Newb Mistake?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 20somethingwidataco, Apr 22, 2018.
  1. Apr 23, 2018 at 8:18 PM
    20somethingwidataco
    20somethingwidataco [OP] Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap AC drip line mod
    Ya
  2. Apr 24, 2018 at 10:11 AM
    20somethingwidataco
    Will
    Washington State
    Any more ideas before I start tearing apart my tacoma again? Think I'll check the connections at the speaker first, maybe plug in a different speaker to see forsure if it's the wires, then start pulling wire to see if it's cut or pinched somewhere
  3. Apr 24, 2018 at 10:36 AM
    MallTaco
    MallTaco Member
    Think that's all you can do. Looks like you have two choices. 1 is try a different speaker and see if its the speaker or the wire going to the speaker.Or 2 if that right rear is on ch4 of the amp move it to say ch3 that is working and see if the trouble follows the wire/speaker. From what you said you did the trouble has to be right there at the amp. But hey crazy things happen if you have the luck i have :censored:
  4. Apr 24, 2018 at 12:40 PM
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    1. Run a cheap set of RCA's, across the seats, from the headunit to the amp to rule out the cable and connections.
    2. Double check speaker wire connections and potential pinch points. Double check the speakers and polarity.
    3. Swap out the head unit for an old/another headunit if possible, to rule out your head unit.
    4. None of the good Amp manufacturers are perfect and components do sometimes fail. If it is a dead channel, Alpine amps are roughly $100 to get repaired door-to-door by an authorized Alpine repairer, which is somewhat reasonable (I took apart my PDX to board diagnose, it took me 3 hours altogether, and I had access to tools if stuff needed swapped) - so I think the $100 is reasonable as long as its reliably fixed in the end. Make sure you don't keep running/idling the amp while its like this, as the problem make become more complicated, and stress other components downstream - or burn a speaker voice coil if its throwing DC out.
  5. Apr 24, 2018 at 1:13 PM
    scotch
    scotch Well-Known Member
    Mark
    Centennial, CO
    2012 Tacoma, 2015 Tacoma, 2005 4runner 4.7L
    Lots of Stuff
    this, you might've yanked the wire from the connector pulling thru your carpet
  6. Apr 24, 2018 at 1:51 PM
    Buckwheat893
    Buckwheat893 Well-Known Member
    Cody
    Tucson, AZ
    2011 AC
    To me it seems like it’s one of five things:
    1: RCA cable disconnected from pre out on head unit
    2: wire to speaker itself became disconnected either at the amp connection or somewhere between amp and speaker
    3: bad RCA Cable
    4: internal component failure of the amp itself
    5: bad Pre out on head unit
    Run a different set of RCA’s, check the speaker wiring, check the head unit, and if all the above yields nothing, then I think it’s safe to say the amp is the problem. If that process gets you nowhere, I don’t know what to tell ya
  7. Apr 24, 2018 at 2:17 PM
    20somethingwidataco
    Will
    Washington State
    Whelp thanks guys. I'll try out these things. Hopefully it's just the speaker wire got messed up. I'll strip a little more wire back and put them back in the amp slots to see if that helps, then go to the Rca idea. Bye bye Saturday
  8. Apr 24, 2018 at 2:27 PM
    Falconsfan
    Falconsfan Well-Known Member
    2017 sr dcsb v6 4x4 black
    You can pull the output wires off the offending channel and take a 9 volt battery and touch the wires to the contacts, you will hear it thump if the wires to the speaker and speaker is still functioning, I have used this method many times to wire vehicles where someone else got there first and made a mess of it. This also keeps you from unhooking what is already working just to test it.
  9. Apr 24, 2018 at 7:33 PM
    20somethingwidataco
    Will
    Washington State
    I'll have to test that. really just hopeing it's an easy fix. But with my luck it won't be
