Newb with frame replacement questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by masspete, Oct 5, 2016.
  1. Oct 5, 2016 at 8:13 AM
    masspete
    masspete [OP] New Member
    2004 Tacoma Double Cab, 243,000 miles and getting a new frame. I'm gonna replace the shocks (looking for advice) and the rusted rear bumber. Looking for other ideas on what to replace while the frame is off.. Budget is around $1000.00.. Last year I did timing belt, water pump, plugs and wires, brakes.. My rear differential is leaking also... Any advice is welcome.. I'd like to get another 100,000 miles out of it! :)
  2. Oct 5, 2016 at 10:38 AM
    TRDanOR
    TRDanOR Well-Known Member
    Danny
    NB Canada
    02 trd or 4x4 step side
    stock
    shocks for shure get front end checked my bushing on my steering rack were done .truckgoing to ride like new.getting lots of new parts.
  3. Oct 5, 2016 at 2:30 PM
    ghs57
    ghs57 Well-Known Member
    Chops
    Catskill Mts. NY
    '17 Grey TRD OR xtracab 3.5L 4WD
    Pretty much stock right now
    I had them take care of a few engine leaks while they had the engine out. Rear main seal etc. I had already done my suspension over, so they reinstalled my parts on the new frame. If you need an exhaust system, it might be a good time, although they are not that hard to do. Tie rod ends might also be good since they will have to aline it anyway. Anything like that that it may need would be a good idea if within your budget.
    And it did ride like new. There will be quite a few new parts included in the replacement.
    TRDanOR likes this.
