Newb Question
Discussion in 'New Members' started by phynyx38, Jun 4, 2009.
  1. Jun 4, 2009 at 7:26 AM
    phynyx38
    phynyx38 [OP] Believe
    San Antonio, TX
    08 Tacoma PreRunner
    Ok I searched for this but couldn't find anything. I hope this is the right place to ask this. Anyway what is rep? How do you get it? How do you give it. How do you know you have it? And any other info you can give me. Thanks.
  2. Jun 4, 2009 at 7:30 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Look under your pic to the right there is a scale, thought buble, and what looks to be a hazzard sign. Click the scale located all the way to the left.
    Rep is reputation, given when somone does something good or is helpful. You can also get negative rep. Leave a name when you give rep.
    The green boxes under you name indicate how much you have. Pass your mouse over the geen boxes and a saying will pop up. You can check your rep by going to user Cp, click it then scroll all the way down and you will see peoples comments. Hope this helped.
  3. Jun 4, 2009 at 7:31 AM
    phynyx38
    San Antonio, TX
    08 Tacoma PreRunner
    Thanks for the info.
  4. Jun 4, 2009 at 7:33 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    added more to the first post I made.
  5. Jun 4, 2009 at 7:41 AM
    phynyx38
    San Antonio, TX
    08 Tacoma PreRunner
    Thanks it helped alot.
