New Yokohama A/T4 G018
Discussion in 'Wheels & Tires' started by Hilborn, Jun 24, 2024.
  1. Mar 14, 2025 at 7:43 PM
    #101
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    That’s good to know. I’m hitting Moab in the fall with these tires and I was wondering how they will do in the desert.
    theluharlifestyle and Squirt like this.
  2. Mar 17, 2025 at 6:32 PM
    #102
    theluharlifestyle
    theluharlifestyle Well-Known Member
    Parth
    SoCal
    2019 DCSB TRD OR
    I'm trying to decide between these, copper stronghold at, and copper rugged treks. Three different tires but in 285/70r17 they're all similar weights.Currently running the ridge grapplers.
    These seem like a good compromise between some ruggedness and on road compliance
    Road_Warrior and Squirt like this.
  3. Mar 27, 2025 at 4:44 PM
    #103
    Chase8059
    Chase8059 Kinda Well-Known
    Chase
    ESVA
    2015 DCSB TRD Sport | Super White : 2008 Lexus IS 350
    OME 887, JBA UCAs, 1.5 AAL, Fox 2.0 RR w CD adj., SCS SR8s Gunmetal, Falken AT3/W 265/70r17
    Can anyone compare road noise of these to the Cooper ST Maxx? I'd have to believe these would be quieter. My second set of coopers haven't worn great and after rotating them this last time I'm getting considerable shakes at 50mph. I'm over them and they are a tad overkill anyways, but would like to stick in 255/80r17 size and these look like a great less aggressive option.
  4. Mar 27, 2025 at 4:49 PM
    #104
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    I’ve never run the ST Maxx’s but the Geolandars are a lot quieter than my old Grabber ATXs, which are a less aggressive all terrain than the ST Maxx’s. Idk if that helps at all.
    Out of all the AT/MT tires I’ve had, these are the quietest. Feels/sounds like you’re on a highway tire when you’re on the pavement.
    Chase8059[QUOTED] likes this.
  5. Mar 27, 2025 at 4:57 PM
    #105
    Chase8059
    Chase
    ESVA
    Appreciate it! I've eyed the X ATs also but they are a tad more aggressive.
    Road_Warrior[QUOTED] likes this.
  6. Mar 27, 2025 at 5:26 PM
    #106
    Chase8059
    Chase
    ESVA
    Placed an order for 255/80r17s in eBay from Priority Tire. $990 for a set, a tad over 1k after taxes. Not a bad price at all.
    I'll post photos once they are mounted up
  7. Mar 27, 2025 at 6:04 PM
    #107
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    Nice! You won’t regret buying them. I’ve put about 20K miles on mine since I got them and they’re awesome tires. Literally drove to the other side of the country and back right after I had them mounted and I’m doing the same trip again with these tires in the fall.
    Whenever this set wears out I’m definitely buying them again. I’ve run a bunch of different tires on my taco and these are by far my favorite and the most practical.
    Also, Yokohama has the best customer service of any company I’ve ever dealt with…ever. It’s a long story but they definitely have a customer for life here.
  8. Mar 30, 2025 at 11:44 AM
    #108
    pillio35
    pillio35 New Member
    Have you ever had the wrangler territory MT's or cooper AT3 XLT before, and were these quieter and better MPG than those?
    How is the treadwear so far too?
  9. Mar 30, 2025 at 11:47 AM
    #109
    Hilborn
    Hilborn [OP] Adventure First. Safety Second.
    Michael
    Utah
    2009 Tacoma DCLB TRD Sport 4x4
    ADD W1 Oil Catch Can. AFE Magnum FORCE Stage-2 Si Cold Air Intake System. AlphaRex Black Pro-Series Headlights. Anderson Engineering Solutions Manifold Spacer. ARK Splash Guards. AVS Door Sill Protectors. BAMF Bolt-On Rock Sliders. BAMF CMC Plates. BedRug. Brute Force HC Rear Bumper. C4 Engine Skid. C4 Transmission Skid. C4 Transfer Case Skid. C4 Fuel Tank Skid. C4 Rear Diff Skid. Cooper Discoverer ST Maxx LT285/70R-17. Dirt King Ball Joint Upper Control Arms. Dirt King Lower Control Arms. Dirt King Spindle Gussets. Doug Thorley Y-Pipe. DRT Fabrication Shackle Hanger Kit. Eaton Detroit Trutrac Rear Differential. ECGS Bushing. Expedition Essentials Bedside ARB Air Compressor Mount. Garmin Overlander GPS. Genesis Gen 3 Dual Battery System w/ G Screen. HCF Delete. Husky Floor Liners. Hypertech In-Line Speedometer Calibrator (@1.038). IGGY Switch Panel. Ironman4x4 Foam Cell Pro Struts and Shocks. KPOffroad Alignment Cam Upgrade Kit. Leer 100XQ. Magnaflow Overland Series Cat-Back Exhaust w/ 10416 Muffler. Method Vex Titanium 17x8.5. Yukon 4.56 Gears. Odyssey Performance Group 34 Batteries (2). OME 886x Coil Springs. OME Carrier Bearing Spacers. OME CS047R Dakar Leaf Springs w/ D29XL. Overland Torque Tune. Pakrax Tailgate Panel. Pinch Weld Mod. Pop n' Lock. Power Stop Z36 Truck and Tow Brake Pads. rcbs204 Illumited 4x4 Switch. Rear Differential Breather Relocation. Rexing V1 Dash Cam. Scanguage 2 w/ TFT. Stahlbus Oil Drain Plug. Stoptech Cryo-Treated Rotors. Sway Bar Delete. Total Chaos Bed Stiffeners. Toyota 70mm Throttle Body. ToyTec Axle Degree Shims. URD 170° Thermostat.* URD 65 to 70mm Throttle Body Adapter. URD Exhaust Cam Gears. USA Spec IPod Interface. Voltage Booster Pro. Wheeler's Brake Lines. Wheeler's Front SuperBumps with 3/8" Spacers. Wheeler's U-Bolt Flip Kit w/ SuperBumps.
    Cooper AT3s have been discontinued.
  10. Mar 30, 2025 at 11:55 AM
    #110
    pillio35
    pillio35 New Member
    The Cooper AT3 4S is discontinued, but the one I'm wondering about is the AT3 XLT. Either way, it would be nice to know a point of reference.
  11. Mar 30, 2025 at 12:06 PM
    #111
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    I’ve never had either of those tires. I’ve previously run these on my Tacoma:
    General Grabber ATX, Yokohama g003, Maxxis Razr MTs and then the crappy factory Toyos of course.
    These are the quietest tire I’ve had on the truck. Treadwear is fantastic, as of today I have 17,000 miles on them and they still look new. It is worth noting that mine are E rated.
    I suspect I can get 100,000 miles out of these if I wanted to take them down to the wear bars. I do a ALOT of highway miles and always run E rated tires, which helps with treadwear on these lighter trucks.
    Squirt likes this.
  12. Apr 2, 2025 at 11:52 AM
    #112
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    Quick update that some may find useful about the treadwear on these tires.
    Mine are E rated LT285/75/16. Yokohama has them listed as starting with 18/32” tread depth new.
    I just had my truck serviced and the tech put the tires at 15/32” front and 14/32” in the rear. The tires have just over 17K miles on them so far, for reference.
    I’m not an astronaut but if I’m doing my math right, and I wanted to really live dangerously and take these down to the wear bars, that means I could get well over 100K miles out of them.
  13. Apr 2, 2025 at 6:28 PM
    #113
    Chase8059
    Chase
    ESVA
    255s came in. Only took 3 days from eBay. Waiting on my new hubs and bearings then I'll get them mounted. Love the more tamed tread pattern compared to my ST Maxx and the sidewall does still have a mild aggressive look.
  14. Apr 2, 2025 at 6:34 PM
    #114
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    Nice!! They look awesome in the skinny version. I do love the tread pattern on these. They look a lot like the Open County AT3 to me.
  15. Apr 2, 2025 at 7:30 PM
    #115
    Chase8059
    Chase
    ESVA
    My buddy said they remind him of his old terra graplers
  16. Apr 3, 2025 at 4:37 AM
    #116
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    Oh yeah I can see that too!
  17. Apr 5, 2025 at 5:05 PM
    #117
    TacoTuesday25
    TacoTuesday25 Member
    Greenville, SC
    I’m eyeballing the same set of tires to replace my 285 Toyo A/T iiis.
    Edit:
    Looks like with Yokohama rebate, 5% military discount, including tax they would be $1164 for 5 at Discount Tire without install shipped to a store. Not too shabby.
    Following to see how they look.
  18. Apr 7, 2025 at 2:09 PM
    #118
    Ghost09
    Ghost09 Well-Known Member
    265/75/16 Yokohama Geolandar A/T4 (G018) on 16x8 Enkei RPT1 ET 0
  19. Apr 7, 2025 at 2:20 PM
    #119
    shnichol
    shnichol New Member
    2002 Tacoma Xtra Cab Manual
    Finally got mine mounted today. So far I'm impressed with how quiet and smooth they are. I was worried going from a P rated tire to a E rated would be a significant ride difference, but so far its not even that noticeable. I'm running LT265/75-16 at 35 psi for reference.
  20. Apr 22, 2025 at 3:45 PM
    #120
    Chase8059
    Chase
    ESVA
    Got my 255/80r17s installed. I also had new front hubs and bearings done but these tires are smooth and quiet! Love em so far after driving home from the mechanic.
