New Wildpeaks and MPG
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Cyborga, Apr 12, 2019.
  1. Apr 12, 2019 at 1:33 AM
    Cyborga
    Cyborga [OP] Member
    2019 Cement SR5
    I just threw some new Falken Wildpeaks 265/75/16s on my 2019 taco. Before having them put on my mpg was around 21 highway. This was my first trip in with them on and I averaged 16. My tire pressure is around 35 on all tires.
    This is pretty alarming. I was expecting a drop in mpg but this is a lot worse then I imagined. Everywhere I read said these tires were going to be great. Can anyone help up with me understanding this? Can the psi being high effect my gas mileage? I also put on a new bed cover at the same time. I don't think that should do anything but maybe help out a bit. Online it says you can expect to lose 3% mpg with AT tires but I just lost about 25%. I don't want to take them off as they look and feel amazing but this was bad.
    harlequin_forest likes this.
  2. Apr 12, 2019 at 1:37 AM
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    you put on bigger heavier tires with a bigger tread pattern so more rolling resistance. Honestly if you care a lot about MPGs you should leave the highway tires on. Also the tire is now a bit bigger which means it rotates less per mile throwing off your MPG calculations by your truck. Go by smiles per mile(spm) and enjoy your truck which isn’t very fuel friendly anyway.
  3. Apr 12, 2019 at 1:37 AM
    ahkouchi
    ahkouchi Well-Known Member
    Andrew
    Big Island Hawaii
    2016 Magnetic Gray Metallic Tacoma
    Front Elka 2.5 non resi with 650lb spring Rear Serviceable 5160's with AAL 265/75/r16 BFG KO2
    one trip is not good enough sample to base it on. try after a few trips. I had KO2 LT's of the same size and didn't lose to much. maybe you drove more spirited than normally? maybe you had more hills? lots of things can play a factor.
    MrCball, Cyborga[OP] and El Duderino like this.
  4. Apr 12, 2019 at 1:40 AM
    ahkouchi
    Andrew
    Big Island Hawaii
    I to have a japanese wife from japan lol
  5. Apr 12, 2019 at 1:41 AM
    El Duderino
    Jeremy
    HI->PNW
    I see you read my sig quote lol.
  6. Apr 12, 2019 at 1:42 AM
    ahkouchi
    Andrew
    Big Island Hawaii
    yes i did. also, as cliche as it is, thank you for your service.
    El Duderino[QUOTED] likes this.
  7. Apr 12, 2019 at 1:43 AM
    El Duderino
    Jeremy
    HI->PNW
    And yours too my good man
  8. Apr 12, 2019 at 1:44 AM
    Cyborga
    Cyborga [OP] Member
    2019 Cement SR5
    I was on cruise control at my normal speed with the same path to work I always take
    DavesTaco68 likes this.
  9. Apr 12, 2019 at 1:46 AM
    ahkouchi
    Andrew
    Big Island Hawaii
    do you normally drive with CC on? i know for a fact that CC eats some gas depending on road. also, again, you need a bigger sample. i'm sure you will be fine
  10. Apr 12, 2019 at 1:49 AM
    El Duderino
    Jeremy
    HI->PNW
    Also I am the walking stereotype of a white guy in Hawaii. Wife even drives a 4Runner :rofl:
    tlaloc5, AxisCab and jimbro like this.
  11. Apr 12, 2019 at 1:50 AM
    ahkouchi
    Andrew
    Big Island Hawaii
    .... i'm about to buy her a 4runner as well.... can't be a "soccer mom" in hawaii without a silver or white 4runner lol
    jimbro and El Duderino[QUOTED] like this.
  12. Apr 12, 2019 at 1:51 AM
    El Duderino
    Jeremy
    HI->PNW
    I’m safe then from that she picked Nautical blue
  13. Apr 12, 2019 at 1:53 AM
    Cyborga
    Cyborga [OP] Member
    2019 Cement SR5
    Thanks for the optimism! But recently yes I have been using CC. It's a 35 mile stretch on a highway. I find it easy to let it do it's thing. I'll stay optimistic and see if it changes at all
  14. Apr 12, 2019 at 1:54 AM
    El Duderino
    Jeremy
    HI->PNW
    Don’t lift it then if you care about MPGs lol. That will absolutely crush it
  15. Apr 12, 2019 at 2:16 AM
    cpc
    cpc Well-Known Member
    MASS/ESSEX COUNTY
    TRD PRO
    cbi front receiver, rigid lights, leitner designs, mobtown sliders, Brute Force Fab
    did you get the LT 10 ply tire or the SL 4 ply tire? there is an eleven pound per tire difference which certainly make a difference in your gas mileage.
  16. Apr 12, 2019 at 2:18 AM
    ahkouchi
    Andrew
    Big Island Hawaii
    he has a point. but 5mpg, i doubt it. like i said, i had the 265/75r16 Kbro2's before. didn't see much of a difference
    DavesTaco68 and tundraconvert like this.
  17. Apr 12, 2019 at 4:41 AM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    I have SL wildpeaks and my mpg never changed from stock.
    shakerhood likes this.
  18. Apr 12, 2019 at 6:45 AM
    HacksawMark
    HacksawMark Well-Known Member
    Mark
    OREGON
    2018 Silver Tacoma V6 DCSB TRD OffRoad traded for 2019 Ford XLT 3.5L EcoBoost SC
    My guess is he got the E rated tire due to the difference in MPG. Probably a huge difference in rolling resistance between the two.
    El Duderino likes this.
  19. Apr 12, 2019 at 6:51 AM
    tundraconvert
    tundraconvert Well-Known Member
    Eric
    San Diego
    2017 White Tacoma DCLB TRD OR
    Seems a bit of a heavy loss to me as well. I put same size tire jump on but with 17” wheels. Of course I lost mpg's but not that drastic.
  20. Apr 12, 2019 at 6:52 AM
    Shellshock
    Iowa
    265/75/16 is available in both E and SL load rating. You bought E and wrecked your MPG. Should have bought SL.
