecon2001
    Phoenix, AZ
    Eh, used tires. Check it carefully to make sure it isn't cracked from age.
  9. Jul 19, 2009 at 2:14 PM
    RelentlessFab
    Eric
    Sparks, NV
    you can also look at the DOM of the used tires, its something that gets molded into every tire. It can be found near the bead on one side of the tire, it will be some numbers like '2705' meaning the tire was manufactured in the 27th week of '05.
  10. Jul 20, 2009 at 12:40 PM
    Notty
    Notty Well-Known Member
    5Twenty
    2017 DCSB TRD OR
    Bilstein 5100s OME887 Deaver AAL BAMF CMC ECGS Bearing Replacement Sprint Booster
    What is the reason for this? I have heard this many times but never got an explanation as to why! Thanks!
  11. Jul 20, 2009 at 1:25 PM
    johnecon2001
    Phoenix, AZ
    One wheel rotates slower than the other causing the LSD to lock.
  12. Jul 20, 2009 at 4:45 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    if u get a flat and have a smaller spare w/ an LSD in the rear, swap tires to where the smaller tire is on the front and the matching sizes are on the rear...problem solved. it would be better to get a tire that has the same diameter, not necessarily the same width as well. if u run 285/75/16, u could get a 255/85/16 that would be the same height, but smaller width. u can use that to find a possible cheaper tire for the spare
