Newb with coilover question, help...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NaZRaQ, May 31, 2015.
  1. May 31, 2015 at 9:50 PM
    NaZRaQ
    NaZRaQ [OP] Well-Known Member
    Zee
    Denver
    2024 TRD OR Tacoma hybrid
    hello, I purchased a set of nice coilovers from a friend, went to install them but ran into an issue. I get the top three bolts in but the bottom mount is in a slight angle to where it should sit so wouldn't go in... So had to put the stock back in for now. I had toytec lifts put on new caps and bushings, can the top bolts be realigned ? Going to see what they can do, but thought maybe someone else had this issue too... Thanks!
  2. May 31, 2015 at 10:27 PM
    NaZRaQ
    Zee
    Denver
    Thanks, the lca tabs are low enough to accept the shock with just removing the 2 bolts from the ball joint. i will ask toytec if they can rotate the shock but I would think they had something to go by when putting on the new caps, or maybe that has nothing to do with it.
  3. May 31, 2015 at 10:28 PM
    CayucosTacoma
    CayucosTacoma Just think outside the Yota
    San Luis Obispo/San Jose
    2004 Double Cab 4x4
    Specs in the Build Thread
    you can put a large screw driver or something in the bottom shock mount and rotate it, wont hurt anything
  4. May 31, 2015 at 10:35 PM
    NaZRaQ
    Zee
    Denver
    I will give that a shot, thanks!
