NEWB Lift Questions
Discussion in 'Suspension' started by HipHead, Apr 13, 2015.
  1. Apr 13, 2015 at 1:46 PM
    HipHead
    HipHead [OP] Well-Known Member
    Jeff
    Gilford, Ontario
    09 Access Cab V6 4L 6 Speed TRD Off Road
    Weathertech bug deflector, Uguard side step, tri-fold tonneau cover, Weathertech floor mats
    I have a stock 2009 TRD AC 4X4 and I am looking at options to lift the truck 2" to 3".
    I have a recall notice from Toyota Canada indicating issues with the current 4/leaf pack.
    Was originally thinking to replace leaf pack with aftermarket to gain an increase in lift and call it a day. When I go for new leaf pack what considerations should I be looking for?
  2. Apr 13, 2015 at 1:54 PM
    16Tacos
    16Tacos Well-Known Member
    Zach
    Boston
    08 Access Cab 4x4 V6 SR5
    OME Nitrochargers w/886s & Dakars, ARB Deluxe Bull Bar w/Warn winch, RCI sliders with kick out, IFS & Mid skids, BFF Hi-clearance rear bumper, Brushed Copper 17" SCS Ray10s w/285-70 KO2s, Black OEM 16" steelies w/255-85 KM2s, Leer contractor cap w/Smittybilt overlander xl RTT, Off-Grid Engineering dual battery kit and bed power panel, Blue sea aux fuse block, Wyntner 60L fridge freezer, ARB dual compressor, Pioneer 720BT head unit, CB radio, @Matt_Gecko bed and engine bay lights, @TacomaTruckParts Dirt bike tie down bar, color matched OEM grill, A-Pillar phone mount mod, @Docloco rear seat molle panel
    I'm installing an OME (Old Man Emu) 2" lift on Wednesday (actually gives ~2.5-3" depending on spring choice). The full kit comes with new leaf springs/shocks, and new front struts. The spring choice for the front will be determined by whether or not you have a steel plate front bumper/winch (886 springs) or if you want a full 3" (887s and maybe a top plate spacer), or just a modest lift without any extra weight on the truck (885 springs). You can buy the full kit or individual parts.
    You can also just AAL (add-a-leaf) to the stock leaf pack.
  3. Apr 13, 2015 at 1:56 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    His leafs might be on the way out..he's an 09
  4. Apr 14, 2015 at 12:56 PM
    HipHead
    Jeff
    Gilford, Ontario
    Yup. The recall will take care of the original 3 + 1 leaf springs.
    So I am going to replace with aftermarket leaf springs.
    When I visit the spring shop I want to be informed as to the leaf springs I should be considering for my 2009. The spring shop has independent manufacturers that supply their leaf springs.
    All that being said I am looking for roughly 2" or 3" of lift. I would assume I should be looking for heavy duty leaf springs? Dimensions?
  5. Apr 14, 2015 at 12:58 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Dakars if you haul or tow ever
  6. Apr 14, 2015 at 12:58 PM
    geekhouse23
    What are some of the names of the independent manufacturers?
    If it were me, I would go with something well known.
  7. Apr 16, 2015 at 6:18 AM
    HipHead
    Jeff
    Gilford, Ontario
    The new leaf springs are considered heavy duty and rated for 1650 lbs.
    The standard OEM springs are rated for 1250 lbs.
    The springs are distributed by Dayton parts and manufactured in Texas.
    The shop would install the new leaf pack and if necessary adjust the springs for a 2" lift.
    New leafs spring pack = $850
  8. Apr 16, 2015 at 6:19 AM
    geekhouse23
    Dakars were $369 for me from Headstrong offroad. Plus $69 for shipping but damn $850..that's insane.
  9. Apr 17, 2015 at 6:34 AM
    HipHead
    Jeff
    Gilford, Ontario
    Will a new leaf pack and 2" of lift require new rear shock absorbers? Brake lines?
  10. Apr 20, 2015 at 8:13 PM
    alexkontos17
    alexkontos17 Well-Known Member
    Alex
    Orlando
    97 tacoma
    It shouldn't everything I have read says you only have to worry once you go above 3"
  11. Apr 21, 2015 at 8:21 PM
    HipHead
    Jeff
    Gilford, Ontario
    K. Thanks.
    Thinking I will have the HD spring pack installed.
    Then maybe go with Billies on 4 corners.
    Step one is to have new leaf pack installed.
    Will take before and after pictures.
  12. Apr 27, 2015 at 7:54 AM
    HipHead
    Jeff
    Gilford, Ontario
    HD leaf pack installed and gained 1.75" lift.
