New Wheels, Violent Shaking at 60+ mph. What's the problem?
Discussion in 'Wheels & Tires' started by RMAN808, May 31, 2012.
  1. May 31, 2012 at 12:55 PM
    RMAN808
    RMAN808 [OP] S)(AKALO)(AWAII
    Reid
    Pearl City, Hawaii
    '17 TRD OR 4X4 Quicksand
    I just bought a used set of 16" wheels that were on a set of Wild Country Radial TXR (32x11.5R15). I had the wheels put onto the tires I already had on my truck, Michelin LTX A/T (31x10.5R15), because the 32's rubbed too much up front. I still rub a little near full lock with the 31's and new-to-me wheels because the backspacing is different (sticks out more).
    Well this morning on my drive to work, on the freeway, I noticed that at about 60-70 mph my truck would shake violently and it sort of felt like it was coming from the front mostly. The tire shop that mounted em did the balancing as well. I also noticed that they put air in my tires to 40psi (is this too high?).
    Anyone know what the problem could be? :notsure: I figure I'd ask TW before calling the tire shop.
  2. May 31, 2012 at 12:58 PM
    98tacoma27
    Ben
    Not Beech Creek
    Sounds like they need re-balanced. One of them is probably off.
  3. May 31, 2012 at 1:00 PM
    RMAN808
    Reid
    Pearl City, Hawaii
    This should be something the shop should do free of charge, correct? Especially since they were just mounted yesterday. You think?
  4. May 31, 2012 at 1:03 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    I would think so. Could be that a weight fell off. Unless one of the lugs is loose. *gasp!*
  5. May 31, 2012 at 1:04 PM
    easyeatlanta
    easyeatlanta Artificial Intelligence beats natural stupidity
    Eric
    Memphis
    14 DC Trd Off Road
    yeah sounds like someone messed up on balancing
  6. May 31, 2012 at 1:09 PM
    TacoTony
    TacoTony Well-Known Member
    tony
    san antonio
    single cab rado
    Maxtrac spindles
    or one of the wheels are bent, also check the tires again..there could be a 'hop' on the tread
  7. May 31, 2012 at 1:20 PM
    Fabulous
    Fabulous Well-Known Member
    Fabian
    Calgary, AB
    2017 Tacoma double-cab TRD Sport
    TRD Pro grill and fog lights, Toytec Boss lift, 265/70-17 Duratracs on 17 x 8.5 FN Verge wheels, LEER canopy, 30% tinted front windows.
    Did you get hub centric wheels? If not, how about the hub spacers to make them fit like they were hub centric? Correct conical lug nuts?
  8. May 31, 2012 at 1:27 PM
    RMAN808
    Reid
    Pearl City, Hawaii
    At the shop now, looks like he's making a bunch of corrections with the balancing. Lug nuts are correct. Hoping that it's just misbalanced.
  9. May 31, 2012 at 6:20 PM
    RMAN808
    Reid
    Pearl City, Hawaii
    Thanks for all the advice folks! :D The drive is better now, although there is still some vibe but it feels almost how it did before the wheel/tire change.
  10. May 31, 2012 at 7:18 PM
    babytruck
    NorCal
    So what was it? Missing weights?
  11. May 31, 2012 at 7:20 PM
    RMAN808
    Reid
    Pearl City, Hawaii
    Yea he had to add weights. The adhesive ones :notsure:
  12. May 31, 2012 at 7:27 PM
    babytruck
    NorCal
    Good. At least that's settled. :)
  13. May 31, 2012 at 7:41 PM
    RMAN808
    Reid
    Pearl City, Hawaii
    :D Thanks for the help. I appreciate it!
