Newbe questions
Discussion in '4 Cylinder' started by AlaskanTaco, Sep 18, 2011.
  1. Sep 18, 2011 at 9:36 PM
    AlaskanTaco
    AlaskanTaco [OP] Well-Known Member
    Anchorage Alaska
    09 sr5 acc cab tacoma
    Hey guys.
    First off, let me start by saying, "I am an automotive tech," so i know my way around a car. Only issue is, I work on chevys all day, not yodas.
    So, with that out of the way!
    First, this TSB about the rear spring in the back...does it include access cab i4 manual tacos? The leaf squeals like it was in the movie, 'the deliverance.'. Is it the 4leaf pack, and do I have to pay extra for the 4 leafs?
    Second, what do you get out of leveling out the front end? What mpg are you guys seeing with a 2-3 inch lift kit? I would like at leaset 22.
    And finally, what is the difference between prerunner, sr5 and base models?? Thanks guys.
  2. Sep 18, 2011 at 9:41 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Rob
    Pacific Northwest
    2005 4x4 DC TRD Off Road
    11 Color Matched Grille, Pro comp 7089s, 265/70/17 Wrangler Duratracs, Black Running Boards, Tinted Windows, Bed mat, Weathertech Floorliners
    Welcome to TW!
    PreRunner is a 2WD on a 4x4 suspension, probably not popular in Alaska:).
    I think the consensus is that Bilstein 5100's are the best way to level the front end.
    White lithium grease has helped my leaf squeal.. But others may know more. Good luck!
  3. Sep 19, 2011 at 9:25 AM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    I'm pretty sure the leaf spring TSB only applies to V6 trucks, but I could be wrong. And it's not for squeaking leafs...it's called the "harsh ride" TSB. Basically this means your truck bottoms out and rides like shit with only a few hundred lbs in the bed.
    Best of luck, and welcome to TW. :)
  4. Sep 19, 2011 at 11:52 AM
    AlaskanTaco
    Anchorage Alaska
    Well, it looks like my, "4 wheeler," I loaded this weekend made it ride like crap. ;). Haha
  5. Sep 19, 2011 at 1:00 PM
    Hard
    Hard Well-Known Member
    H
    4X4X4
    The TSB is not only for 6cyl trucks. I had it done on my access cab 4 banger. If your truck has 4 rear leafs then it has an aal or the tsb already done.
  6. Sep 19, 2011 at 3:51 PM
    AlaskanTaco
    Anchorage Alaska
    Nope, I have 3 springs. :-/. Squeaks like hell
  7. Sep 19, 2011 at 4:33 PM
    AlaskanTaco
    Anchorage Alaska
    Just an FYI. I looked up the TSB on all data. It does cover 4 cylinder trucks. Access cabs and double cabs. TRD packages and non TRD packages 09-current. Must complain, "when truck is loaded, rides like crap."
