Newb question
Discussion in 'Suspension' started by TG8, Mar 19, 2011.
  1. Mar 19, 2011 at 5:38 PM
    TG8
    TG8 [OP] Well-Known Member
    Trey
    Laredo, Texas
    2011 Tacoma Trd Sport 4x4
    STOCK STOCK STOCK SUCK STOCK STOCK WeatherTech Floor Mats All-Weather throughout the truck Smittybilt Bull bar with Hella 500 Series Halogen Driving Lamp (2)
    What i would be the greatest ideal lift from
    3-5' considering not having Any harm to my taco and if will affect wheel
    Alinement or raise gas price
    I'm considering putting either 18 or 20' rims maybe rockstar unless if there is a better off road rim and also putting 33' or 35' bf mud terrain
  2. Mar 19, 2011 at 5:43 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Just getting the more aggressive tires alone will effect your MPG...and the bigger you go...the less MPG as well. Most of use around here do 3" lifts with 285s or 33's. Old Man Emu makes a great lift and so does Toytec...any additional info you need can be found using the "Search Fuction"
    Also anything over 2.5" of lift requires new UCAs to get your alignment right...
    :cool:
  3. Mar 19, 2011 at 5:44 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    You wanna put on 35's but not affect gas mileage ?
  4. Mar 19, 2011 at 5:46 PM
    ColtsTRD
    Scott
    AZ
    Thats like wiping before you poop....it doesn't make sense :laugh:
  5. Mar 19, 2011 at 5:48 PM
    darkgreentaco
    darkgreentaco XXXL Member
    NorCaL
    Timberland Rocket
    King RR C/O's, Extra mustard, All-Pro expdtn Leaf, sesame seed bun, Icon UCA's Fox Resi's BAMFsliders, sweet candy coating, LCAskids, diffcover 17" Addicts Yukon 4.56 Mt/r kevlar
    hey man, your lift better not raise our gas prices!
  6. Mar 19, 2011 at 7:42 PM
    DevL
    DevL Well-Known Member
    There really isnt a lift between 3" and 5" its really an either or type thing.
    You will want, from your description, 4.5" RCD lift, and 33" tires with 4.10 gears. For rims... a better rim than Rockstar for offroading? Uhh... I thinks that pretty much any rim as that would be the WORST offroad rim choice possible on any level. You want to try to find the lightest tire possible to reduce lost milage too... probably a BFG KM2 as a compromise.
  7. Mar 19, 2011 at 7:48 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I'm totally guessing here.
    But I bet the RCD drop bracket lift and 20" rockstars with 33" 305/55R20 BFG-AT KOs would work well for what you want.
    Now, it's possible that I'm totally wrong. But you haven't told us much about how you plan to use your truck, have you?
  8. Mar 19, 2011 at 8:34 PM
    Phuket
    Phuket Well-Known Member
    Travis
    Los Angeles
    03 4X4 TRD
    Eibach/Toytec coils, bilstein 5100's all around, Kenwood DNX7100 Navigation
    thats my new sig hahaha
  9. Mar 19, 2011 at 11:26 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    x2
  10. Mar 19, 2011 at 11:47 PM
    TG8
    Trey
    Laredo, Texas
    I go messing around a lot mainly mudding and offroading
  11. Mar 20, 2011 at 11:51 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    OK, once you get offroad past the "fire road" stage, it's pretty typical to air down your tires. How much is a different question...
    But when running a low profile tire such as 55, you can't air down very much.
    So it's typical to run a 75 series tire such as 285/75R16, rather than a low profile 'off road' tire on a tall rim such as an 18 or 20" rockstar.
    The harder the trail, the more treacherous it is to have a high center of gravity. And drop-bracket lifts such as RCD et. al. lower the front differential and axle components, so they don't really increase clearance over much over the center vs. a 3" lift. (Yes, they WILL have higher breakover/approach/departure angles)
    So trail driven tacomas often choose just a 3" lift such as OME, Toytec, or coilovers by Fox/Icon/Camburg/etc...
    Have you high centered your truck yet on roads/trails you drive?
    There's lots more info in the "sticky" threads at the top of this forum you can read through.
  12. Mar 20, 2011 at 11:55 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Also, running big heavy tires is gonna hurt your gas mileage. No two ways around it.
    You're likely going to get driveline vibes.
    Final word: go down to your local wheelin' areas and see what setup folks who're actually off-roading their Tacomas are running.
  13. Jun 17, 2012 at 3:43 AM
    ToyComa84
    ToyComa84 Well-Known Member
    Matt(hew)
    "flatland"
    03 prerunner sr5
    plasti dipped wheel caps,
    Nice! aLf (a Lotta funny), alf (a little funny):thumbsup:
