newbe help not sure my locker is working
Discussion in '1st Gen. Tacomas (1995-2004)' started by Auto, Nov 2, 2009.
  1. Nov 2, 2009 at 4:48 PM
    Auto
    Auto [OP] Well-Known Member
    Delaware
    01 TRD SR5
    None Yet Some Coming Soon
    I have just bought a 01 TRD 4X4 and i need some help figuring out if my diff lock is working when i drop my truck into low range and engage the diff lock the light on the dash for Diff Lock blinks and the abs light comes on is this normal.
  2. Nov 2, 2009 at 4:50 PM
    -TRDMAN-
    -TRDMAN- ΜΟΛΩΝ ΛΑΒΕ
    Greg
    Clarion Pa
    F-150
    Sounds like the actuator is bad had the same problem on my 99 trd....
  3. Nov 2, 2009 at 4:59 PM
    Auto
    Delaware
    01 TRD SR5
    How can i test it to find out if it is bad. If it is where can i buy a new one or can i find a rebuild kit for the one i have.
  4. Nov 2, 2009 at 5:01 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Mine take a minute to lock up aswell...I think its the gears trying to get alligned. When you engage the locker try creeping forward slowly while turning your wheel slightly to the left and right
  5. Nov 2, 2009 at 5:10 PM
    Auto
    Delaware
    01 TRD SR5
    I have tried that and it seems like the locker is engaging. when i disconnect out of 4wd lo and the locker i get 2 clicks with i do not engage the locker and only put it 4wd lo and disconnect it i only get 1 click. is it possible that it is working but the sensor is messed up some way.
  6. Nov 2, 2009 at 5:59 PM
    Auto
    Delaware
    01 TRD SR5
    thanks guys
  7. Nov 4, 2009 at 10:50 AM
    matthew5olson
    matthew5olson Well-Known Member
    matthew
    pittsburgh, PA
    04 ext cab 3.4L 5spd 4x4 sr5
    K&N cold air intake, doug thorley headers, rear sensor simulator, flowmaster 40 series, magnecor plug wires, Royal Purple synthetic gear lube, airaid throttle body spacer, Hyperground system, flex-a-lite elec fan.
    go to a gravel lot engage the e locker and spin some tire. Look at the skid marks. You'll know if it engaged or not. Consider doing the grey wire mod. I love it. It enable you to use the locker in 2 or 4 hi as well.
