Newbie Brake Maintenance question
Discussion in 'Technical Chat' started by Sinister184, Jun 10, 2023.
  1. Jun 10, 2023 at 8:35 AM
    Sinister184
    Sinister184 [OP] Well-Known Member
    23 Tacoma TRD OR 4x4
    I’m changing the front brakes on my Camry. I don’t normally mess with brakes (because I don’t usually keep cars long enough to change them), but after reading up I think it’s easy enough. A few questions though…
    I bought new OEM rotors and pads, most people clean the new rotors before putting them on with brake cleaner. I don’t really love brake cleaner fumes, can 90+ IPA be used for this purpose? Seems like I’ve seen people use it this way, and there should only be light residue on a new rotor.
    There’s some conflicting information about where to put shim grease. Should I put it on back of the pad and the back of the shim?
    Should I put the rubber grease (same as pins) on the pad ear/tab/track?
    Thanks!
    Bivouac likes this.
  2. Jun 12, 2023 at 2:25 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    I never used and cleaner on new rotors just removed the surface rust.
    Hi temp brake grease on metal to metal wear parts .
