newB QUESTION
Discussion in '2nd Gen. Tacomas (2005-2015)' started by avengedkevinfold, Jan 13, 2011.
  1. Jan 13, 2011 at 11:28 AM
    avengedkevinfold
    avengedkevinfold [OP] Well-Known Member
    Kevin
    Socal - OC - Huntington Beach
    bilstien 5100s all the way around, ICON progressive 3 leaf kit, Illegal tint, snuglid SL, seatbelt chime mod. light racing UCAs
    what does TSB stand for when people talk about "TSB rear leaf pack"?
  2. Jan 13, 2011 at 11:30 AM
    neontrail
    neontrail ✈ ✈ ✈ ✈ ✈ ✈ ✈
    Idaho
    2004 NISSAN XTERRA XE/SE
    De-badged, Tint 20%, Blue 48 LED dome-light, .......
    toyota service bulletin
    Its a memo for Toyota Techs, its not really ment for the public to see.
    Search around and you will find TONS of info on the site
  3. Jan 13, 2011 at 11:31 AM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    Thought it was Technical Service bulletin?
  4. Jan 13, 2011 at 11:33 AM
    neontrail
    Idaho
    Maybe in Canada.
    J/k.... Yeah I think you are correct sir. :cool:
  5. Jan 13, 2011 at 11:33 AM
    imtwistd
    imtwistd Going nowhere as fast as possible
    I forgot
    Liverpool NY
    08 dbl cab long bed sport 4x4 beast
    AllPro offroad front LT with Fox 2.5 shox and AllPro expedtion rear springs with Fox piggy back res shox, TRD skid plate, Toyota roof rack, Undercover tonnuea cover, Pro comp 3" lift, 4 Pro comp 8" offroad lights, 17" XD Series "SPY", Nfab tube steps and light bar, Fitch Fuel, Flexalite fan, Unichip, URD cai, TRD supercharger, URD y-pipe, Banks monster cat back, debadged, projection head lighs, LED tail lights and a loud stereo, Stainless Steel Brake Lines front and rear, Doug Thorley long tube headers, Walboro 255 fuel pump, KC rock guards on my Pro Comp 8" lights
    Same thing just worded differently.
  6. Jan 13, 2011 at 11:35 AM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Technical Service Bulletin. It's instructions to the dealerships on how to fix a common problem that Toyota has recognized and come up with a planned diagnosis and solution.
    The rear spring TSB is because they make the trucks to ride smooth. But when you try to load them up with weight, they bottom out in the back and ride on the bump stops making the ride rough. So this TSB addresses that problem by replacing the rear leaf springs with another one that has an additional leaf in it.
  7. Jan 13, 2011 at 11:35 AM
    ruslanus
    ruslanus Well-Known Member
    Rus
    Wasilla, AK
    Either way it's a Service Bulletin :)
  8. Jan 13, 2011 at 11:37 AM
    BeefTaco
    BeefTaco WESTern Alliance: NORCAL COAST
    Santa Cruz County Ca.
    TSB: (Technical Service Bulletin) which is a communication between Toyota and its dealerships that can serve as an update to Toyota publications, describe parts updates, or relay enhanced or new service procedures. Service procedures may explain diagnostic steps, implementation of recommended updates, or how to perform certain repairs.
    SSC: (Special Service Campaign) If Toyota determines that a defect exists and decides that the defect is “related to motor vehicle safety,” per the Safety Act, the company will conduct a safety recall. In addition, for issues that are not “safety-related defects,” the company may decide to address a condition found in the field to enhance customer satisfaction. Sometimes the company may address such issues through a Special Service Campaign (SSC), under which vehicle owners are provided a free repair.
    TAS (Toyota Assistance System) Located in Torrance Ca. it is where technical information is gathered by Toyota. When a tech in the field is unable to find a fix for a vehicle they are repairing they contact TAS. TAS will then assist in the repair by searching there data base for similar repairs and assist in the repair and will then open a case number that the tech will have to close at the end of the repair. The information gathered during this repair will be input to the data base.
    FTS (Field Technical Specialist) In the event the dealership is unable to repair a vehicle they may call out an FTS from the region headquarters one FTS may cover 6-8 dealerships. These guys are usually x dealership MDT's (Master Diagnostic Technician's) that have been hired by the Toyota to assist in repairs at the dealership level. :cool:
  9. Jan 13, 2011 at 11:55 AM
    neontrail
    Idaho
    rep sent to beefTaco! Nice post
  10. Jan 13, 2011 at 12:40 PM
    BeefTaco
    Thanks Neon!
  11. Jan 28, 2011 at 3:55 PM
    Tacozoid
    Tacozoid Well-Known Member
    Terry
    Katy Texas
    White Tacoma Pre-runner
    Billsteins,Texas tint. Blue Dash mod. Console mod. in Blue, Customized grille
    Basically a TSB is Toyota telling their dealerships that there is a problem but unless they get bugged to death, don't fix it. All Car companies do this. It's screw the consumer. No need for a recall. That's why My rear springs are shot and I am out of warranty. I'll just get air bags. It's one of the industry secrets. Stick 'em when you can and don't tell. The sooner you can check a TSB the better chance you MIGHT be in luck.
