Newb with question. Yes, I have searched, lol.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BigHeadTaco, Jan 4, 2013.
  1. Jan 4, 2013 at 10:59 AM
    BigHeadTaco
    BigHeadTaco [OP] GFY
    Big Head
    Full OME lift 885's with Dakar leaf springs. LR UCA's. ImMrYo relocation bracket.
    I just purchased certified used 2012 double cab TRD with 3700 miles on the odometer. It has 2" lift with 285/65/18 nittos and monster XD wheels. The issue/OCD I am having is that the rear passenger tire sticks out about 1/4" to 1/2" further than the rear drivers side tire. I noticed this and it has been driving me insane. Is this really common in the 2012's? I have read on here that adjusting the bed is simple. I have checked the offset of each rear wheel and they are exact, ubolts are tight. Could this be anything else? Any input is appreciated and I looked forward to being a part of Tacoma World.
  2. Jan 4, 2013 at 11:01 AM
    tacofire38
    tacofire38 Captain Taco
    Land o Pears,TX
    08 Taco PreRunner SR5
    V-Tech gunmetalrims, BFG All-Terrains, Front 5100s and OME 884 coils, Rear 5160s, Rear AAL, SpiderTrax Wheel Spacers, Hummer Bed Rack, Thule Kayak Roof Racks........
    Maybe the bed is off? BTW welcome to TW
  3. Jan 4, 2013 at 11:04 AM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Most likely. Op check the gap between your cab and bed see if they are the same
  4. Jan 4, 2013 at 11:05 AM
    BigHeadTaco
    Big Head
    Yeah, I read that as well. I am probably just being paranoid and need to adjust the bed. It drives straight as an arrow, I am going to check the bed alignment tomorrow
  5. Jan 4, 2013 at 11:07 AM
    Taco Dan
    Taco Dan Well-Known Member
    Dan
    Tuscaloosa, AL
    07 FJ Cruiser auto 4X4
    Snorkel, Cooper ST Maxx 255/80/17, diff breather relocate, Cobra ultra III cb radio set up Warrior Products front bumper
    this offset could have occurred when the truck was lifted. if both sides of the rear axle were lifted together,(when the ubolts were loose) then any bump to the axle or even bed could have altered it. this and not measuring from hub to frame could be the problem. during the rear lift, my guess was that the axle was free floating from the frame, not being torqued down with the ubolts, that it got miss aligned. does that make sense?
    to correct this, measure from hub to frame on each side of the axle to see if its off. if so, loosen ubolts, nudge axle back into alignment, and tighten ubolts back.
  6. Jan 4, 2013 at 11:07 AM
    tacofire38
    Land o Pears,TX
    If it were me i wouldnt worry bout it so much. Gives it character:p Pretty sure mine is off too lol
  7. Jan 4, 2013 at 11:11 AM
    BigHeadTaco
    Big Head
    Thanks guys, I think I am having OCD because it is my new baby.
  8. Jan 4, 2013 at 11:12 AM
    BigHeadTaco
    Big Head
    I will measure this tonight when I get home. Thanks for the suggestion!
  9. Jan 4, 2013 at 12:28 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    I dont see how the actual axle could shift unless it was like that before the lift. You might be right but the centering pin in the leaf springs should keep the axle centered.
  10. Jan 4, 2013 at 2:22 PM
    BigHeadTaco
    Big Head
    I guess 1/4"-1/2" is not too bad.....it could always be worse
  11. Jan 4, 2013 at 2:23 PM
    tacofire38
    Land o Pears,TX
    Just put some mean tires on and you will forget all about it haha
  12. Jan 4, 2013 at 2:44 PM
    BigHeadTaco
    Big Head
    It came with the 285/65/18 Nitto Terra Grapplers, they are surprisingly quiet
  13. Jan 4, 2013 at 2:46 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    if it isn't whats been suggested maybe they have a wheel spacer on 1 corner and forgot to take it off? :notsure:
  14. Jan 4, 2013 at 2:51 PM
    BigHeadTaco
    Big Head
    No wheel spacer, I removed both rear wheels to check the offsets of each wheel.
  15. Jan 4, 2013 at 3:09 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    Almost can guarantee it lol. Try to find a point where you can measure from the frame to the bed accurately on both sides.
  16. Jan 4, 2013 at 3:11 PM
    BigHeadTaco
    Big Head
    Going to check with a buddy tomorrow AM. I will put in a update of what we find out. I will try to get some pics as well.
  17. Jan 4, 2013 at 3:12 PM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2015 Jeep Wrangler Sahara
    Did the first owner do a body lift also. That could explain the bed being off
  18. Jan 4, 2013 at 5:45 PM
    BigHeadTaco
    Big Head
    nope, no body lift
  19. Jan 4, 2013 at 5:47 PM
    BigHeadTaco
    Big Head
  20. Jan 4, 2013 at 5:49 PM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    tint, dents, scratches, two blown speakers and trying to pay her off...
