Newb Question on budbuilt skid
Discussion in '1st Gen. Tacomas (1995-2004)' started by jessecain1, Aug 13, 2013.
  1. Aug 13, 2013 at 5:51 PM
    jessecain1
    jessecain1 [OP] New Member
    jesse
    Hey I'm new to Tacoma's and got to thinking I needed a new front Skid plate, because who doesn't right?:p. Anyhow I ordered one of budbuilts after reading some high praise here. Now I got to looking a little further on his website after I placed the order and noticed the plate I ordered doesn't say anything about if it's compatible with a lift (I have a 3" suspension lift) but he had another plate that said 4", and 6" lifts. Not sure if I ordered the wrong plate or not, because his sight isn't very clear on the descriptions of what is what. So will it work or do I need to give bud a Call?
  2. Aug 14, 2013 at 4:15 AM
    NCJeyota
    NCJeyota Well-Known Member
    Raleigh,NC
    2002 Tacoma 3.4 v6 Prerunner
    I have the OME 2.5 suspension lift on my Tacoma with the Budbuilt front skid plate and it fits perfectly . It is just very heavy to install. I usually use a jack in the middle of it, to stabilize it when I don't have any help around.
  3. Aug 14, 2013 at 4:24 AM
    taco47001
    taco47001 Newborn
    Aurora, IN
    LX470
    I believe the other versions of his skids that are for 4" and 6" of lift are designed to be used with the DB (Drop Bracket) lifts. At 3", you should be just fine...none of the attachment points are moved with a 3" "Suspension" lift.
  4. Aug 14, 2013 at 5:02 AM
    Large
    Large Red
    As long as you don't have a diff drop you should be good, if you have a diff drop you probably gotta lose it.
  5. Aug 14, 2013 at 5:06 AM
    taco47001
    taco47001 Newborn
    Aurora, IN
    LX470
    When I was researching skids I think I pm'ed him about this, as I have a diff drop installed. I believe his response was that they would work with the diff drop installed.
  6. Aug 14, 2013 at 5:12 AM
    Large
    Large Red
    I don't think I've seen a set of skids work with a diff drop, but chime back in when you get the skid and have it installed.
  7. Aug 14, 2013 at 5:28 AM
    taco47001
    taco47001 Newborn
    Aurora, IN
    LX470
    You're probably right about the bud builts.
  8. Aug 14, 2013 at 6:11 PM
    wrat
    wrat Well-Known Member
    Wyoming
    2004 Tacoma Xcab 4x4 TRD
    My setup: 2004 Tacoma X-cab, 4x4, OME 882, Dakar + D6XL
    I just installed the full budbuilts (thanks 45acp and Majikman!) with no problem. I do NOT have a diff drop.
  9. Aug 14, 2013 at 7:02 PM
    chvymechanic
    chvymechanic Well-Known Member
    Thomas
    New Hampshire
    04 Limited TRD Off Road 4x4 Xtra Cab
    Stuff and Thangs
    I have full Bud Builts with a diff drop, and still have about 1/4 of an inch clearance between the diff bolt and skid.
