Newbie All in One 60k Maintenance
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ex_MGB, Jul 15, 2016.
  1. Jul 15, 2016 at 1:31 AM
    ex_MGB
    ex_MGB [OP] Member
    Hello, new member. I had my son's 2011 Tacoma 4.0 6-speed TRD Off Road Access Cab while he was overseas. When he got back we did the 60k service for which I put together a google doc which I'm uploading below.
    I noticed quite a difference after putting in the Redline 75W-90 vs. spec 75W-85 fluids. Doesn't thunk as loud engaging 4WD and just in general seems more smooth. I'm a big Redline fan, use it in all my other vehicles. We put on a Fumoto oil drain valve and the plan is to run Mobil 1 5W-30 EP for 10k intervals. Anybody else tried that? 5k seems overkill for that oil.
    We also worked over a 1998 Nissan Frontier X which he drove coast to coast and back to pick up household items and save miles on the Taco but that's another story. He's back and we swap out Sunday. Bye Taco! What an awesome vehicle.
    Please advise any tips.
    <iframe src="https://docs.google.com/document/d/1R0M2UTkVpuC_RGDrx9Ui7bZK53hQeGc63pkGR-2C7Ik/pub?embedded=true"></iframe>
    10trdtaco and Arailt like this.
  2. Jul 15, 2016 at 1:44 AM
    ex_MGB
    ex_MGB [OP] Member
    Meant to note that my method when changing out gear oils was to put a level on door sill while on ground and note bubble location, drive up on Rhino ramps, floor jack up rear at differential to get bubble same location and then put jack stands under the rear axle. BTW, I used Mobil 1 gear oil in the transfer case as I ran out of Redline.
  3. Jul 15, 2016 at 3:54 AM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Thanks 4 the tip - have to try.
  4. Jul 15, 2016 at 4:04 AM
    george3
    New Jersey
    Thanks for all the work on the doc. You must be a maintenance guy so just wondering why would you want to save so little and risk so much with a 10k oil change ? Oil filters are only effective for 7K at most - 10k is propaganda pushed by the EPA - BTW they are also pushing to get rid of all detergents in gasoline - wait to U C the effect of that.
  5. Jul 15, 2016 at 4:11 AM
    Lou Slink
    Lou Slink I like daags...
    Catskill, NY
    2013 TRD OR DCSB
    OME 886's, Total Chaos UCA's, Dakar's, BFG KO2's on Method Race Mesh Wheels, Bunch of All-Pro Goodies, Warn Zeon 10S Winch
    Nice write-up! Thanks for sharing. I will be doing this service pretty soon.
  6. Jul 15, 2016 at 4:21 AM
    george3
    New Jersey
    I do have another question "Do not use anti-seize on spark plugs, it will damage O2 sensors. Do not use lithium grease on hinges, etc., under the hood, it will damage O2 sensors." Where did this information come from and what do you use on the spark plug threads ? Spark plugs and head are dissimilar metals and can cause plugs 2 B "welded" in. What would you use for hood hinges ? Thanks for any reply and for all your work on TW.
  7. Jul 15, 2016 at 4:47 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    10k miles is fine for the oil. Even fine for the oil filter. You know, some manufacturer only require 1 oil change a year using synthetic oil.
  8. Jul 15, 2016 at 5:05 AM
    george3
    New Jersey
    To each his own. Manufacturers want to sell at $30k and up - I change my oil for less then $30 so ---
  9. Jul 15, 2016 at 5:12 AM
    topcathr
    topcathr Well-Known Member
    2015 limited
    how about a new cabin filter?
  10. Jul 15, 2016 at 5:17 AM
    george3
    New Jersey
    I made one (there's a link 4 that) and clean it every oil change. $$ once for the life of the truck.
  11. Jul 15, 2016 at 5:19 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    10K isn't propaganda. Plenty of guys run that long, there is a guy on here who is over 350K and runs 10k changes. You are misinformed.
    Arailt likes this.
  12. Jul 15, 2016 at 5:28 AM
    george3
    New Jersey
    Oh well - I live in my own little world and I'm happy there. Thanks.
  13. Jul 15, 2016 at 1:06 PM
    ex_MGB
    ex_MGB [OP] Member
    Long time BITOG member here. I know when Toyota had gear driven cams those engine were vicious on oil and prone to sludge. Mobil guarantees the EP for 15k miles, so 10K should be NP. I use extended range oil filters.
  14. Jul 15, 2016 at 1:12 PM
    ex_MGB
    ex_MGB [OP] Member
    Spark plugs actually come with a coating of sorts. Besides screwing up your O2 sensor, you get a false torque value using anti-seize. 30k spark plug changes are no problem in terms of removal. Platnium plugs at 80k get tougher with the carbon build up. I always torque spark plugs to 15 ft-lbs, there is a real tendency to under tighten if done without a torque wrench.
    Lithium lubricant will throw off fumes in a hot engine compartment which if drawn into the intake will damage O2 sensors. I just use a gentle application of Mobil 1.
  15. Jul 15, 2016 at 1:12 PM
    timothom
    timothom Well-Known Member
    2014 Tacoma Access cab sr5
    Kenwood DMX7705S PrecisionPower Phantom 900.4 Alpine type-r 8" Image Dyanmics CXS64.2
    Might want to put something in there about using sludge treatment in the oil. If you have cold winters it's usually a good idea every so often. I'm planning to do it at 30k changes along with the plugs.
    Basically it's a quart of cleaner (smells like diesel fuel) you put into your warm motor before you drop the oil. You run it for 5 minutes (don't rev it or it might bubble up because your a quart over full). Then you drop the oil and let it drain out real good.
    This is supposed to be good for the valve train and the top end of your motor. Gets all the goopy sludge out of there.
    Edit, link to the stuff:
    http://www.ruralking.com/gunk-5-minute-engine-flush-30-oz-mf3.html
    You can get it at any farm supply store or Napa, etc
  16. Jul 15, 2016 at 1:30 PM
    ausfahrt
    ausfahrt Well-Known Member
    FL & VT
    2015 SR5 MT 4X4 V6
    Extended range oil filters?
    I am not familiar with them. What is the difference from a regular oil filter?
  17. Jul 15, 2016 at 1:38 PM
    ex_MGB
    ex_MGB [OP] Member
    At a certain point you just accept "good enough". Mobil 1 5W-30 Extended Performance at 10k OCI is for me "good enough".
  18. Jul 16, 2016 at 3:47 AM
    ex_MGB
    ex_MGB [OP] Member
    I thought the cabin filter was an "add on".
    Anyhow, my son must have better hearing than me because he was bugged by a sound from the fan motor. He pulled it. I had told him to go to good bicycle shop and get some good syn oil, he instead got 3 in One. My theory is the original lube gets "crusty" (typical of all Japanese grease, guess the whale oil base goes bad especially high heat of an American summer).
    So, just pulling the motor we held it top bearing on top. Alternating between Mobil 1 applied with a "q"-tip and PB Blaster applied with a "q"-tip (squirt some in the cap to dip the "q"-tip in) and spinning by hand, it got worked in pretty good and when he put the motor back in, sound was gone.
    Note, we did not disassemble the motor as we could not get the screws loose as they are epoxied in place, just pulled it and oiled as above. I think the PB Blaster breaks down the crusty OEM whale oil based grease.
  19. Jul 16, 2016 at 3:54 AM
    ex_MGB
    ex_MGB [OP] Member
    Yeah, "extended mileage" is probably the correct term. Check the shelves on Wally World. Bosch is nice and even Fram has a 15k mile version.
    I keep my daughter's 1997 BMW Z3 running, uses Mobil 1 0W-40 European Formula with BMW oil filter cartridge and is good for 15k miles per BMW. Now has 140k miles and no oil related issues or much usage. Now, admittedly, it's the 1.9 liter 4 cylinder and gets a 5.5 quart fill. The Taco is a 4.0 liter and gets 5.5 quarts as well but I'm going with 10k OCI and the engine is not really doing much high rpm loading.
    Fact is, modern synthetic oils are far, far superior to conventional oils 20 years ago. Of course, with modern CNC machining and what not, so are engine tolerances. Same goes for synthetic gear oils. Modern industrial gear boxes with 300 hp motors will run 24-7 for years no problem with syn gear oil.
    Pull a valve cover on a modern engine that's had a steady diet of Mobil 1 after 100k miles and the valve train will look like it just came out of the factory. No golden hue let alone sludge.
    I'm not sure people really appreciate what the Taco is all about. It's old school Japanese and designed and manufactured to be easily serviced, take a beating and run practically forever with just a tad of TLC and mechanical empathy.
  20. Jul 17, 2016 at 1:22 AM
    mavfox
    mavfox Well-Known Member
    SFL
    2013 AC TRDOR/07 FJC
    ARB Deluxe bullbar, OME 886 w/ Dakars, Warn Winch, Safari Snorkel, Tepui RTT.
    You forgot the most important one:
    -Check installation of driver's floor mat.
    :D
