New Wire for Door Speakers
Discussion in 'Audio & Video' started by mantis_fortress, Dec 30, 2023.
  1. Jul 18, 2024 at 7:09 PM
    Jigstick
    Jigstick Well-Known Member
    2023 TRD OR LB
    So if I’m wiring the back doors, front doors, and subs directly from the amplifier, how would I carry the amplified single for the dash speakers from the amp up to the factory tweeter singles to splice in? Using splice taps seems like a bad move
  2. Jul 18, 2024 at 7:34 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    They should connect to your new tweeters with their included crossover.
    And no, you don't want to be running the factory tweeters and crossover on anything beyond the factory radio.
  3. Jul 19, 2024 at 5:04 AM
    Jigstick
    2023 TRD OR LB
    Right. So if I mount new tweeters in the dash then somehow I have to get speaker wires from them to the crossovers. I don’t see a way to do that without running new wire directly from the crossovers to the new tweeters
  4. Jul 19, 2024 at 7:00 AM
    soundman98
    NW Indiana
    What amp do you have, and where is it going?
    And what tweeters/crossovers do you have
  5. Jul 19, 2024 at 4:54 PM
    Jigstick
    2023 TRD OR LB
    Focal FlaxEvo PS 165 FXE Components
    And Focal FlaxEvo PC 165 coax in the rear doors
  6. Jul 20, 2024 at 6:06 AM
    soundman98
    NW Indiana
    You didn't specify your amp-- I was looking for the size of it.
    Depending on the size of the amp and the install location, the crossovers can sometimes be installed with the amp behind the seats or under the seats, with separate wire runs up to the speakers.
    The door looms to the door speakers are directly under the front tweeters, so the same path is usually used, with popping off the dash side trim to run the wire up to the tweeters.
    The disadvantage to that method is running 2 pairs of wire from the amp/crossover location can add some additional bulk to be hidden in tight spots, as well as slightly increased cost from the additional wire. But done right, can make for a much more presentable installation.
    Alternatively, there's space within the dash on either side above the kick panels(lay on the driver's side floor and look up, passenger side, remove the side panel, there's space between the panel and the glove box enclosure that should be accessible from underneath), and under the tweeters, so the amp output can also be ran to that location, and shorter wire can be ran off the crossover to the door speakers and tweeters locations.
    And of course the middle option, is always going to be underneath the seat. Even if the amp is under one seat, the crossovers could be placed under the other seat.
    Pray4Mojo likes this.
  7. Jul 20, 2024 at 7:34 AM
    Jigstick
    2023 TRD OR LB
    Either the Audison SR600.5 or the JL HD900/5. Plan on mounting that behind the drivers side rear seat. The crossovers I was thinking of mounting on either side of the amp, or in the cubby underneath the rear seat.
    soundman98 likes this.
  8. Feb 2, 2025 at 5:21 AM
    MarlonB54
    MarlonB54 Well-Known Member
    Fishaholic
    22’ Barcelona Red TRD Off Road
    the factory wiring can handle 100 watts rms ??
  9. Feb 2, 2025 at 6:05 AM
    GRNT4R
    GRNT4R Well-Known Member
    NC - Triad
    2010 TRD Sport DCLB 4WD Silver
    TBD
    Yes, the factory wire could handle that as well
  10. Feb 2, 2025 at 6:09 AM
    MarlonB54
    Fishaholic
    Man everywhere ive read they say it cant. Im mad because i just installed everything yesterday and read that the factory wires arent sufficient so i havent plugged anything in yet
  11. Feb 2, 2025 at 6:32 AM
    GRNT4R
    NC - Triad
    TBD
    Err on the side of caution and replace the wiring. Dean and Fernando often use the OEM wiring on I stalls with 5 Star Car Stereo. They have done install on multiple tacomas as well. I always ran new wire as it was normal for me but you could easily throw in some 14 or 16guage wiring. You have a 22 so I’m sure you are good but check them out on IG and you can ask the question on their live and they will reply
    Pray4Mojo and soundman98 like this.
  12. Feb 2, 2025 at 6:42 AM
    MarlonB54
    Fishaholic
    For now i was thinking to plug everything in and tune the amp with a multimeter then just run the set up at 50% volume max until i get around to buying and installing new wire. What im not sure of though is if lower volume = less watts being pumped out.
  13. Feb 2, 2025 at 8:54 AM
    GRNT4R
    NC - Triad
    TBD
    If you have clean power you will be fine. Distortion is what will kill your speakers which is running out of power. What speakers and amp are you running
  14. Feb 2, 2025 at 9:04 AM
    MarlonB54
    Fishaholic
    2 Kicker Cs series 6x9 150 watt RMS in the front
    2 Kicker Cs series 6 3/4” 100 watt RMS in the back
    Pioneer GM DX874 100RMS x 4 amp
  15. Feb 2, 2025 at 9:18 AM
    #35
    GRNT4R
    NC - Triad
    TBD
    I think you will be fine. Not sure how clean the power is from the pioneer so it may not be an actual 100watts coming from it. Just listen did distortion.
  16. Feb 22, 2025 at 6:03 PM
    #36
    Pray4Mojo
    Pray4Mojo Member
    2012 Super White Pre-Runner
    Yes. The power being sent through the speaker wires is dictated by the music: how loud it is and even the type of music (more bass = more power).
    Thinner wire has more resistance than thicker wire. Resistance in the wire converts electrical energy into heat. Too much power (energy per second) sent through a wire can heat up the wire so much that it catches on fire. However, that's far less likely in speaker wire because the power sent through the wire isnt continuous--it fluctuates with the music. If your amp is capable of producing 100W of power, it's only doing so at max volume, and unless you're playing something like a 50Hz sine wave it's not continuously producing that power. Playing music at max volume would result in something like 1/5th the max power delivery on average (rough rule of thumb). The dips in power delivery allow heat to dissipate rather than continue to build up.
    The main benefit to upgrading to a thicker speaker wire is less power is lost to heat before reaching your speakers. Outside of extreme scenarios, it's not a hazard to re-use factory speaker wiring with an aftermarket amp.
  17. Apr 21, 2025 at 1:45 PM
    #37
    P-Rizzle
    P-Rizzle Member
    Patrick
    2020 TRD Sport 4x4
    Bilstein 3” readylift Method 703 17x9 Bronze Rocksliders
    I have been chasing a gremlin for a year now.
    Started getting popping and crackling from front left channel, mainly the DS18 dash tweeter. replaced it, replaced harness. Still there. Checked all amp connections, solid. Redid all grounds, solid. Someone said it was probably my LC5i pro, warranty replacement. Still happening. It's intermittent and even happens when stereo is off.
    Could it be wiring? Any ideas.
  18. Apr 21, 2025 at 6:23 PM
    #38
    GRNT4R
    NC - Triad
    TBD
    It could be a bad RCA. Try replacing an RCA to see if that clears it up
  19. May 29, 2025 at 4:21 AM
    #39
    BustedKnuckles7
    BustedKnuckles7 Well-Known Member
    2022 Electric Lime TRD
    Would also check RCA cable, could be bad cable. In my past I have been known to solder a ground wire to the shield of the rca and to a ground point in a pinch......
