New wheels (procomp 7089) will they fit?
Discussion in 'Wheels & Tires' started by bkthompson6, Jun 19, 2010.
  1. Jun 19, 2010 at 8:42 AM
    bkthompson6
    bkthompson6 [OP] Well-Known Member
    Brandon
    Oregon
    Ok, so i got the go ahead from the ol' lady to get new wheels. I'm already set on the 7089's. I have a 2005 DCSB 4x4 4.0 V6. Will these fit my truck? Procomp 7089 18"x9", 6x5.5, center: 108, offset: -6mm, BKSP: 4.75". They are not hubsentric, does this matter? The wheels i have on my truck right now are 18" so they should fit the tires i have. 4wheelonline wants $145.99 each, this is the cheapest i have found. please let me know soon because i want to get them ordered!! Thanks guys.
  2. Jun 19, 2010 at 8:44 AM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
  3. Jun 19, 2010 at 8:48 AM
    bkthompson6
    Brandon
    Oregon
  4. Jun 19, 2010 at 9:09 AM
    Toyota Truck
    JT
    Texas
    2008 Prerunnner
    I think you also need hub centric wheels hopefully someone else chimes in to help you out.
  5. Jun 19, 2010 at 10:38 AM
    bkthompson6
    Brandon
    Oregon
    bump
    someone please help me with this... i want to get them ordered because im sure they will take forever to get here. thanks
  6. Jun 19, 2010 at 7:53 PM
    bkthompson6
    Brandon
    Oregon
    bump.
    this is rediculous, no one knows anything about these wheels?
  7. Jun 20, 2010 at 5:52 AM
    IB Slingin
    IB Slingin Well-Known Member
    you want NON Hub-Centric. If I remember correctly, the ProComp 7089 hub-centric wheels are for a Chevy. The smaller bore(hub) size wont fit the Tacoma. The Non hub centric fits the Tacoma perfectly. As a matter of fact, they go on so tight, you'd swear it was hub-centric. Also, ProComp makes black lug nuts for these wheels. I have the NON hub-centric on mine......
  8. Jun 20, 2010 at 6:00 AM
    Toyota Truck
    JT
    Texas
    2008 Prerunnner
    Are they the shank lug nuts.
    http://www.brandsport.com/grla-21138et.html
  9. Jun 20, 2010 at 6:00 AM
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    Hampton, VA
    '17 Tundra; '16 Odyssey; ;14 A4
    ^ You would be correct! You want LUG-CENTRIC WHEELS!!!
  10. Jun 20, 2010 at 6:04 AM
    Toyota Truck
    JT
    Texas
    2008 Prerunnner
    :annoyed:
  11. Jun 20, 2010 at 6:06 AM
    Slimwood Shady
    Linwood
    Hampton, VA
    ^ that is the same thing!
  12. Jun 20, 2010 at 6:09 AM
    Toyota Truck
    JT
    Texas
    2008 Prerunnner
    :eek:
  13. Jun 20, 2010 at 6:12 AM
    IB Slingin
    My lug nuts DO NOT have a shank. Im not saying the small shank ones wont work. Mine are the acorn style. I still have the ProComp lug nuts box. Part# 21134B. Description: 6 lug, 7 point, 12x1.5, Color: black.
  14. Jun 20, 2010 at 6:55 AM
    bkthompson6
    Brandon
    Oregon
    Bro this is a sick truck!! hopefully exactly what mine will look like when i get those wheels!
  15. Jun 20, 2010 at 8:02 AM
    IB Slingin
    Thanks:cheers:
  16. Jun 20, 2010 at 9:24 AM
    bkthompson6
    Brandon
    Oregon
    Where did you get those procomp black lug nuts? I have found them online but i think they are the chrome ones, they have the same part number as the ones you described except for the "B" at the end which i assume is for "black". Thanks man
  17. Jun 20, 2010 at 9:28 AM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    you want the one with 4.5 backspacing
  18. Jun 20, 2010 at 9:33 AM
    bkthompson6
    Brandon
    Oregon
    well then it looks like i wont be getting these wheels because they dont make 18"s in 4.5 backspacing, and im not getting new tires.
  19. Jun 20, 2010 at 9:35 AM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    well you can get the 4.75 backspacing one but it may rub on the UCA... but then you could always get wheel spacers... I was looking into getting those but people kept saying they'd rub
    stock wheels are like 5 backspacing but I think they are only 6" wide rim
  20. Jun 20, 2010 at 11:05 AM
    IB Slingin
