Newb with questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by cjgill78, Apr 10, 2009.
  1. Apr 10, 2009 at 11:43 AM
    cjgill78
    cjgill78 [OP] New Member
    I've never owned a tacoma before, but I'm looking to possibly buy a 1st gen 4 cylinder tacoma with a 2.4L and a 5spd. I'm debating whether or not to get a 2wd or 4wd. I'll be commuting in this so gas mileage is a priority for me. Does anyone out there have real world mpg for a single cab 4wd 5spd with a 2.4 L ?? I've searched and found a lot of info on the 2wd 2.4L and the 4wd 2.7L but nothing has come up w/ the combination I'm looking at. Any info would be appreciated.
  2. Apr 10, 2009 at 11:52 AM
    Gr8WhiteTaco
    Gr8WhiteTaco bishes love my haircut
    Aaron
    Knoxville, TN
    SOLD 02 Double Cab TRD 4x4
    2005 Mazda 3S hatchback
    I dont know much bout the mileage numbers on the 4 bangers but do u plan on offroading or using 4wd?
  3. Apr 10, 2009 at 11:56 AM
    cjgill78
    No offroading. I work in the high country so I'll need 4wd for the snow in the winter time and mild mud on the fire roads, but that is the extent of my 4wd use.
  4. Apr 10, 2009 at 1:24 PM
    offroadTRD
    offroadTRD Well-Known Member
    Dinwiddie County, Virginia
    2000 Tacoma V6 SR5 4x4 TRD- Fabtech
    Fabtech 3" adjustable coil-over system, Alcan 8-leaf spring pack, Fabtech 3" body lift.
    I would definately get the 4x4. It's better to have it and not need it, than need it and not have it. I have a 2000 3.4L TRD 4x4 and love it. I only get about 16-17 mpg average but I am jacked up 6 inches and on 33x12.50 tires. My buddy has a 98 2.7L 4x4 and his is jacked up to on 33's. I think he gets about 15-17 mpg. The reason his is low is because the 2.7L has a little load on it with the 33's with STOCK gearing. But, the 2.7L motor is reliable as hell and never let him down. My V6 has never let me down either(knock on wood), and him and I drive our yotas very very hard, especially in hunting season. You can't go wrong with the 2.7 or the 3.4, but if you are worried about gas mileage, KEEP IT STOCK... don't jack it up unless you plan on gearing lower. I'm guessing you will get around 20 mpg with a stock 2.7 motor. Hope this helps.
  5. Apr 10, 2009 at 1:35 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    As a second gen owner, I am willing to say the first gen is a better build vehicle. If you have any question whether or not to get a 4x4 i would definitely get it. If you get bailled out even once for having it, then you have justified your decision
  6. Apr 10, 2009 at 1:42 PM
    rpoint16
    rpoint16 Well-Known Member
    Tempe, AZ
    2008 double cab, 4X4, V-6, TRD. Super White.
    OME 885 coils & front shocks, with TT top plate, Total Chaos UCA, Rear OME extended shocks, Rear TSB, Rear Toytec AAL, trimmed the saber-tooth-tiger-long-ass mud flaps. 17" XD Revolver rims, 265/75/17 BFG AT KO's. Ripped out the crappy FM Modulator & installed a PA-15-toy interface. OEM bed matt.
    I have had two different 95's. Awesome trucks! I wouldn't think a V-6 would be much more. The 4 bangers are solid though.
  7. Apr 10, 2009 at 3:57 PM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    Are you saying you are looking for a 4wd 2.4l because only the 2wd models came with the 2.4 and 4wd models and the prerunner came with the 2.7 and the 3.4. From what I've heard the 2.7 4wds got pretty good gas mileage.
  8. Apr 10, 2009 at 3:59 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    Welcome to TW :wave:
  9. Apr 10, 2009 at 7:43 PM
    cjgill78
    Someone had a '98 single cab 4wd 2.4l for sale on CL. After I called him and asked if it really had a 2.4L, he said he didn't know. I'm assuming now that its a 2.7L.
  10. Apr 11, 2009 at 6:20 PM
    2015 Sport
    2015 Sport Well-Known Member
    Wadesboro NC
    4X4 TRD Sport
    I had a 98 4x4 2.7 and i got 20-21 mpg. Go with the 4x4.
