New wheels won't fit!
Discussion in 'Wheels & Tires' started by JP22, Sep 20, 2012.
  1. Sep 21, 2012 at 2:48 AM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    Supposed to tighten them in a star pattern anyways. That's how you tighten any series of bolts to be torqued, for example the engine head..
  2. Sep 21, 2012 at 4:51 AM
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
    No kidding.....not everyone knows that. :facepalm:
  3. Sep 21, 2012 at 6:03 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    x2....and most shops or "home" mechanics use an impact then wonder why their wheel studs sheared off...derp
  4. Sep 21, 2012 at 7:22 AM
    JP22
    JP22 [OP] Active Member
    Alabama
    09 DCSB 4X4
    After calming down, I went by to see scott this morning. I UNDERSTOOD HIM WRONG! The bearing cap on the hub is too large for the wheel. I called and talked with the place I got them from. According to specs they are right. Bore size is 106+. Shitty luck on my part!
  5. Sep 21, 2012 at 8:49 AM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    What a cluster fuck; I would return those things asap before you miss out on the return policy and get stuck with those wheels.
  6. Sep 21, 2012 at 10:53 AM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    sometimes when manufacturers paint/powdercoat their wheels, the hub opening gets coated by a thin layer of paint/powder. this can sometimes cause a tight fit when you try to mount the wheel on.
    OR
    because of the tight tolerance, make sure that your hub is nice and clean for the wheel to slip on easier.
    disregard the above if they completely shipped you the wrong wheels.
  7. Sep 21, 2012 at 12:06 PM
    650H1
    Michael
    VA
    Stay with factory wheels and never have this issue/disappointment again. Plus they won't shake when you put a factory wheel on, if the tires not fucked up, like most aftermarket wheels do.
  8. Sep 21, 2012 at 12:09 PM
    ace96
    Western KY
    That is not true. My Pro Comps never shook. If aftermarket wheels are that bad why do so many people run them?
  9. Sep 21, 2012 at 5:56 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    They shake because you weren't running a hubcentric ring. ;)
  10. Sep 21, 2012 at 8:28 PM
    JP22
    Alabama
    09 DCSB 4X4
    I can guarantee when I get these replaced there will be a set of hub centric rings with them
