Newb Alert...have a few questions!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Smartin426, Jun 23, 2016.
  1. Jun 23, 2016 at 12:30 PM
    Smartin426
    Smartin426 [OP] Member
    Hi guys,
    I am completely new to this forum. I had a FJ Cruiser before acquiring my 2016 Tacoma TRD Sport 4x4 in Grey. Couple questions, and sorry if they have been covered, I am a motorcycle guy so dont know a lot about moding trucks.
    First, has anyone had issues with their speedometer? I do, It dosnt work half the time or completely malfunctions and the needle acts like a "ticking" similar to some second hands on clocks. Only 13,000km on the truck. I have a video I can post later. I have mentioned this to Toyota, which it has now been escalated to Toyota HQ to see if this is a one time thing, or happening to more trucks..haven't heard back yet, or about my appointment to have it fixed.
    Secondly, I just won a sick set of rims in a golf tournament for my truck. I stuck with the 17's cause of more tire options, however I am curious the largest tire size I can go without needing a lift. I dont want to mess with the truck and jack it up as its my daily driver. However I want some beefy tires just to make it look a little better with the matte black rims. Stock is 265/65/17, the new rims are 17x7.5 with a 20mm offset..any suggestions?
  2. Jun 23, 2016 at 1:32 PM
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    20MM offset of gonna be REAL close to rub, your only plus is the 7.5 width that could help some.
    Smartin426[OP] likes this.
  3. Jun 23, 2016 at 1:35 PM
    Smartin426
    Would you suggest I get some Spidertrax 1.5" spacers?
    I imagine a 265/70/17 will fit especially if I get spacers?
  4. Jun 23, 2016 at 1:56 PM
    stan23
    stan23 Well-Known Member
    stan
    Santa Clara, CA
    2025 DCSB TRD Sport 4x4
    1. Yes, the speedo problem has been reported here, as well as the 2nd gen. There is no real root cause other than dealer replacing the gauge cluster - which may or may not happen again.
    2. 265/70/17 seems to be the preferred size for folks that want to have a slightly beefier tire and retain stock handling characteristics.
    Garyji and Smartin426[OP] like this.
  5. Jun 23, 2016 at 1:59 PM
    Smartin426
    Great thanks for the info, would you happen to know if I should run spacers due to the 20mm offset? Im skeptical about spacers, I know there are lots of talk about it on this forum, but something about bolting something behind your wheel gives me a scare...
  6. Jun 23, 2016 at 2:06 PM
    stan23
    stan
    Santa Clara, CA
    Welcome ! i'm also a motorcycle fanatic (supermotos) and there are quite a few of us here.
    IMO, and just MO - i'm not a fan of wheel spacers. I would buy a set of wheels with proper offset, or not run them at all. I come from an old school background where I don't like to introduce variables in the drive train. You're basically adding a point of failure.
    Here's a great calculator with view-able differences: The stock sport wheels have 30mm offset, you're running 20mm. Which means 10mm further out. I would be fine with that.
    SothernTaco likes this.
  7. Jun 24, 2016 at 11:23 AM
    Smartin426
    Awesome, that's all I needed to know, if the stock sport wheels are 30mm then the 20 will be no issue. No need for spacers I am cool with that. Thank you very much! Now to order tires and mount them up!
  8. Jun 24, 2016 at 11:38 AM
    stan23
    stan
    Santa Clara, CA
    Just for reference the SEMA TRD Pro wheels everyone has here has a 4mm offset, and many are running stock suspension with 265/70/17 and reported no rubbing.
    Well sorta; seems some folks with OEM mudflaps will rub, and some won't. Probably just manufacturing tolerance thing.
