New Wheels - What Lugs & Tire Size?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Steel409, Aug 21, 2019.
  1. Aug 21, 2019 at 8:03 AM
    Steel409
    Steel409 [OP] Active Member
    Jack
    2017 Magnetic Gray TRD Off Road
  2. Aug 21, 2019 at 8:21 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Yes, factory lugs will work.
    265/70/17 is perfect, try and get an SL or C rated tire for mpgs and no calibration needed for the speedo. Also no rubbing, so your safe there. Excellent tire size over the 275s which may rub but I doubt it will in the SEMA wheels but that's an odd ball size and not much out there in terms of selection.
    Steel409[OP] likes this.
  3. Sep 12, 2019 at 7:25 AM
    Steel409
    Jack
    Thanks, mds08. Are tire pressure requirements the same?
  4. Sep 16, 2019 at 9:38 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    No.
    P and euro metric tires require a PSI that attains a 2,149 lb load capacity. For a P265/65/17/110, it is 29 PSI.
    LT metric tires require a PSI that attains a 1,954 lb load capacity. For a LT265/70/17, it is 37 PSI.
  5. Sep 19, 2019 at 2:34 PM
    Steel409
    Jack
    Gents, thanks for the feedback on the size of the tire.
    I'm a little confused about the other info though. Are those load ratings, speed ratings, etc?
    Example, if I go to https://www.discounttire.com/buy-tires/bfgoodrich-all-terrain-t-a-ko2# , my options for the LT265/70/17 are: 112S, 118S, and 121S.
    112 = 2469 lbs.
    118 = 2910 lbs.
    121 = 3197 lbs.
    S = up to 112 mph
    Am I understanding that correctly? I'm not planning on towing or hauling anything heavy, so would guess the 112S tire at 37 psi would be most logical?
    Thanks for your input!
  6. Sep 19, 2019 at 3:00 PM
    splitbolt
    NW Arkansas
    You got it...
    For that tire size;
    112=C load
    118=D load
    121=E load
    They would all take 37 PSI.
    It's a matter of how much weight and stiff construction you do or don't want.
    Steel409[QUOTED][OP] likes this.
  7. Sep 19, 2019 at 6:19 PM
    Steel409
    Jack
    Ahhhh!!! Awesome man, thanks!!!
