New Yokohama A/T4 G018
Discussion in 'Wheels & Tires' started by Hilborn, Jun 24, 2024.
  1. Sep 25, 2024 at 5:46 AM
    #81
    TH_Don
    TH_Don Well-Known Member
    2024 Bronze Oxide Trailhunter LWB
    Do they have full depth sipes? I don't want to buy a tire where the siping is gone (along with wet/snow traction) well before the tread depth becomes unusable.
    Mad German and Road_Warrior like this.
  2. Sep 25, 2024 at 7:37 AM
    #82
    Hilborn
    Hilborn [OP] Adventure First. Safety Second.
    Michael
    Utah
    2009 Tacoma DCLB TRD Sport 4x4
    ADD W1 Oil Catch Can. AFE Magnum FORCE Stage-2 Si Cold Air Intake System. AlphaRex Black Pro-Series Headlights. Anderson Engineering Solutions Manifold Spacer. ARK Splash Guards. AVS Door Sill Protectors. BAMF Bolt-On Rock Sliders. BAMF CMC Plates. BedRug. Brute Force HC Rear Bumper. C4 Engine Skid. C4 Transmission Skid. C4 Transfer Case Skid. C4 Fuel Tank Skid. C4 Rear Diff Skid. Cooper Discoverer ST Maxx LT285/70R-17. Dirt King Ball Joint Upper Control Arms. Dirt King Lower Control Arms. Dirt King Spindle Gussets. Doug Thorley Y-Pipe. DRT Fabrication Shackle Hanger Kit. Eaton Detroit Trutrac Rear Differential. ECGS Bushing. Expedition Essentials Bedside ARB Air Compressor Mount. Garmin Overlander GPS. Genesis Gen 3 Dual Battery System w/ G Screen. HCF Delete. Husky Floor Liners. Hypertech In-Line Speedometer Calibrator (@1.038). IGGY Switch Panel. Ironman4x4 Foam Cell Pro Struts and Shocks. KPOffroad Alignment Cam Upgrade Kit. Leer 100XQ. Magnaflow Overland Series Cat-Back Exhaust w/ 10416 Muffler. Method Vex Titanium 17x8.5. Yukon 4.56 Gears. Odyssey Performance Group 34 Batteries (2). OME 886x Coil Springs. OME Carrier Bearing Spacers. OME CS047R Dakar Leaf Springs w/ D29XL. Overland Torque Tune. Pakrax Tailgate Panel. Pinch Weld Mod. Pop n' Lock. Power Stop Z36 Truck and Tow Brake Pads. rcbs204 Illumited 4x4 Switch. Rear Differential Breather Relocation. Rexing V1 Dash Cam. Scanguage 2 w/ TFT. Stahlbus Oil Drain Plug. Stoptech Cryo-Treated Rotors. Sway Bar Delete. Total Chaos Bed Stiffeners. Toyota 70mm Throttle Body. ToyTec Axle Degree Shims. URD 170° Thermostat.* URD 65 to 70mm Throttle Body Adapter. URD Exhaust Cam Gears. USA Spec IPod Interface. Voltage Booster Pro. Wheeler's Brake Lines. Wheeler's Front SuperBumps with 3/8" Spacers. Wheeler's U-Bolt Flip Kit w/ SuperBumps.
    They say they have 3D siping. Only time will tell.
    Road_Warrior likes this.
  3. Sep 25, 2024 at 7:40 AM
    #83
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    The sipes are not full depth, which I was disappointed about. But like hillborn said, we will see how they wear. There is certainly a lot of siping.
    The mud terrains I had before these actually had deeper sipes, believe it or not.
  4. Sep 25, 2024 at 8:23 AM
    #84
    Hilborn
    Michael
    Utah
    I've had tires with full depth sipes, BFG KO2, and they were horrible in wet, snow and mud. The Cooper ST Maxx I run on my Tacoma are a better tire than the KO2s. Too many sipes also allow the thread blocks to squirm under load and that will increase wear.
  5. Sep 25, 2024 at 11:05 AM
    #85
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    That’s an interesting point. I also assume that if they were able to get the tire certified with the 3PMS, it must be good in the rain and snow.
  6. Sep 25, 2024 at 11:57 AM
    #86
    TH_Don
    I could see where full depth sipes that go to the very outside edge of the block (especially on both sides or directly through the block from edge to edge) could lead to chunks of the block tearing away.
    I think the 3D sipes are so that they close up against each other tightly to stiffen the tread block under load.
  7. Sep 25, 2024 at 12:02 PM
    #87
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    That would make sense, because the sipes on these tires are packed together pretty tightly. So far they have been great on wet pavement but I haven’t had them long enough to write any real review.
  8. Oct 14, 2024 at 6:20 PM
    #88
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    I don’t have time to write a ton at the moment because I’m out on the road but I’ve put ~3K miles on these tires this week and they are by far my favorite tire I’ve run to date on the truck.
    Dirt, gravel, mud, rain, highway, backcountry roads…these things have been absolutely crushing it. They preform fantastic off road and drive like a highway tire at speeds up to 80mph.
  9. Oct 14, 2024 at 6:24 PM
    #89
    Squirt
    Squirt Samsung Aficionado!
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back with a 3in Speedys Snap resonator. J&L catch can. AMP Powersteps
    Can't wait to hear about snow performance.
  10. Oct 14, 2024 at 6:30 PM
    #90
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    We’ll see if we get any snow in my area this year. We haven’t had more than a few inches the last couple winters. With all the siping, I think they will be extremely good in the snow.
    Squirt[QUOTED] likes this.
  11. Oct 28, 2024 at 2:33 PM
    #91
    Rocky.Mtn
    Rocky.Mtn Well-Known Member
    Canada
    2024 Tacoma TRD OR (Hybrid)
    Also looking at these new G018s for tires for my new '24 in a 255/80/17 instead of the Toyo AT3.
    They are a couple lbs heavier, but the siping looks better for winter.
  12. Oct 29, 2024 at 4:32 AM
    #92
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    If the wet weather performance is any indication of their winter performance, it’s all good. I drove through a rain storm in the highway mountain passes of Idaho the other week and these things were fantastic.
  13. Jan 15, 2025 at 6:07 PM
    #93
    Hilborn
    Michael
    Utah
    Update: Tires do very well in light snow. I am not experiencing any flat spots after being parked for several days. Also noticing that the tires are holding pressure. I am not having to add air all the time to maintain where I put them at.
  14. Jan 15, 2025 at 6:41 PM
    #94
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    Same here. I forgot to post a snow update after we got about a foot the other week. This tires are really fantastic in all weather and I can now say the same for snow and slush. They definitely live up to the 3PMS rating.
  15. Jan 17, 2025 at 4:25 AM
    #95
    Mad German
    Mad German Well-Known Member
    2016 TRD Off Road
    That's a good point. I hadn't thought of that before. Thank you!
  16. Jan 19, 2025 at 12:29 PM
    #96
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    More ice and snow on the roads here today and I got to really test these tires out. I can now definitively say these are the best all terrain tires I’ve ever run, and probably the best tires in general that I’ve had on any of my vehicles. Yokohama really knocked it out of the park with these.
    I had zero issues while driving around in about 1” of snow and ice on the roads. I tried to get the truck to break loose in a couple places where it was safe and I just couldn’t get these tires to break traction even while it was actively snowing. I will definitely be getting another set of these when this set wears out.
    ChaCha and Hilborn[OP] like this.
  17. Jan 21, 2025 at 7:07 AM
    #97
    ChaCha
    ChaCha Well-Known Member
    Sandy, UT
    13 DCLB
    I've put about 2k miles on my set of GO18s, and I've been very pleased so far. I'm curious to see how they continue to perform and sound with mileage.
  18. Feb 22, 2025 at 4:20 PM
    #98
    shnichol
    shnichol New Member
    2002 Tacoma Xtra Cab Manual
    Just received my G018's. Thought I would share my observations on the sipe depth since it has been impossible to find anything online. Mine are LT265/75R16 and have a actual weight of 49.2 (spec says 49.7 so glad its a bit lighter). The tread depth is 18/32 and sipe depth is 16/32. That is pretty much full depth in my opinion since you should be replacing the tires once you get to 2/32 anyways. Probably won't get around to installing till the spring, but ordered them now because Yokahama is offering $100 off purchase of 4 (or $125 off 5) with an invite code that pops up when you visit https://www.yokohamatire.com/tires/geolandar-a-t4
  19. Feb 22, 2025 at 7:24 PM
    #99
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    Nice, you will love them. Hands down the best all purpose tire I’ve ever run on my Tacoma.
    Canadian Caber likes this.
  20. Mar 14, 2025 at 4:53 PM
    #100
    Hilborn
    Michael
    Utah
    Currently in Moab. Tires did great in loose sand and loose rock. Aired down to 20 psi. No serious offroading. Just light trails. They do like to pick up and throw rocks. They did very nice on the way here through the mountain passes during a light snow storm.
    Road_Warrior and Squirt like this.
