NEWBIE- 2013 Double cab Offroad 4x4 Tacoma...sorta disapointed.
Discussion in 'New Members' started by costaa1, Oct 20, 2012.
  1. Oct 20, 2012 at 7:29 PM
    costaa1
    costaa1 [OP] Member
    NJ
    I guess break in is what it needs...but 700 miles later...kinda annoying. I will take it to work tomorow, 80mile commute each way and see if it continues....Either way Im gonna get it checked out. Every tacoma I see on the road 2011-13 I ask them..and same answer is "no i dont have that problem"
  2. Oct 20, 2012 at 7:30 PM
    gasgasman
    gasgasman Well-Known Member
    Girard
    Texas
    Mine did the same thing.
    The transmission "learns" the way you drive.
    If you accellerate hard after you let off the throttle (all the time) the trans will anticipate that and down shift one gear.
    You can disconnect the battery for ten minutes, then drive the truck. After you coast gently ease into the throttle. May take 100 or so miles to "leard" your driving habits.
  3. Oct 20, 2012 at 7:32 PM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    id just deal with it, at least until the second oil change. shit like that will ease up as it gets broken in. also, mine has become considerably LESS noticable since i put larger/heavier tires on, and i can attest to the truck shifting down around 45-48mph, but it doesnt jerk my whole truck, its just a smooth down shift, as any other car ive driven does. just let it break in, and enjoy it in the meantime!
  4. Oct 31, 2012 at 6:50 PM
    cmghoughton
    cmghoughton Active Member
    Doug
    Northern VA
    2012 Tacoma
    BenWa power rear slider RollBak G2 Retractable Tonneau Bed Cover
    My transmission did the same thing for a while, or I guess I just got used to it. I figured it was just a truck thing.
  5. Oct 31, 2012 at 7:21 PM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    My '12 doesn't do this. Your not driving in 4th gear are you? I only ask because one time I must of bumped mine over by mistake & didn't notice until I let off the gas & it jerked forward. Luckily I wasn't diving at high speeds & I didn't go far before I noticed.
  6. Nov 2, 2012 at 2:27 PM
    GreenGoblin2012
    GreenGoblin2012 New Member
    Pittsburgh
    2012 Tacoma Trd Spt
    Bull bar and nerf bars soon.
    Is it just when you coast? My 12 does it when I hit the brakes and let off, almost like the down hill function switch is on, only i dont have that.
  7. Nov 2, 2012 at 2:41 PM
    mccarroll
    mccarroll Well-Known Member
    Newfoundland, Canada
    2012 DC 4X4
    ^^^this.
  8. Nov 2, 2012 at 2:51 PM
    1stacoma
    1stacoma Well-Known Member
    Austin
    2012 MGM SR5 DCSB 4.0
    5100's front and rear, front 2.5" rear 2" AAL, 18% tint front and rear, color matched grill. SCS wheels 275/70/17 BFG AT KO's. DTRL toggle switch.
    Mine did the engine brake when new either I got used to it or it stopped. I will check next time I drive it. I also came from a standard so it was really apparent. I will post back.
  9. Nov 2, 2012 at 7:21 PM
    agv1700
    agv1700 Well-Known Member
    Angel
    Black DCSB 4wd
    Welcome to TW!
