New wheels don't fit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dal3_gribble, May 2, 2019.
  1. May 2, 2019 at 6:15 PM
    Superhulk LB
    Superhulk LB Well-Known Member
    Josh
    Oregon
    2019 superwhite DCLB off road
    Tonneau cover, Black exhaust tip, blacked out badges and tailgate lettering. Black rhino(glamis)18x9 wheels with +12 offset. LT265/70/18 Toyo Opencountry ATIII. Metaltech 4x4 rock sliders Cali Raised lower grill light bar/mounts TRD Pro Skid, DD Fogs(pro), Ironman 4x4 FC pro lift.
    Not a pro, but I did install 100s of wheels when I was younger. Might be worth trying both sides and making sure they’re fully torqued down.
    Your call though. May not help a bit.
  2. May 2, 2019 at 6:17 PM
    dal3_gribble
    dal3_gribble [OP] Well-Known Member
    Crew Cab SB TRD Offroad
    Hmmmm, ya I didn't fully torque them to see if it flattened out and or cleared. Suffice to say it would definitely be super close. I remember in my tuner days when I ran BBKs on everything that there seemed to be some rule about minimum safe clearance between the rotor and wheel for runout and stuff. I feel like it was a few mm.
  3. May 2, 2019 at 6:54 PM
    Superhulk LB
    Josh
    Oregon
    Well good luck with the spacers. Seems like that should work.
  4. May 2, 2019 at 8:57 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    They seemed to overlook this important factor with their wheel specs.
    X-factor
    Caliper Clearance (X-factor): The amount of clearance built into the wheel to allow for the vehicle's disc brake and caliper assembly.
    tlp.wc and BVita like this.
  5. May 2, 2019 at 9:01 PM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    It’s ROTA.. what’d Ya expect?
  6. May 2, 2019 at 9:03 PM
    NYCTaco52
    NYCTaco52 Half man, half goat
    Somehow known as Stewart, but named Ben
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Or removing the brakes completely? :anonymous::thumbsup:
  7. May 2, 2019 at 11:51 PM
    blackohio
    blackohio Well-Known Member
    Cliche Guevara
    white mudflap
    in this case offset has zero to do with rubbing. that wheel could be -50 or +70 and he’d still hit the brakes. the wheel doesn’t have a tall enough backpad or the spoke design doesn’t have enough rise to step away.
    i wouldn’t run a non bolt on spacer on our shit studs. if anything grab a spidertrax spacer. but honestly that’s kinda a shit offset to go 31mm negative.
    BVita and Superhulk LB like this.
  8. May 3, 2019 at 5:21 AM
    dal3_gribble
    I agree. BORA has a .75" bolt on hubcentric spacer. It will only push the wheel out .5".
  9. May 3, 2019 at 6:24 AM
    Aldo98229
    Aldo98229 Well-Known Member
    Aldo
    Bellingham, Washington
    2019 Tacoma TRD Off-Road
    Pity. Those are good looking wheels.
  10. May 3, 2019 at 7:44 AM
    blackohio
    Cliche Guevara
    white mudflap
    will 3/4" clear the factory studs though?
    Honestly, dont fight making those wheels fit. Whoever sold them to you, shouldnt charge you re-stocking or shipping since, they don't fucking fit. If they have a version with a taller backpad go with those. But really, rota isnt exactly known for their expertise
    auskip07 likes this.
  11. May 3, 2019 at 7:53 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    couldn't you just return them and get the -5 version instead of buying spacers>
  12. May 3, 2019 at 7:58 AM
    Puck
    Puck Well-Known Member
    South Florida
    Black SR5 DCSB
    Mount them backward and you’ll have one hell of an offset. All the Bros will be jealous
    On a serious note, aren’t the spacers more expensive and worse quality.... why not just pony up the restocking fee and end up with a better setup and probably the same if not cheaper cost?
  13. May 3, 2019 at 7:59 AM
    MESO
    State of Jefferson
    And this is how Hawaii style was born..
  14. May 3, 2019 at 8:01 AM
    blackohio
    Cliche Guevara
    white mudflap
    again.
    offset wont solve the problem with their wheel design (unless the offset change is simply additional backpad height, but thats a new mold and theres literally no point in making a new mold without moving the center for an offset change). He needs a wheel with a different backpad height.
    SC4333, dal3_gribble[OP] and BVita like this.
  15. May 3, 2019 at 9:12 AM
    #35
    tlp.wc
    tlp.wc WC Member
    California
    2018 DCLB SR5 SW
    Because reps....
    blackohio and BVita like this.
  16. May 3, 2019 at 9:20 AM
    #36
    Ez2Tan
    Ez2Tan Well-Known Member
    2017 Quicksand Tacoma OR
    BVita and MESO[QUOTED] like this.
  17. May 3, 2019 at 10:27 AM
    #37
    dal3_gribble
    The rotas have cutouts between the lugs for the studs to poke through. So the .75" is fine.
  18. May 3, 2019 at 10:31 AM
    #38
    dal3_gribble
    Restocking and shipping is about $250. BORA (well respected hubcentric US made spacers) cost me $200. I have no problem running spacers. The problem is I don't get the $250 back for restocking/shipping, so it's not like I get that on top of the credit for the wheels. I can fight the restocking fee for poor fitment but I do like the wheels.
  19. May 3, 2019 at 10:32 AM
    #39
    dal3_gribble
    Guys, I spent 10 years in the tuner community, you don't need to lecture me on Rotas. I know what they are.
  20. May 3, 2019 at 10:35 AM
    #40
    blackohio
    Cliche Guevara
    white mudflap
    fuck that nonsense, give them a chance to take back, if not hope you used a credit card
