New with suspension and need Advice
Discussion in 'Suspension' started by rmacher, May 8, 2011.
  1. May 8, 2011 at 7:55 PM
    rmacher
    rmacher [OP] Well-Known Member
    2010 TRD SR5 / SB
    4 Kergen HID / Spidertrax spacers / Argentinian leather / FAb light bar / Raamaudio /DMM HID's 6000k/ Jl Audio amp /etc //
    I have a 2010 TRD 4 x 4 Tacoma and I will like to change the suspension for Adjustable Bilstein (all around) , the rear has 3 leaf only and I will use 265/75/16 tires with original rims and 1.25 spacer , now what should I do to have a nice look , I do 99.5% city ride.
    Thanks you.
  2. May 9, 2011 at 5:36 AM
    rmacher
    2010 TRD SR5 / SB
    If I replace the front shock should I use the same coils ? it will work fine , the rear because I have 3 leaf an extra one will be fine? the high I want is just decent .
  3. May 9, 2011 at 7:34 AM
    brelandt
    brelandt Well-Known Member
    Terry
    Dublin, CA
    04 Prerunner reg cab SR5
    3" lift front and back
    LOL did you know while i was trolling the pick n pull last week that every single 1980's square body Ranger had lift blocks from the factory on them! Never knew that...... :eek:
