New Yokohama A/T4 G018
Discussion in 'Wheels & Tires' started by Hilborn, Jun 24, 2024.
  1. Aug 30, 2024 at 9:37 AM
    #41
    1urch420365
    1urch420365 Well-Known Member
    James
    2015 Tacoma
    Just called my local DT they claim they have not heard about this tire and cannot order it.
    Road_Warrior likes this.
  2. Aug 30, 2024 at 9:41 AM
    #42
    BDSKJChris
    BDSKJChris Well-Known Member
    Albany, NY
    2019 Quicksand TRD OR DCSB
    Per Yokohama's website, these are now called the "Geolandar AT/4" no longer called the "Geolandar A/T G018", they do not seem to be replacing the G015, just a slightly more aggressive tread pattern. I plan to get a set when I use up the Duratracs I currently have.
  3. Aug 30, 2024 at 11:15 AM
    #43
    1urch420365
    James
    2015 Tacoma
    For those of you who run/have run the G015s: Do you have the P or the LT version of the tire and how happy are you with it? I think im going to just get the G015 as I cant go much further on my current tires and I have a credit with DT. Thanks in advance!
  4. Aug 30, 2024 at 12:52 PM
    #44
    BDSKJChris
    Albany, NY
    I ran a set of P265/70R16 on the tacoma, changed them out at about 40K miles of roadwear, could have gotten more had I not been running them over-inflated. They have about 1/16" of tread in the middle left and maybe 1/8 or 5/32" at closer to the edge of the tread.
    I ran a set on my jeep before getting the tacoma. My favorite AT tire for a daily driver. They did great in rain and snow and were very quiet and comfortable.
    I have run duratracs and cooper discoverer AT/3s before that. Kind of hate duratracs to be honest, noisy as hell, need to be rotated every 2,500-3,000 miles or they get obnoxiously noisy, and their performance on wet roads was garbage, and they only did good in snow they could dig into, anything hard packed, slush, etc... and they were mediocre. But they do look cool as hell.
    I plan to run another set of G015s on my factory wheels and the G018s on the TRD Baja wheels. Will probably get P rated tires considering I have yet to load the tacoma with anything super heavy, so why not save money and get a smoother ride.
    1urch420365 and Road_Warrior like this.
  5. Aug 30, 2024 at 1:07 PM
    #45
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    Running G015s now about 6-8K miles on them. Excellent tire all around, very good in heavy rain & standing water on the roadway, very good on dry & rocky single-track forest trails, very good at high speed on clean dry asphalt.
    My truck is medium-heavy, running at about +650-700 lbs beyond stock curb weight, and I occasionally load it with as much as 1700 additional lbs of cargo and/or landscaping debris. (FOX 2.5s on all 4 corners + heavy Deaver U402 III leafs on back make this possible & comfortable to do.) Tires are fine with this, I sometimes inflate them as high as 40 PSI for heavy loads. (Max PSI listed on sidewall is, I believe, 51 PSI.)
    We will see how tread-wear goes, just by "look and feel" I think they're probably a pretty soft compound and will be more likely to do 38-42K miles, rather than 55-60K miles. (Going by the legal standard for tread wear limit in CA, which is 4/32s for the front tires, and 2/32s for rear tires.)
  6. Aug 30, 2024 at 1:50 PM
    #46
    Hilborn
    Hilborn [OP] Adventure First. Safety Second.
    Michael
    Utah
    2009 Tacoma DCLB TRD Sport 4x4
    ADD W1 Oil Catch Can. AFE Magnum FORCE Stage-2 Si Cold Air Intake System. AlphaRex Black Pro-Series Headlights. Anderson Engineering Solutions Manifold Spacer. ARK Splash Guards. AVS Door Sill Protectors. BAMF Bolt-On Rock Sliders. BAMF CMC Plates. BedRug. Brute Force HC Rear Bumper. C4 Engine Skid. C4 Transmission Skid. C4 Transfer Case Skid. C4 Fuel Tank Skid. C4 Rear Diff Skid. Cooper Discoverer ST Maxx LT285/70R-17. Diode Dynamics SL2 Pro LED Bulbs. Dirt King Ball Joint Upper Control Arms. Dirt King Lower Control Arms. Dirt King Spindle Gussets. Doug Thorley Y-Pipe. DRT Fabrication Shackle Hanger Kit. Eaton Detroit Trutrac Rear Differential. ECGS Bushing. Expedition Essentials Bedside ARB Air Compressor Mount. Garmin Overlander GPS. Genesis Gen 3 Dual Battery System w/ G Screen. HCF Delete. Husky Floor Liners. Hypertech In-Line Speedometer Calibrator (@1.038). IGGY Switch Panel. Ironman4x4 Foam Cell Pro Struts and Shocks. KPOffroad Alignment Cam Upgrade Kit. Leer 100XQ. Magnaflow Overland Series Cat-Back Exhaust w/ 10416 Muffler. Method Vex Titanium 17x8.5. Yukon 4.56 Gears. Odyssey Performance Group 34 Batteries (2). OME 886x Coil Springs. OME Carrier Bearing Spacers. OME CS047R Dakar Leaf Springs w/ D29XL. Overland Torque Tune. Pakrax Tailgate Panel. Pinch Weld Mod. Pop n' Lock. Power Stop Z36 Truck and Tow Brake Pads. rcbs204 Illumited 4x4 Switch. Rear Differential Breather Relocation. Rexing V1 Dash Cam. Scanguage 2 w/ TFT. Stahlbus Oil Drain Plug. Stoptech Cryo-Treated Rotors. Sway Bar Delete. Total Chaos Bed Stiffeners. Toyota 70mm Throttle Body. ToyTec Axle Degree Shims. URD 170° Thermostat.* URD 65 to 70mm Throttle Body Adapter. URD Exhaust Cam Gears. USA Spec IPod Interface. Voltage Booster Pro. Wheeler's Brake Lines. Wheeler's Front SuperBumps with 3/8" Spacers. Wheeler's U-Bolt Flip Kit w/ SuperBumps.
    My theory is that Yokohama calls the P rated G018, the CV4S.
  7. Aug 30, 2024 at 4:03 PM
    #47
    1urch420365
    James
    2015 Tacoma
    Thanks for the reply! Are you running the P rated version also what size?
  8. Aug 30, 2024 at 4:38 PM
    #48
    GilbertOz
    GilbertOz Driver
    CA
    Right, oops, you asked what rating in your earlier post.
    P-rated, stock size, P265/70/R16.
    1urch420365[QUOTED] likes this.
  9. Aug 31, 2024 at 2:23 PM
    #49
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    I just pulled the trigger on a set of these in LT285/75/16. They appear to be the perfect tire for my needs. The previous iterations of Yokohama’s all terrains were just a tad too mild for me, I think these will fit the bill.
    I’ll let you all know how they ride once I get them mounted, it will probably be a week or two.
  10. Aug 31, 2024 at 2:33 PM
    #50
    1urch420365
    James
    2015 Tacoma
    Nice… where’d you buy em from?? And how much??
    Road_Warrior[QUOTED] likes this.
  11. Aug 31, 2024 at 2:37 PM
    #51
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    Simple Tire and they were $246 a piece.
    Crazy cheap for a 33” tire from a reputable company. Under $1K for all 4. I believe they’re running a Labor Day sale so I snagged them while they’re on sale.
  12. Aug 31, 2024 at 2:39 PM
    #52
    1urch420365
    James
    2015 Tacoma
    Niccccee.:thumbsup:
  13. Aug 31, 2024 at 2:40 PM
    #53
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    Thanks! Hopefully they’re as good as I expect. I’ve been searching for the perfect
    tire for me and I have high hopes for these.
  14. Sep 4, 2024 at 8:29 AM
    #54
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    So a bit of an update. I placed my order with Simple Tire on Saturday and the tracking labels haven’t been created yet. I’ve ordered 3 sets of tires from them previously, and the tires arrived at my house within 2 days of placing the order each of those times.
    I contacted their customer service to see if they could just give me an ETA for the tires shipping, and the customer service rep said they are going to “check with the warehouse” and then send me an email.
    If you’re planning on ordering these from Simple Tire, I would wait until I get an answer because I’m starting to suspect they took my money and don’t actually have them in stock. My online account with them says that the tires have been “pulled off the shelf” and are waiting to ship but this wait time is highly unusual for them based on my previous experiences. I also checked and noticed I can’t find this size of this tire in stock anywhere else, which makes me more suspicious.
    I’ll update when I hear back from them.
    Canadian Caber and 1urch420365 like this.
  15. Sep 5, 2024 at 7:05 AM
    #55
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    Well I never heard back from Simple Tire so I contacted them again today and I was told that my order has been reassigned to a new warehouse and “should ship today”. If I don’t get confirmation that they ship today I think I will probably just cancel the order so I can get my money back. I’ll let you guys know if they actually wind up having these in stock.
    Canadian Caber likes this.
  16. Sep 5, 2024 at 10:57 AM
    #56
    Hilborn
    Michael
    Utah
    I called my local Discount Tire yesterday to get a price quote. they were having a hard time tracking down a set of 265/70-17s. They found 2 on TireRack.com but there was no lead on when a full set would be available. I was looking for a new set of tires before November. Keeping my fingers crossed in hoping Yokohama gets these out to the market by then.
  17. Sep 5, 2024 at 11:05 AM
    #57
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    Yeah it seems like they are really hard to find, I’m hoping I hear something soon from simple tire but still nothing yet.
    hyrule_trd likes this.
  18. Sep 5, 2024 at 11:08 AM
    #58
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    Just get the MT Baja Boss ATs :fistbump:
    They’re just the heaviest ATs…
    Hope these are shipped for you soon though
  19. Sep 5, 2024 at 11:11 AM
    #59
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    :rofl:
    Trust me I considered it!!
    hyrule_trd[QUOTED] likes this.
  20. Sep 5, 2024 at 11:44 AM
    #60
    Hilborn
    Michael
    Utah
    Im not even going to lie, I recommend the MT AT SL all the time. I personally am looking for a E tire and the MT AT Es are past the weight I am willing to go with.
