New wheels, new tires, need alignment?
Discussion in 'Wheels & Tires' started by kikkoman, Jun 30, 2010.
  1. Jun 30, 2010 at 7:01 PM
    kikkoman
    kikkoman [OP] Active Member
    OC
    TRD Sport 4x4 DC
    16X8 AR Mojave wheels, BFG T/A KO 265/70/16, OEM Running Board, OEM All Weather Floor Mats, Neoprene Seat Covers, De-badged, cheeap rubber antenna from Pep Boys
    I somehow got my wife to give the ok on buying new wheels and tires for '09 DC TRD Sport. I'm getting 16x8 mojave's and 265/75/16 BFG AT/KOs (woohoo!). My mechanic is insisting that I get a wheel alignment and not just the balancing. Do I really need to get it done? Luckily (or unluckily), the wheels are back ordered to mid/late July...so i had some time to ponder this. I'd appreciate any input. Thanks!
  2. Jun 30, 2010 at 7:05 PM
    rick
    rick `
    it's probably not a bad idea.
  3. Jun 30, 2010 at 7:25 PM
    jcayce
    jcayce Well-Known Member
    Texas
    17 DCSBTRDOR4X4
    I didn't and it tracks straight as an arrow. It won't hurt anything to do it so if you want to pay for it go right ahead.
  4. Jun 30, 2010 at 7:30 PM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    No not needed. Guy is just trying to make an extra buck.
  5. Jun 30, 2010 at 7:31 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    ^agreed... not needed
  6. Jul 1, 2010 at 12:52 AM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    ^^ agreed
  7. Jul 1, 2010 at 1:55 AM
    sch0enne
    sch0enne Well-Known Member
    penticton British Columbia Canada
    03 Tacoma TRD
    bed lights, cobra 19 dx cb radio, flow pro muffler
    yeah like they said. not needed but maybe a good idea if you have the coin
  8. Jul 1, 2010 at 7:45 AM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    I got an alignment done for the first time after 5 1/2 years on mine (installed 5100's). The toe in/toe out which is usually what needs adjustment was still perfect. Personally, unless you see an indicator that it might be out of alignment (uneven tire wire on the worn out set of tires, pulling to one side, steering shake, or you've run into things like curbs really hard with one tire), then I think it's a waste of money. But a lot of tire shops will tell you to get it done each time you get a new set of tires (I wonder why? $$$). Well, I went through three sets before my first alignment and there still weren't any problems!
    And remember that if you're going to 265/75 on aftermarket wheels without any lift, you MIGHT need to do some trimming or removal of mudflaps. The 265/75 is the largest size you can go on STOCK rims without rubbing (people tend to forget that little important bit of info).
  9. Jul 1, 2010 at 7:49 AM
    AeroCooper
    AeroCooper Half the strength of ten (microscopic men)
    NH
    2018 Barcelona Access Cab Off Road
    Remote start, tailgate inserts, nifty key fob case, Husky X-Act floor liners, AVS vent shades, bed mat, MX4 Tonneau cover, Tyger step rails
    ^^ Agree, except for the part about vibrations (alignment will not cause vibrations). If your current tires are not wearing irregularly and the truck is tracking properly then there is no need for an alignment just because you get new tires.
  10. Jul 1, 2010 at 7:53 AM
    05Moose
    Jim
    I said steering shake, not vibrations. Steering shake will occur if the toe out is well out of adjustment. Had this problem on past cars (Rx7 for one...and yes, the toe out was severely out of spec. Thought I'd add that here in response to Aero's post below mine.). In those cases, it usually will shake when accelerating and ease up when decelerating. But with the Taco's, I will say that steering shake is usually not caused by an alignment but rather improperly balanced tires.
  11. Jul 1, 2010 at 7:59 AM
    AeroCooper
    NH
    I did alignments for 10 years, and never once saw a vibration or steering shake due to alignment. I would imagine if the tires a SEVERELY toed in or out, then yeah, the car may actually hop from the sideways friction.
  12. Jul 1, 2010 at 6:57 PM
    kikkoman
    OC
    TRD Sport 4x4 DC
    Hey, thanks for the warning. I guess all the discussions on here have been about the largest you can go on stock SUSPENSION. well, hopefully this tool I used (http://www.rimsntires.com/rt_specs.jsp) was right about clearance.
