newbie but need an answer... 2in leveling kit in the front, what do you need in the rear? for level
Discussion in '3rd Gen. Tacomas (2016-2023)' started by fnhi808, Sep 21, 2017.
  1. Sep 21, 2017 at 12:14 AM
    fnhi808
    fnhi808 [OP] Member
    sheldon
    17 dblcb trd 4x4
    do I need to get a 1in block? it is a 2017 dbl cab trd 4x4....instead of me searching...I just need an answer so I know what to buy instead of guessing...
  2. Sep 21, 2017 at 12:23 AM
    Toyo_newb
    Toyo_newb Well-Known Member
    Matthew
    2017 DCLB TRD OR 4x4 QUICKSAND
    I'm pretty sure you don't need anything as the rear sits about 2" higher than the front stock. Someone more lift knowledgeable will be able to confirm.
  3. Sep 21, 2017 at 1:16 AM
    fnhi808
    fnhi808 [OP] Member
    sheldon
    17 dblcb trd 4x4
    thanks guys...I already got the 2in leveling kit for the front...but I wanna know if anyone owns and installed this already and if they did how close it is too level...or will I have to buy a block for the back?
    cuz I wanna run 275 70 17 ko2 with out any rubbing issues...been looking into the forums and want answers instead of half knowing...so if anyone could help me out I would be greatly thankful and appreciate it greatly
  4. Sep 21, 2017 at 1:18 AM
    fnhi808
    fnhi808 [OP] Member
    sheldon
    17 dblcb trd 4x4
    what up killa!! ... stay blessed and live da humble life!! aloha from Oahu... k-town 96744 all day errrrryyyyydddaaayyy!!
  5. Sep 21, 2017 at 2:43 AM
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    subbed.....thinking of doing the same. I've read that the 2" spacer will give you
    about 2.5" of lift so you'd need a 1.5" block to level it. What did you buy?
  6. Sep 21, 2017 at 2:55 AM
    SR5 BRI
    SR5 BRI Brian Good Sport
    Brian
    Albany n.y.
    2023 Sport Quadcab
    Alot
    Save your money on the leveling kit and do it right the first time and level it with 5100's and new coils. Little more money ,but done right way. Most people will agree.
  7. Sep 21, 2017 at 9:16 AM
    fnhi808
    fnhi808 [OP] Member
    sheldon
    17 dblcb trd 4x4
    I ended up with a 2in supreme suspension spacer...but will probably end up going with the bilstein 5100 set up...as I been reading its the better way to go... thanks sr5brian
  8. Sep 21, 2017 at 11:09 AM
    amxguy1970
    amxguy1970 Well-Known Member
    Tyler
    Texas
    How about you not be lazy and do some homework so you know you are buying the correct thing the first time?
    Also here is a little piece of advice you could have received if you searched instead of went the lazy first post generic question route, all trucks sit different. If you take a tape measure you can see how much rake you have, then apply kindergarten math to see how much lift the rear needs (if at all) to get the desired result.
    The laziness of people these days :facepalm:
    Tyler
    bullaculla, Lord Helmet and irayfz6 like this.
